#1 |
Member#: 197739
South East
Vehicle:2009 WRX Obsidian black pearl |
So I was bored today an desided to try out making my own a pillar gauge pod.
![]() Make sure you are ready to prep and paint the other a pillar to match. I had my old gauge pod from my 2004 miata. ![]() I took out the a pillar. FYI the air bag deployes between the apillar and the rubber trim. ![]() Nice area to run my wire for the AFR and boost gauge. ![]() ![]() Its a close fit but needs work. ![]() ![]()
#2 |
Member#: 197739
South East
Start by sanding the inside of the pod and the area on the apillar the pod will be glued to.
![]() ![]() I used 5 min epoxy on the inside of the gauge pod. Work fast before it gets gummy. Use 15 min expoxy if you have never used this stuff. After I put the pod on the Apillar, I tacked the whole thing together with foam friendly thin CA and kicker. ( it will flex more than reg. CA.) You can get both of the glues from a local hobby shop. I also think i saw some at hobby lobby. ![]() ![]() ![]() Before we start puttying and fiberglassing, do a test fit. ![]() off to go mix and spread bondo. Next set of pics soon. |
#3 |
Member#: 200730
Vehicle:2008 \\\/\/RX SWP |
nice idea! cant wait to see how it turns out
#4 |
Member#: 197739
South East
Putty time!
![]() ![]() ![]() ![]() Sanding the rough shape. You can see how it will blend in. ![]() ![]() ![]() ![]() |
#5 |
Member#: 197739
South East
And more Putty time. This layer will fill the first layer and smooth it all out.
![]() ![]() ![]() ![]() And after sanding the putty. You can see the final blend. Hopefully this will be the last time for the putty. ![]() ![]() ![]() ![]() ![]() ![]() |
#6 |
Member#: 189860
South East
Vehicle:2006 StageII WRX TR WRB |
looking good cant wait to see it finished
#7 |
Member#: 197739
South East
Ok so to see any cracks or scratches I shot a thick coat of primer. I then wet sanded it down.
![]() ![]() Now I used .75 fiber glass cloth. Mixed 5 min epoxy with denatured Alcohol. This it to thin the epoxy. Then I applied the cloth to the edges of the pod. This is to prevent the cracking between the plastic and the bondo. ![]() ![]() ![]() ![]() |
#8 |
Member#: 197739
South East
All most done.
Im using filler primer to fill any scratches. Im also using it to give the apillar the smooth finish. I will do this to the other apillar as well. This is a long process of spraying and wet sanding. The more you do it the smoother it will be. The next update will be the finished part. So far not bad for a day of work. ![]() ![]() ![]() ![]() |
#9 |
Member#: 152042
NWIC
Vehicle:2002 WRX WRB |
wow looks good. Have you done all this today?
#10 |
Member#: 192015
Damn that looks incredible wish I had skills like that.
#11 |
Member#: 186441
South East
Vehicle:2004 Impreza WRX PSM |
Great work! Look forward to seeing the finished product!
#12 |
Member#: 197739
South East
Ok Finished.
Its not perfect. But it works .I used Graphite Grey Metalic and also painted the other apillar. I did not sand and smooth the other side. Just wanted to see if i needed to. Maybe next weekend I will do it along with the B and C pillars. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Inside shots. Its crapy pics but you get the idea. ![]() ![]() Last edited by AtomicFrawg; 03-21-2009 at 10:16 PM. |
#13 |
Member#: 197739
South East
#14 |
Member#: 179573
South East
Vehicle:2002 MBP Bugeye Flip Flop Tuned on corn |
that looks sick good job man!!
#15 |
Member#: 153056
Dedication and patience is the key here. Great results Chris! U also picked a nice weekend to work on this project. Beautiful weather all day long.
Keep the pictures coming man, it's looking superb. |
#16 |
Member#: 182874
International
Vehicle:2007 wrx WR Blue |
good effort anyway
#17 |
Member#: 125573
TXIC
Vehicle:2006 2.5i ProTune by Sean S. |
looks great bro! i like that color of the pillars
Blake |
#18 |
Member#: 200730
nice job
do work! |
#19 |
Member#: 189860
South East
looks good blends well pretty good
#20 |
Member#: 185297
Vehicle:2008 Evo X RR |
Nice work mate,
Haha not when are you going to make me one... |
#21 |
Member#: 43602
NESIC
Vehicle:2005 Outback Sport |
What happens if the A pillar air bags go off?
#22 |
Member#: 193921
TXIC
Vehicle:2010 Impreza WRX STi SWP |
i wish someone offers an A pillar pod, or a clock pod, or any pod for that matter for '08s
I have a set of defis and i want them to go on clean i wish i was good to try and make my own ![]() props on what u did |
#23 | |
Member#: 200730
a: hate the location 2: cant believe how overly priced that piece of plastic is |
#24 |
Member#: 201995
NESIC
Vehicle:2005 bugeye Flat White & whatnot |
props. looks good
#25 |
Member#: 197739
South East
The airbag depolys between the apillar cover and the rubber seal. The apillar does not move. In the first few pics you can see the ridged plastic mount for the airbags. This mount dirrects the bags downward.
http://www.youtube.com/watch?v=PoOpqiU4ics Notice in the video, The a pillar trim does not come off the a pillar. Last edited by AtomicFrawg; 03-22-2009 at 11:04 PM. |
| Thread Tools | |
| Display Modes | |
| Stock WRX Clock Pod and A-Pillar Gauge Pod | niemand_1 | Interior/Dressup/Audio & Security | 3 | 03-01-2010 05:02 PM |
| dual A-pillar gauge pod - dual cluster bezal gauge pod | designfate | SCIC Private Classifieds | 5 | 03-17-2008 11:46 PM |
| Lotek WRX Wagon a-pillar Gauge pod | abqkid | Private 'For Sale' Classifieds | 14 | 05-25-2006 01:38 AM |
| 02-05 WRX Autometer triple pillar gauge pod | BOOST3DWRX | Private 'For Sale' Classifieds | 4 | 04-29-2006 02:38 AM |
| autometer dual a-pillar gauge pod and triple center gauge pod | anthonyrb98 | Private 'For Sale' Classifieds | 10 | 08-04-2005 10:21 PM |
