Old 03-22-2009, 02:06 PM   #1
Izzy05
Member#: 111166
Default Swapping in an Ej20. Is there a How to? Advice?
My friends jdm impreza blew the piston rings in the current stock EJ20 so weve picked up a used JDM ej20. We are going to attempt to swap it in our selves but we are not sure where to start. I cannot find a "HOW TO" which i thot I would be able to here on Nasioc.
Thanks for any help or advice!
Izzy05 is offline   Reply With Quote
Old 03-22-2009, 02:42 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yep. It's called the Conversions Forum.
Old 03-22-2009, 03:40 PM   #3
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
so your swapping a JDM engine with another JDM engine??
Factory service manual will tell you everything you need, to remove and replace a engine.
scoobydorift is offline   Reply With Quote
Old 03-22-2009, 05:48 PM   #4
Izzy05
Member#: 111166
yes its a jdm to a jdm. Thx ill check the conversions forum
is there a trick to this. how to remove your cam gears to get to you head bolds STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 08-21-2015 11:58 AM
07 wrx clutch swap is there a how to? boostdog Transmission (AT/MT) & Driveline 7 11-09-2009 06:18 PM
Tech gurus: Is there any way to trick an installer into thinking an OS is different? Jessie James Off-Topic 11 04-23-2008 02:58 PM
Is there a how to replace tie-rod thread? subyboy828 Newbies & FAQs 10 08-07-2007 07:03 PM
Is there a way to put the gauges from an STI in a 03 RS? jonnysubby Electrical & Lighting 16 09-29-2005 01:19 PM
