Old 03-18-2009, 03:45 PM   #1
parkes
Member#: 166898
1994 T leg SS
ABM
Default Help! EJ22-EJ25!
Okay, Original Car 1999 subaru legacy EJ22 Brighton.
Swapped in 1997 Phase 1 DOHC EJ25 from a leggie GT.
Engine is swapped in and complete, We are not getting spark.
We believe it to be incorrect wiring of EJ22 to EJ25 Coil packs.
The EJ22 harness has 4 wires for the original coil pack, Black, Red-black, yellow-black and blue.
The EJ25 Coil pack uses 3 wires, Blue, Red-white and yellow.
How do i convert the EJ22 harness to use the EJ25 coil pack on an EJ25 engine?
thanks!
parkes is offline   Reply With Quote
Old 03-18-2009, 04:14 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The 1999 uses an integral ignitor that is built into the coilpack. That's what you are missing. You've got no ignitor.
Old 03-18-2009, 04:35 PM   #3
parkes
Member#: 166898
1994 T leg SS
ABM
Okay, What do i do about that?
Old 03-18-2009, 07:29 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
One thing you can do is look into a set of Kinsborne sparkplug wires. They have an application that fits your 99 coil and has DOHC boots at the other end.
I've used plain ole 180* (straight) booted Accell wires on DOH motors too. Reused the OEM coil boots with new terminals inside and never had any issues once I got the boots slid over 8mm wire.
A last resort would be to add an external igniter and do the appropriate wiring involved with it.
Jay
Old 03-18-2009, 11:21 PM   #5
parkes
Member#: 166898
1994 T leg SS
ABM
The coil pack does not bolt up, how do i go about wiring in a ignitor?
Old 03-19-2009, 07:59 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
I'm sure you can make a bracket to hold the coil, so I won't address it.
To wire up an igniter (which you won't need if you make brackets to hold your old coil) you'll need to Splice it inline with the 2 channels of ignition you've got coming from the ECU and provide a ground. I don't have wiring diagrams with me at the moment, so I can't comment of specific wire colors. I believe it is member "Amigerslives" (spelling might be wrong) that posted up info on eliminating the igniter to run a new style coil with older style wiring harness. He's built his car from scratch, using Subaru power. If you search around the conversions forums for those terms, you may find the thread. I can look later when I get home.
Jay
Old 03-19-2009, 08:12 AM   #7
parkes
Member#: 166898
1994 T leg SS
ABM
Ok i will make a bracket, but what wire goes to what?
Old 03-19-2009, 08:54 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
If you are going to continue to do these weird mix and match swaps, which seem to give you no end of trouble with sensors and wiring, I would strongly suggest you get your hands on a set of wiring diagrams for all of the cars you intend to mess with.
Old 03-19-2009, 10:05 AM   #9
parkes
Member#: 166898
1994 T leg SS
ABM
lmao so true!!!! I dont know where to get wiring diagrams from though
Old 03-19-2009, 05:01 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
http://techinfo.subaru.com/index.html
www.northursalia.com
http://techinfo.subaru.com/html/index.jsp
The thread relating to bypassing the factory igniter is here: http://forums.nasioc.com/forums/show....php?t=1552376 you can do the opposite, by adding the igniter.
Jay
Old 03-19-2009, 05:13 PM   #11
parkes
Member#: 166898
1994 T leg SS
ABM
Im just making a custom bracket and rewiring my old coil pack in and get different plug wires, i wanna go the safest route
Old 03-19-2009, 07:07 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
I think that is your best bet. Kingsbourne(sp?) wires has a PN for hybrid Subies, I don't recall what the number is.....but get in touch with them.
FWIW.....I mounted a coilpack to the pitchmount on the RS. Used a couple pieces of aluminum angle stock and it's been rock solid. It required longer plug wires, but it wasn't a big deal for me. Here's a couple pics. Sorry I don't have any showing the boots going into the heads, or a close up of the coil mount.....It was kind of an afterthought at 2-3am prior to a race......
Jay
Old 03-20-2009, 08:17 PM   #13
parkes
Member#: 166898
1994 T leg SS
ABM
Ok so i made i bracket which was really easy thanks for the suggestion storm
wired it back up and i got spark now i just need to solder the wires and tidey that up and mosey around for my old plug wires and g rig it
Old 03-20-2009, 10:57 PM   #14
parkes
Member#: 166898
1994 T leg SS
ABM
Got the car to start, and runs like poooo. It starts and runs like a cho cho train but will not idle
Random oil coming out the bottom but it got to dark to check where it was coming from but it didnt look like it was coming from the oil pan
Old 03-21-2009, 10:06 AM   #15
Storm
Member#: 5218
96L Most Over-
Developed Beater
At least you're making headway. I'm sure that with some persistance and patience, you'll get it sorted out!
Jay
Old 03-21-2009, 12:20 PM   #16
parkes
Member#: 166898
1994 T leg SS
ABM
yea it seems like i plugged in the injectors wrong.... maybe....
Old 03-21-2009, 10:06 PM   #17
Storm
Member#: 5218
96L Most Over-
Developed Beater
I've got my fingers crossed......
Jay
Old 03-22-2009, 05:38 PM   #18
parkes
Member#: 166898
1994 T leg SS
ABM
yeah!! i didnt cross the fuel lines and i can get the car to rev awsome!! it sounds good i just need to source the oil leak and then set my throttle screw and get this thing to idle!
Old 03-22-2009, 06:47 PM   #19
parkes
Member#: 166898
1994 T leg SS
ABM
Here ya Go!
270cc red top injectors + fuel rails from EJ22, EJ25 Kawikid20o2 Private 'For Sale' Classifieds 9 02-01-2006 02:13 AM
Engine I wanted sold...Anyone have a N/A block for me? EJ22, EJ25 preferred marcus12 New England Impreza Club Forum -- NESIC 24 02-05-2005 07:08 PM
WTB: ej22/ej25 supermoose Mid West Subaru Owners Club Forum -- MWSOC 3 05-20-2003 04:45 PM
ej20 , ej22, ej25 tech questions STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-24-2002 09:28 PM
ej22/ej25 spark plug cables... Benjamin Tang Normally Aspirated Powertrain 2 10-02-2001 09:42 PM
