Old 03-22-2009, 10:16 AM   #1
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
Default Finally decided to go with the Blouch 18G, what else do I need to get?
I picked this turbo setup due to price and power (up to 400HP is good enough for me). I'm going to accompany this turbo with a grimmspeed EWG combo http://www.importimageracing.com/mm5...egory_Code=573
750cc injectors, fuel pump and a turboxs FMIC
http://www.importimageracing.com/mm5...egory_Code=576
and obviously, I will be tuned.
Am I missing anything? Headers a must?
I already have a 3" catless TBE and an intake.
lateralus1082 is offline   Reply With Quote
Old 03-22-2009, 11:28 AM   #2
s42k1
Member#: 95702
You should be fine with that setup
s42k1 is offline   Reply With Quote
Old 03-22-2009, 11:30 AM   #3
Wagtoda3rd
Member#: 173351
06 WRX STI
Thats would be going towards the limits of your transmission though wouldnt it?
Wagtoda3rd is offline   Reply With Quote
Old 03-22-2009, 11:33 AM   #4
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
I've heard the 5 speed on the 08s are pretty stout, but I'm not so sure . One of the reasons I haven't considered a GT30R rotated kit
Old 03-22-2009, 11:38 AM   #5
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
Originally Posted by ehnihl View Post
I think it's all good...Good Luck man...
Thanks! Now, I need more luck to put more money away with approval of the wife
Old 03-22-2009, 12:02 PM   #6
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
How about your BPV? I'm guessing you're retaining your stock one since you didn't mention it? What boost levels are you going to run? What about BCS? Are you getting an aftermarket one or going with the MBC?
ThreeEleven is offline   Reply With Quote
Old 03-22-2009, 12:14 PM   #7
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
I'm looking at 16-18. should keep me safe
I have a BOV here, but it's atmospheric. Booo! So I don't know whether or not to keep the stocker. I forgot about the BCS, what do you recommend?
Old 03-22-2009, 12:28 PM   #8
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
I'd keep your stock BPV and you'll be more than happy with it. Crush the cap if you're lookng to hold over 22psi just to make sure there are no leaks. For boost control...that's something you're going to ask your tuner what he prefers. My tuner HATES MBCs so I got the GM BCS on here for $35 shipped. Other good BCS are HOA (which is the same as prodrive), Prodrive, and Grimmspeed. The last three just plug into your factory BCS harness, whereas with the GM you have to cut the stock harness and solder in a new one.
Old 03-22-2009, 01:25 PM   #9
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
I got prodrive . Works great
vtecTHIS is offline   Reply With Quote
Old 03-22-2009, 01:57 PM   #10
jonpark
Member#: 141449
2007 EvoIII16g WRX
UGM EJ257+05/6speed
is 16-18psi enough to get 400hp?
i think it's too low get that kind of hp...
jonpark is offline   Reply With Quote
Old 03-22-2009, 02:02 PM   #11
garboplateNY88
Member#: 134113
05 LEGACYGT
247hp 300tq retuned STM
turboxs FMIC no that is worst FMIC you can get for your STI I used to have that then I switched to Ultimate Racing FMIC way better cooling
you will need Dom 4 to hit 400hp
garboplateNY88 is offline   Reply With Quote
Old 03-22-2009, 02:03 PM   #12
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
I just have a regular WRX
Old 03-22-2009, 02:05 PM   #13
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
well, it's rated up to 400HP. I don't know if the engine could handle that much without some internal work.
Old 03-22-2009, 02:13 PM   #14
garboplateNY88
Member#: 134113
05 LEGACYGT
ok my Dom 4 is rated for 580 hp you think Iam going to hit 580 hp without putting racegas and 30 - 35 psi to tune it at.
http://www.blouchturbo.com/turbos/Dom4/
18g is rated at 400hp that means its maxed out the turbo at 400 so 20psi you only get 300 hp at the wheels
to get 400hp to need around iam guessing 30psi on that 18g
Old 03-22-2009, 02:16 PM   #15
garboplateNY88
Member#: 134113
05 LEGACYGT
Ultimate Racing FMIC will be better cooling for your turbo making it last longer too
Old 03-22-2009, 02:18 PM   #16
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
Would I be better suited with another turbo? I'm open to all options (with the exceptions of turbos that need me to upgrade my internals)
Old 03-22-2009, 02:20 PM   #17
garboplateNY88
Member#: 134113
05 LEGACYGT
well how much hp you looking for?
Old 03-22-2009, 02:22 PM   #18
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
400 is as much as I want to go. I'll be daily driving this thing
Old 03-22-2009, 02:24 PM   #19
garboplateNY88
Member#: 134113
05 LEGACYGT
well Dom 4 then will be easlier with less boost to hit 400
my tuner is tuning my car at 20 PSI and I have a fully built motor and I should have around 400hp or less need to put it on the dyno then I can tell you for sure
Old 03-22-2009, 02:49 PM   #20
Lateralis
Member#: 144421
2012 STi ltd
If this is a daily driver than I recommend you stay with the 18g. This is the way you need to look at it though. Dont look at this as the #'s game like "oh I want to hit 400hp ATWs". Think of it as "where do I want my power? Do I want quick and snappy so I can play with it all the time, or do I want it up top so I can scream onto the freeway with the occasional highway pull? The 2.5l and an 18g will be pretty snappy with usuably power on the street and should put you well into the 300's in the hp and ft-lbs area. But its up to you.
Lateralis is offline   Reply With Quote
Old 03-22-2009, 06:49 PM   #21
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
I just dynoed my 18g TDO5 7cm on my 06 TR and I laid down 310 and 350 at 18PSI. This was on a Dyno Jet.
*6STARS* is offline   Reply With Quote
Old 03-22-2009, 08:01 PM   #22
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
How much boost are you running?
Old 03-22-2009, 09:30 PM   #23
v8crossover
Member#: 204206
you dont need a dom 4 to hit 400, dom three should be fine but 400 on 18g in theroy is possible. sound like a nice set up though
v8crossover is offline   Reply With Quote
Old 03-22-2009, 09:39 PM   #24
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
You are getting this info about the TXS fmic from where? What dyno charts, timeslips or anything, is telling you this? Because I assure you its wrong.
You also dont need anything approaching a DOM4 for 400hp. He is looking for 400 at the crank, not wheels.
Defiant Autospeed is offline   Reply With Quote
Old 03-22-2009, 10:01 PM   #25
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
18 PSI it was in my post haha the first pull it made 315HP and 389torque. I was like. CAMtuning did a great job
Just ordered a Invidia Q300 Catback, What else do I need to hook it up? STIStalker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-05-2010 02:01 AM
just ordered some STi heads to go wiith my EJ257 block...what else do I need? ted dibiase Built Motor Discussion 10 10-04-2007 01:40 PM
Going to install mods what else do I need? breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-09-2006 11:40 AM
Buying VF34: what else do I need to buy? The Modaholic Normally Aspirated with bolt-on Forced Induction Powertrain 1 02-03-2004 07:49 PM
What else do I need to consider before installing this GenMaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-21-2003 11:11 PM
