Old 03-21-2009, 09:57 PM   #1
pinoiboi13
Member#: 143107
04 wrx cam-tuned
blue(sold)
Cool are sti cams a good upgrade instead of using the wrx cams
hello i'm getting a block built with forged internals on a 2.0l since i spun a bearing. i have the option for swapping the wrx cams for sti cams for an extra $200. i wanted to know if its worth it. i heard i can get another 20-30 hp depending on the setup.what do you think guys. help me out. i was also thinking about getting the block pinned basically making it a semi-closed block like a version 7 engine but not the price. i need some feedback.
pinoiboi13 is offline   Reply With Quote
Old 03-21-2009, 11:31 PM   #2
305mouse
Member#: 106792
2005 Saab 92X
Stage Pi w/ VF35
If for $200 you'll get STI cams installed, I would do it. You'll get some more top end out of it.
305mouse is offline   Reply With Quote
Old 03-22-2009, 03:14 AM   #3
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
I'd beg to differ as the lift is not much more on those. The only reason to do this is to utilize AVCS but if you don't have the heads and ECU to support it, its a waste in my mind. If you do go down this route, make sure to plug up the oil holes for avcs if you can't control it. Honestly though, you'd be better off getting a set of cams made for the wrx...
Fongers is offline   Reply With Quote
Old 03-22-2009, 08:59 AM   #4
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
You can probably get another 2hp at the flywheel.... IIRC, theyre the same except for one more mm of lift on the exhaust side. = not worth $200.... I have a set of cams you might find useful - pm me if you want...
gto7419 is offline   Reply With Quote
Old 03-22-2009, 09:19 AM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
They may net you only minimal gains to peak HP but your HP curve will definitely not drop as much up top as it does with WRX cams. For $200 installed and shimmed, I think its worth it considering if you want to go aftermarket cams you're looking 700-1000 bucks + necessary buckets + labor= way more money than you're probably willing to spend. Like said by others, duration is the same, lift is a little more I ran them before I got my Cosworths and they are better than the stockers.
Old 03-22-2009, 09:26 AM   #6
pinoiboi13
Member#: 143107
04 wrx cam-tuned
blue(sold)
well thanks for the knowledge i'll probably stay with the stock cams. dont want to worry about other problems arising.
Old 03-22-2009, 09:30 AM   #7
andya
Member#: 200134
STI cams have 10 degrees more duration on the exhaust than the WRX and I have seen decent gains over the entire rpm range with the swap.
andya is offline   Reply With Quote
Old 03-22-2009, 09:52 AM   #8
scottD
Member#: 94748
I put sti cams in and gained near 30 hp on the top end and the torque did not
drop near as fast..
Yes! they will help...
scottD is offline   Reply With Quote
Old 03-22-2009, 11:18 AM   #9
gto7419
Member#: 44256
05 outback xt
drop near as fast..
I stand corrected... Do you have dyno runs for this? Were the cams all that was changed?
Old 03-22-2009, 11:26 AM   #10
the real suby dude
Member#: 125497
02 Alpine White M3
Rouge Engineering !!!
Might as well go with some BC's
the real suby dude is offline   Reply With Quote
Old 03-22-2009, 12:40 PM   #11
kellygnsd
Member#: 32669
LINK G4 hybrid STi
If you can get some BC's installed for $200 I'm all for it but for the money his upgrade ain't to shabby.
What year and model STi where these out of? USDM STi cams are the same duration as USDM WRX cams ('04 at least)
Old 03-22-2009, 12:46 PM   #12
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
if you get the 06/07 sti cams they are hollow thus lighter weight.. i have a set of 07 cams in my car.. the top end doesn't drop off at all like the wrx cams did.. but i am not sure of the actual increase in power, i did a lot more all at once than just this mod
autvincereautmori is offline   Reply With Quote
Old 03-22-2009, 01:49 PM   #13
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Just to help you guys out a bit:
First, let's look at the part number history for the intake cam:
2.0L
02 WRX 13031AA101/102
03 wRX 13031AA390/391
04 WRX 13031AA391/392
04 WRX 13031AA490/492
05 WRX 13031AA490/492
2.5L
06 WRX 13031AA350/351/352
07 WRX 13031AA351/352
04 STI 13031AA350/351
05 STI 13031AA350/351
06 STI 13031AA350/351/352
07 STI 13031AA351/352
As you can see the 02-05 WRX cams are of course different from the corresponding year STI cams, but in 06 when the WRX went to the 2.5L motor it follows the same cam part numbers.
Looking at the specs:
04 WRX
04 STI
07 WRX
07 STI
From this, we get:
04 WRX
240 duration intake
240 duration exhaust
17 degrees overlap
04 STI
240 duration intake
0 - 20 degrees overlap
07 WRX
240 duration intake
0 - 40 degrees overlap
07 STI
240 duration intake
0 - 30 degrees overlap (* note difference from above WRX. This is an ECU programming difference)
As you can see, the change from 04 STI to 07 STI is only in the amount of AVCS advance.. Not a physical thing but instead an ECU map change. However, note that the duration of the WRX and STI cams are the same. What is different however is the overlap. WRX cams have a fixed 17 degree overlap, while the STI cams can be changed from 0 to 40 degrees. (Lift is also different)
If you put STI cams in WRX heads, you will be running them with 0 advance, so the will be the 'max retard' values.
