Old 03-21-2009, 04:32 PM   #1
04subaroo
Member#: 206199
2004 WRX
Default lookin to start a hybrid build maybe
start off by saying sorry if this is already on here and most of the hybrid builds have different mods so i figured i just start one with my mods
my mods are full exhaust header up pipe TBE and Fender CA and a zoom stage one clutch
my questions are i have a 2004 wrx with blown rings or sumthin along those lines i have the chance to get a 06 sti long block. would it be better to run the sti motor(my concern is trans). or build a hybrid motor? i kinda wanna build the hybrid motor. i know i need sti HG water pump or will the wrx one work (its new). timing belt and tensioner or will the WRX one work (new also). as for turbo i wanted to run the stock tdo4 with maybe a pound or 2 over stock boost and a tune by 555.
anything else i may need advice anything to help me out a little here thanks James
04subaroo is offline   Reply With Quote
Old 03-21-2009, 04:56 PM   #2
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
regardless of it being a hybrid or a full sti longblock, the 2.5 bottom end is going to make a lot more torque, and it is only a matter of time when the 5 speed goes. A lot has to do with your driving style too! If you can get an sti longblock, with all the harnesses, ecu, and dash for a good deal (and can afford it) then that is the better route.
P.S. I hate to be the one saying this, but you need to search, this has been covered and done so many times.
DK
WrXtaCy2003 is offline   Reply With Quote
Old 03-21-2009, 05:05 PM   #3
04subaroo
Member#: 206199
2004 WRX
y dash? and ya im sorry i spent like 2 hours reading and what not but most of the other poster were like i wanna make 300 400 500 hp im not lookin to do that so i figured id post one
Old 03-21-2009, 05:26 PM   #4
JSarv
Member#: 163445
l33t *******
[email protected]
Hybrids tend to be problematic.. Not a bad Idea but personally I would pickup some used 257 heads and just do the longblock....
-Jerod
JSarv is offline   Reply With Quote
Old 03-21-2009, 05:52 PM   #5
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
If you do the full LB, will the WRX harness work? Or by running the 257 heads do you automatically need the STI harness?
STI_KLR is offline   Reply With Quote
Old 03-21-2009, 08:02 PM   #6
JSarv
Member#: 163445
l33t *******
[email protected]
I think there are a few differences. mainly AVCS... I would just pickup a top engine harness either new or used and then do the couple of wires for the AVCS from the enginebay to the ecu... I think there may also be a company that makes a harness or conversion for this...
-jerod
Old 03-21-2009, 08:11 PM   #7
STI_KLR
Member#: 189660
'02 WRX
Ah, good info. What if I don't want to run AVCS? I know you have to plug the holes on the intake cams.
Old 03-21-2009, 08:15 PM   #8
JSarv
Member#: 163445
l33t *******
[email protected]
No biggy then - you could probably run a 2.0 ecu as well then...
-Jerod
Old 03-21-2009, 09:01 PM   #9
STI_KLR
Member#: 189660
'02 WRX
Sounds good.
After doing more research, all you need to do is:
  • Plug holes on intake cams
  • Use WRX cam seals
  • Run oil feed lines to AVCS solenoids
  • Drill &Tap location for WRX cam sensor on EJ257
Am I missing anything?
Old 03-21-2009, 09:05 PM   #10
JSarv
Member#: 163445
l33t *******
[email protected]
Sounds about right... I'm not 100% positive though..
I'd consider running 264 non avcs cams - kelford or such... I'd also run a td06-20g with an 8cm2 turbine housing.
You'll have early boost - a good amount of power and those cams will really compliment it...
-Jerod
Old 03-21-2009, 09:35 PM   #11
STI_KLR
Member#: 189660
'02 WRX
Right now, I'm trying to save money wherever possible. I'm not making a crazy build, similar to the OP. Just a reliable DD re-using my DB small 16g.
Old 03-22-2009, 12:24 AM   #12
JSarv
Member#: 163445
l33t *******
[email protected]
Why not stick with the 205? It has more potential than alot give it credit for..
-Jerod
Old 03-22-2009, 12:36 AM   #13
STI_KLR
Member#: 189660
'02 WRX
Honestly, I don't feel like rebuilding it. I don't have the time to take the motor apart, and start from scratch. I'm on a budget and I have time constraints. Plus, getting the 257 now helps with my plans for the future when I have more time and money to make a beast. But for now, a stockish STI SB/LB or Hybrid build will do
Old 03-22-2009, 01:17 PM   #14
04subaroo
Member#: 206199
2004 WRX
if i do the long block will my water pump and all the accessory's work on the sti or do i need "sti" accessorys
Old 03-22-2009, 01:40 PM   #15
JSarv
Member#: 163445
l33t *******
[email protected]
There were some revisions - but yes I do think they will... I know PS pump - ac - alternator will forsure.
-Jerod
Old 03-23-2009, 01:26 AM   #16
04subaroo
Member#: 206199
2004 WRX
ok thanks
Old 03-23-2009, 07:02 AM   #17
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Originally Posted by STI_KLR View Post
Sounds good.
  • Use WRX cam seals
If you get a long block all you have to do is [*]Drill &Tap location for WRX cam sensor on EJ257
If you have the avcs oil lines hooked up you shouldn't block holes on the intake cams. I know for sure the intake cam gear on the 04 sti has a point for the cam sensor to pick up a signal from. Other years may have it as well but I always use an 04 gear when I swap in a long block.
LiquidForce is offline   Reply With Quote
Old 03-23-2009, 09:54 PM   #18
wrxdrivr04
Member#: 156619
2004 WRX 2.5 hybrid
FP EVOIII 16g
Default hybrid
well i just finished up my hybrid build this weekend, i have to say so far so good, my mod list is a bit more than what you have but, i have to say it was good build for my budget i spent around 3200, im running a map for my utec delta till breakin is over then its down to turbo xs for the tuning!! so in all if no problems occur i will have about 3700 buck in the whole build, i have about 150 miles on it so far and i cant complain one bit!!
modd list b4 hybrid swap
Megan racing uppipe and header
sr*s turbo back
greddy profect spec B Electronic boost controller
FP Evo III 16g
255lhp
Utec delta
Spec stage 2 clutch kit
Modds for hybrid swap
ej257 shortblock
Modd Wrx injectors by witch hunter
TGV deletes (done myself)
Group-n sti motor mounts
Also i did all my Labor myself which saved me about 2000 bucks but it was well worth it!!!
wrxdrivr04 is offline   Reply With Quote
Old 03-24-2009, 01:40 PM   #19
04subaroo
Member#: 206199
2004 WRX
sweet well my car is for sale on ebay it ends sonday if it dont sell i am gunna start the build the only problem is its gotta be done by april 20 so i can go to school if it sells imma go buy some cheap good on gas car. been look at 2003 SER spec v any1 hear anything about them
Old 03-26-2009, 02:29 AM   #20
04subaroo
Member#: 206199
2004 WRX
nothing on the spec v ???
2.0 to 2.5 hybrid build question mvcsk8r Built Motor Discussion 3 07-27-2014 08:30 PM
Lookin to start a build soon.. advice or opions plz wiseyZ32 Built Motor Discussion 1 10-11-2009 06:09 PM
Funky WRX > STI via RS Block Hybrid build to save cash - CAN I DO THIS? Fongers Built Motor Discussion 24 12-28-2008 08:41 PM
lookin to start a meet in westlake boardertj Southern California Impreza Club Forum -- SCIC 8 09-15-2004 07:06 PM
I want to build a rally car... but I don't know where to start. majglow Motorsports 25 04-24-2002 12:55 PM
