Old 03-21-2009, 12:10 AM   #1
subarujay
Member#: 206231
Default help needed?????/
I just bought a beat up 2.2 1996 imprezza outback to do some rallycross in. Brought it home and the car started to cut out at 4200 rpm. In any gear, any amount of throtle. It feels like a rev limiter at exactly 4200, kinda like a street bike. Heres the wierd thing.....If you turn the car off and restart it, it will rev all the way to redline 3 or 4 times before it starts limiting. Oh ya, I forgot to mention that when I started looking closer at the car I realized that someone had changed the engine to a EJ18. I have heard that the EJ18 are a much beter engine to build that the 2.2, but I know very little about subarus now.........That will change
Any advise as to where to start would be appreciated
subarujay is offline   Reply With Quote
Old 03-21-2009, 07:13 AM   #2
loccomoffo
Member#: 200891
1995 Impreza EJ18
Shabby White
Blocked fuel filter? Fuel pump delivery?
loccomoffo is offline   Reply With Quote
Old 03-21-2009, 11:37 AM   #3
testify
Member#: 196517
2007 n00b rocket
urban grey metallic
I believe that with the engine swap its going to throw you into M4(full modified class) at the rallyX. That can be a big rough if your car is not well prepared and others in the class are heavily modified.
testify is offline   Reply With Quote
Old 03-21-2009, 05:52 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
if it's only for rallyx, gut that mofo. I mean it, do every weight saving thing you can. Take the hood off if you have to(I'm not sure what the rules say about the trunk). Power doesn't mean everything at a rallyx. Tires usually do. Since your engine is (more or less) gutless, it'll be easier to remove weight than to make more power. As for your current problem......I have nothing. Sorry.
Old 03-21-2009, 06:14 PM   #5
cmiovino
Member#: 134005
2004 WRX Premium
Try the purge valve... my buddy's girlfriend had this same fuel cutting problem with her Miata. I have no idea where it's located or how much it costs.
Old 03-21-2009, 07:59 PM   #6
subarujay
Member#: 206231
Default air flow
If this helps anyone else........It was the air flow sensor on the air box. Unpluged it and the car ran like crap but reved up great.
Need Help, Need Help nicholas112481 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-10-2010 01:24 PM
HELP HELP HELP Need help diagnosing a clutch problem.... redoktober_99 Tri-State Area Forum 9 02-06-2007 10:28 PM
Need help!! Need to find a +12v switched wire NOW! Please help! nxwrxfx Electrical & Lighting 16 04-25-2006 05:29 PM
need perrin uppipe help & more help needed hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-09-2004 08:07 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
