#1 |
Member#: 190388
Vehicle:2002 WRX PSM |
I currently have a WRX shell Im slowly piecing together and as of now it has a JDM STi 5 speed. I was looking for engines to put in and I was wondering how hard it would be to throw in a 06 US STi engine if I also had the wiring harness and ecu? What all would I need to change such as Cluster and all that good stuff?
Do you guys think its worth the effort to go with that instead of the stock 2.0? Also after search a little I found that a hybrid set up is also an option any thoughts there? Any thoughts are appreciated! ![]()
#2 |
Member#: 98961
Vehicle:2003 WRX Black |
My swap is nearing completion and the difference in power between my tuned 2.0 and the untuned STI engine is staggering. With the same VF34 it's night and day. I vote for STI engine.
#3 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
how about a 2.0 top end and a 2.5 block ... no wiring required..
#4 |
Member#: 190388
#5 | |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
I'mma be running a built 9.0:1CR 2.2 closed deck shortblock with ported '06 WRX heads. Weird??? hA! This setup is to be revved up to 8250rpms. |
#6 |
Member#: 177
NWIC
if any thing would be weird about it, it would be the tuning as the VE will be different with the higher compression ... --> it will need a custom tune by someone who knows what they are doing .
| Thread Tools | |
| Display Modes | |
| *WTB: STI short block, JDM 2.0 or USDM 2.5 | Lam | Private 'Wanted' Classifieds | 5 | 02-14-2008 06:42 PM |
| *WTB: STI short block, JDM 2.0 or USDM 2.5 | Lam | VIC Private Classifieds | 0 | 02-11-2008 11:38 PM |
| JDM 2.0 or USDM 2.5 into '02 Forester | sabubarub | Subaru Conversions | 0 | 03-05-2007 12:22 AM |
| WTB pre 98 dohc heads/intake manifold jdm 2.0 OR usdm 2.5 | gto7419 | Private 'Wanted' Classifieds | 0 | 01-04-2007 12:46 PM |
| When motor goes...JDM 2.0 or US 2.5??? | Drews_WRX | Factory 2.0L Turbo Powertrain | 5 | 09-03-2004 10:40 AM |
