Old 03-20-2009, 10:18 PM   #1
cayman-impreza
Member#: 195604
1998 JDM STi Impreza
Default "Monster Energy" WRX/STi Impreza project.
This is my EJ20/EJ25 Setup
*EJ20 Heads
*STi Head Gasket
*TRP 2.5 Semi-Closed Deck Race Block
*Arias 100mm Forged Aluminum Pistons
*TRP Steel Billet Con-Rods
*Factory Forged Crankshaft '
*ACL Main Bearings
*Custom "wider" Rod Bearings
*TRP 12mm High Flow/Volume Oil Pump
*Cosworth Oil Control Baffle Plate
*Moroso Aluminum Oil Pan
*Stainless Steel Header
*Custom 2.5" External WG Setup, T3 Flanged Heat Wrapped "Up pipe"
*GT35 Oil & Water Cooled Turbo
*Full 3" Custom Exhaust System
*Apexi Muffler
*STi 5 Speed Gear Box Equipped with PPG Gear Set
*ACT Heavy Duty Pressure Plate, 6 puck "549lbs torque rated"
*JUN Light Weight Flywheel
*JUN ECU
*800cc Injectors
*Aeromotive FPR
*ect..
This is when the car 1st arrived
cayman-impreza is offline   Reply With Quote
Old 03-20-2009, 10:19 PM   #2
cayman-impreza
Member#: 195604
After a few days....
Old 03-20-2009, 10:20 PM   #3
cayman-impreza
Member#: 195604
Here is the start of the motor build up
Old 03-20-2009, 10:21 PM   #4
cayman-impreza
Member#: 195604
Few More Pics:
Old 03-20-2009, 10:23 PM   #5
cayman-impreza
Member#: 195604
Few More Pics:
Old 03-20-2009, 10:23 PM   #6
cayman-impreza
Member#: 195604
Few More Pics:
Old 03-20-2009, 10:24 PM   #7
cayman-impreza
Member#: 195604
Few More Pics:
Old 03-20-2009, 10:25 PM   #8
cayman-impreza
Member#: 195604
Droping in time
Drop the motor in yesterday...unfortunately they sent me the wrong clutch disc..the springs on the clutch touches the flywheel bolt...shipped it back today so hopefully by monday i should have a replacement...so the main time we can go ahead & finish up the front end.
Stay Tuned!
Old 03-20-2009, 10:48 PM   #9
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Thats a nice project you have there.
scby rex is offline   Reply With Quote
Old 03-20-2009, 11:59 PM   #10
JoePokah
Member#: 154734
2005 Legacy GT LTD
Looks to be a great build. Great pictures as you went. Subscribed.
Jeff
JoePokah is offline   Reply With Quote
Old 03-21-2009, 08:02 AM   #11
wrxhard
Member#: 108091
Such a bad ass build deserves some less turd-tastic tail lights. Other than that, i love it!!!!
wrxhard is offline   Reply With Quote
Old 03-21-2009, 08:36 AM   #12
06njsti
Member#: 150986
06 #001 LSB STi
looks good im just a little confused as where the "monster energy" comes in at
06njsti is offline   Reply With Quote
Old 03-21-2009, 12:48 PM   #13
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
you should ship me your original tail lights
slava from goshen is offline   Reply With Quote
Old 03-22-2009, 10:32 PM   #14
cayman-impreza
Member#: 195604
Updates on the progress this morning, most of the front end is complete (radiator, A/C, Power Steering, Light Weight Pulleys, Belts, Oil Cooler & Relocator Kit ect installed)...hopefully get the turbo back from Tropical Metals Ltd Tomorow with the Down Pipe Flange & have the Up Pipe, turbo & Exhaust System Installed ect.
Old 03-22-2009, 10:53 PM   #15
SharpShifter
Member#: 101484
2002 jdm sti {gt35r}
sti blue
wait what u doing here
lol
look good keep it up
SharpShifter is offline   Reply With Quote
Old 03-23-2009, 02:34 AM   #16
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
wow great build have fun!
toutanje is offline   Reply With Quote
Old 03-23-2009, 05:51 AM   #17
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
awesome build. good luck!
Thug Nasty is offline   Reply With Quote
Old 03-23-2009, 11:04 PM   #18
cayman-impreza
Member#: 195604
Thanks GUYS!!!
Some Updates on the progress today, having the Aeromotive fuel filter changed ...i tried fitting the turbo....with no success on that due to the Rotated Mount Up Pipe, Big Turbo & using TOP MOUNT created a clearence issue, will get new pipe tomoro & build the up pipe from scratch & modify it to how we want it to fit!
Old 03-23-2009, 11:25 PM   #19
MartinSTi05
Member#: 145145
2006 wrx STi
It was looking pretty good until this happened:
The specter of shoddy fabrication rears it's ugly head in yet another otherwise decent build.
MartinSTi05 is offline   Reply With Quote
Old 03-24-2009, 08:26 AM   #20
cayman-impreza
Member#: 195604
Were not using that up pipe, im buying a new pipe today & were gonna build it from scratch to fit.
Old 03-26-2009, 11:08 AM   #21
SharpShifter
Member#: 101484
sti blue
well keep it up
but tmic why
Old 04-01-2009, 10:44 PM   #22
cayman-impreza
Member#: 195604
The TMIC is just temporary, just to get back on the road.
Placed an order on few goodies for the car... [nod] (High Flow Fuel Rails, SAMCO 9pc "red" Hose Kit, "Black Clear" complete front end Aftermarket Lighting, Summit 23ft Braided Fuel Lines with various -6AN fittings, Earl's Performance "Y" Fuel Block, Summit Racing x3 "90deg" & x4 "straight" -6AN Hose Ends Fittings, x2 Summit Racing Chrome Hood Pins & Hood Pins Lanyards, x2 Summit Racing Dozen Decal Packs, Hayden Automotive Power Steering Fluid Cooler, Turbonectics Turbo Heat Shield)
Old 04-01-2009, 11:24 PM   #23
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You have yet to mention engine management?
Old 04-01-2009, 11:36 PM   #24
cayman-impreza
Member#: 195604
for the main time, im just hooking up a Greddy E-manage "blue" to the Mine's ECU thats on the car allready, also using PE 850cc Injectors.
Old 04-02-2009, 10:40 AM   #25
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
All that and no head work?
The heads are really going to hold you back.
LiquidForce is offline   Reply With Quote
FS: Subaru WRX/ STI/ Impreza Turbo TD05H -16G Marine520 Engine/Power/Exhaust 14 12-08-2006 01:19 PM
Wrx-Sti Impreza build swilcox01 Subaru Conversions 5 11-05-2006 08:48 PM
FS:Chargespeed type I CF front lip WRX/STI impreza kool168 VIC Private Classifieds 1 09-04-2006 05:48 AM
WRX STI Impreza Subaru tail lights 04 05 06 Blueboost Private 'For Sale' Classifieds 10 10-07-2005 01:57 PM
Turbo Xs Subaru Wrx Sti Impreza Exhaust Save Big wojtek Private 'For Sale' Classifieds 0 06-10-2005 07:05 PM
