Old 03-21-2009, 07:07 PM   #1
j3t
Member#: 169815
Default ej20g injector question
Getting my car tuned soon, and wanting to get some new injectors. What is a good direct upgrade for this? Is there a stock fuel rail that is an upgrade for the ej20g? Ive got greytops in now, which from what i hear are stock.
Thanks,
Jet
j3t is offline   Reply With Quote
Old 03-21-2009, 11:23 PM   #2
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
I wouldn't worry too much about the fuel rails. If you want to upgrade injectors, I believe 300ZX ones are the same so there are plenty of aftermarket options around.
rockcrete is offline   Reply With Quote
Old 03-22-2009, 02:31 AM   #3
suberdave
Member#: 101865
88 GL-10 STi
dont mess with finding a set of injectors that may fit...
buy a set of phase 2 adapter collars, and then any USDM STI sidefeed injector will fit right in to your rails...
i have these ones and they are awesome...
http://www.fecker.co.uk/scooby/product.php?id=2
-=Subedave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 03-24-2009, 04:03 AM   #4
ncarn8
Member#: 71419
or, STI yellowtops are 440cc. cheap bolt in upgrade.
ncarn8 is offline   Reply With Quote
Old 03-24-2009, 06:51 AM   #5
RealDealTarheel
Member#: 142447
**** Texas
Which the stock gray tops are also 440cc........
RealDealTarheel is offline   Reply With Quote
Old 03-24-2009, 03:37 PM   #6
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
while we're talkin about injectors, i have a spare set of Tomei 555cc's out of a SR20, are those a drop in replacement (EG20K).
Rei_Akira is offline   Reply With Quote
Old 03-24-2009, 06:26 PM   #7
sniper512
Member#: 189923
1993 JDM WRX
Okay i have thought for quite sometime that the gray tops are 440s as well but the more I talk to people about them the more I get confused. I know my car come stock with the TD05 and have been told that with the TD05 comes 440s, but lots of people argue with me about it. Does anyone have proof/data that the phase 1 WRX's come with 440s? Rob? I just keep hearing different opinions.
sniper512 is offline   Reply With Quote
Old 03-24-2009, 06:56 PM   #8
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
If my memory is right, the WRX injectors are the JECS side feed and the part #'s are on them - I think they might be 0R05
http://www.witchhunter.com/injectordata1.php4
Just remember that flow rate is subjective to fuel pressure and if you're planning on leaning on your motor, send them out and get them flowed if you're not upgrading.
Old 03-24-2009, 06:57 PM   #9
Rikshaman
Member#: 90817
should be the same as supra injectors? 2jz. lol
Rikshaman is offline   Reply With Quote
Old 03-24-2009, 07:21 PM   #10
Rikshaman
Member#: 90817
actually, yes. 2jz injectors will work as long as you use a resistor pack.
Old 03-24-2009, 07:38 PM   #11
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Depends on what bar fuel pressure... The grays are rated flow 370 whereas the yellows flow 440cc at same bar pressure.
Yellows are bigger injectors flow wise than grays.
blkgm8 is offline   Reply With Quote
Old 03-24-2009, 10:59 PM   #12
suberdave
Member#: 101865
88 GL-10 STi
Just looked they are. anyone have numbers on the yellow tops???
-=Suberdave=-
www.suberdave.com
Old 03-25-2009, 02:32 AM   #13
kleinkid
Member#: 27091
2010 STi SE
Default yellow tops
These yellow tops I have came out of a ej20k intake manifold and they are
OR15.
kleinkid is offline   Reply With Quote
Old 03-25-2009, 05:25 AM   #14
RealDealTarheel
Member#: 142447
**** Texas
What bar pressure are the gray's rated at 370? Everything I've ever read says they're 440's. I haven't sent my spare set to be flow tested because well, honestly I don't really care, but I'd like to see your data.
Old 03-25-2009, 08:51 AM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
agggg misinformation
greys 440 cc at 3 bar
yellow 480 cc at 3 bar
all the other test you see are at 3 bar example: blue usdm wrx top feed 440cc at 3 bar
this is from results at RC engineering
those bad numbers (370,390,440) are a 2.5 bar (which is used in au/nz) but have no idea why
sr20 injectors will not drop in they are phase 2 and need the rail adapter
Old 03-25-2009, 09:57 AM   #16
sniper512
Member#: 189923
1993 JDM WRX
Awesome definitive. Me likes.
Old 03-25-2009, 11:29 AM   #17
Rei_Akira
Member#: 194555
1997 GC8 coup
green
thanks Jaxx, much appreciated.
Old 03-26-2009, 02:33 PM   #18
thad
Member#: 176616
1994 impreza
white
Ok, I may be way off on this one, but since the EJ20G FPR is set somewhere around 2 bar, doesn't that mean that the Gray tops will not even break the 370cc mark in use on a stock motor.
I may be assuming something incorrectly.
thad is offline   Reply With Quote
Old 03-26-2009, 03:09 PM   #19
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
You are. Stock fuel pressure is 3 bar.
rob is offline   Reply With Quote
In need of EJ20G injectors Millencolin! Private 'Wanted' Classifieds 2 03-17-2006 01:35 PM
wtb ej20g injector silvialost Private 'Wanted' Classifieds 0 11-03-2005 03:00 PM
ej20g injector problems smacksube Subaru Conversions 4 01-13-2004 03:12 PM
injector question on EJ20G 99WRXEJ20 Subaru Conversions 1 12-11-2003 03:24 AM
EJ20G Injectors NinNin Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-30-2002 03:37 PM