How does this effect power:
WRX cams in WRX heads will have greater power rolloff up top due to excessive overlap.
STI cams in WRX heads will have better top end power, but worse spoolup due to lack of overlap.
STI cams in STI heads will have the best of both world. Yummy.
This, btw, is part of the reason for the difficulty in tuning the hybrid 257+wrx head/cam engines.
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 03-22-2009, 01:55 PM   #14
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Correct up to 07. (08 STI is different)
Not in the 04-07 range.
Correct:
04 WRX Cam Lift
Intake 9.25
Exhaust 9.15
04 STI Cam Lift
Intake 9.55
Exhaust 9.75
STI Cams have a bit more lift, especially in the exhaust side.
Jeff
Old 03-22-2009, 02:09 PM   #15
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
If you got the money some Tomei 252s or Kelford 264s cams would be great. I hold 300whp until 7K RPM with Kelford 264/264 cams and I am only running 16PSI.
csmithwrx'05 is offline   Reply With Quote
Old 03-22-2009, 02:18 PM   #16
andya
Member#: 200134
Interesting... I will take another look at the service manual because I remember compairing the 03WRX to the 05STI exhaust profiles and came up with the 10 degree difference... I could be wrong but the swap made a great improvement after tuning vs a WRX cammed vehicle with similar mods.
Old 03-22-2009, 03:18 PM   #17
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Those pictures I posted above are from the service manual. It is possible you noticed the difference in open or close angle, not duration.
As I mentioned above, the swap will net more lift as well as less overlap at higher rpm, which will net more power. So you are not wrong as to the gain. It is as would be expected given the differences.
Jeff
Old 03-22-2009, 03:57 PM   #18
gto7419
Member#: 44256
05 outback xt
Im actually pretty sure I was right, that the sti cams only offer a mm of additional lift on the exhaust cam..
Old 03-22-2009, 05:17 PM   #19
pinoiboi13
Member#: 143107
04 wrx cam-tuned
blue(sold)
Cool
drop near as fast..
thats why i was thinking about putting them on. my machinist and tuner said it give me around 20-30 hp. thats the feedback i wanted to hear.
Old 03-22-2009, 05:22 PM   #20
pinoiboi13
Member#: 143107
04 wrx cam-tuned
blue(sold)
so basically i could get some good topend gains uptop???
Old 03-22-2009, 09:07 PM   #21
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Here is a dyno of a hybrid with 02 heads with stock 2.0 cams and sti cams. Not much of a change in peak power but area under the curve is way improved.
LiquidForce is offline   Reply With Quote
Old 03-23-2009, 12:00 AM   #22
pinoiboi13
Member#: 143107
04 wrx cam-tuned
blue(sold)
i guess the sti cams aren't bolt on either. do i got to do something with the acvs. also am i gonna have to retune my car with the sti cams.
Old 03-23-2009, 03:13 AM   #23
kellygnsd
Member#: 32669
LINK G4 hybrid STi
All you have to do to make the AVCS cams work is plug the oil feed passages by tapping and putting in an allen head set screw + loctite.
Of course you need a re-tune after upgrading cams. Cams are the heart of any motor. They orchestrate the whole combustion process and if you hadn't noticed, most anything you add to our cars would benefit from a re-tune.
What was all included in this $200 deal you talked about. I'm starting to think you may have misunderstood what you where getting for $200. If its STi cams installed, shimmed, and made ready for non-AVCS use its a steal. If its just $200 for the cams and the rest on you, expect to shell out a good bit more to get everything right and right is the only way to do it
Old 03-24-2009, 01:20 AM   #24
pinoiboi13
Member#: 143107
04 wrx cam-tuned
blue(sold)
actually ya its only $200 more. basically i paid for the labor already with the motor being built. he already has some sti cams already there that are plugged. so ya just $200 and he installs them and everything. i also heard he builds good engines.he only builds subaru race motors. keith from awdtuning.com reccomended him to me. he's a reputable tuner in texas.
i spun a bearing on mine so he's basically making mine like a version 7 motor. thats why i was thinkin about doing this upgrade. can i drive my car with the sti cams on and be ok till i get a tune 2-4 months from now??
Old 03-24-2009, 02:23 AM   #25
kellygnsd
Member#: 32669
LINK G4 hybrid STi
So my question to you is why aren't they installed yet?
Don't half ass this build. Sell yourself on the corner or wait a few until you can raise $400 for a tune. You will possibly be in different load site throughout the rpm range and your timing will be off. You'll be risking you new motor and that's not worth $200 so do it right or don't do it.
Why can I not post pictures directly instead of using a link? WRXfoME Newbies & FAQs 1 09-08-2007 10:14 AM
Since several members are incapable of using the search function.... Thug Political Playground 14 11-01-2004 03:42 PM
Instead of eating the donut I put in front of my cats face...... eurojax Off-Topic 18 06-05-2004 08:26 PM
instead of tatoos, the piercing thread IgotWRXed Off-Topic 32 08-20-2002 05:50 PM
Why are you guys running Redline75-90ns instead of mt90? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-28-2002 01:28 PM
