Old 03-22-2009, 08:51 PM   #1
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
Default "knock" issues
just rebuilt the engine, but the ecu is NOT happy.....IAM is dropping to 12, it thinks its knocking but theres no way, no timing and 14psi of boost...we think its mechanical noise....any one run into this issue before? know a way to fix it?
2.5 litre on 2 litre heads
wiseco pistons
eagle rods
272 BC cams, springs n retainers, 1mm oversize valves
any ideas at all????? i gotta get this thing tunedd!
vanillajuice is offline   Reply With Quote
Old 03-22-2009, 09:14 PM   #2
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
I had a friend with a similar issue and I believe it turned out to be a bad injector...
gto7419 is offline   Reply With Quote
Old 03-22-2009, 09:25 PM   #3
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
IAM starts at 16 just cruising around....then during boost it drops then comes back up in the logs
Old 03-22-2009, 10:11 PM   #4
JSarv
Member#: 163445
l33t *******
[email protected]
I think this is a common issue with hybrids...
Did you have your 2.0 combustion chambers bore matched for the bigger 2.5 bore??
-Jerod
JSarv is offline   Reply With Quote
Old 03-22-2009, 10:12 PM   #5
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
Did you torque the knock sensor down to spec? Pretty common cause after a fresh rebuild...
Are you seeing actual FBKC? What values and where? WOT or just cruising? Any fine learning KC?
I assume you're logging a wideband, too?
phlegmon is offline   Reply With Quote
Old 03-22-2009, 10:25 PM   #6
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
yea afr's are right where they should be....fbkc is like -2.11 and -4.22....WOT....3064 and 3155 rpm then nothing before or after...then it goes back to zero....and IAM back up to 16 towards redline...a suby tech did the install...im sure he torqed it to spec....one tuner suggest i add timing and lean it out more?
Old 03-22-2009, 11:12 PM   #7
Maxwell Power
Member#: 190729
sounds like either a bad injector or a rich misfire causing engine noise being picked up as knock. Is the engine running smooth when this happens? Are there black puffs of smoke from the tailpipe?
Oxygen sensors pick up oxygen in the exhaust. It isn't a fuel burn sensor. Extra overlap from larger cams puts more oxygen in the exhaust. Cams do affect your indicated afr a bit and it changes with boost levels. If one cylinder is lean and the other are rich, you can have burn post combustion and AFRs might indicate 10.9 but 3 cylinders might be 9.8 and the other is 12 or 13:1.
Maxwell Power is offline   Reply With Quote
Old 03-23-2009, 03:02 AM   #8
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
so wouldnt i have knock all the way thru the log or cruising if an injector was bad?
Old 03-23-2009, 12:22 PM   #9
Maxwell Power
Member#: 190729
nope...
Old 03-23-2009, 12:29 PM   #10
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Considering these are the same injectors that his old setup was tuned on and the maf and injector scaling hasn't changed, I don't think it can be an injector.
06rexwagon is offline   Reply With Quote
Old 03-23-2009, 12:52 PM   #11
Maxwell Power
Member#: 190729
great!
So we have another case where someone asks questions and seeks advice and argues with every answer. Instead of arguing, try proving that the items in question aren't the issue by testing.
Good luck!
unsubscribing
Old 03-23-2009, 12:55 PM   #12
06rexwagon
Member#: 114730
[email protected]
Originally Posted by Maxwell Power View Post
great!
Good luck!
unsubscribing
Wow, I was just suggesting that the injectors aren't a likely problem. The thing that changed on his setup is his motor, not his fuel system. He didn't argue with you, and neither did I. Way to over react.
Old 03-23-2009, 01:13 PM   #13
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
^ +1 rich knock, totally sounds like it but don't knock the guy trying to help ya man. Lean up a point or two.
Fongers is offline   Reply With Quote
Old 03-23-2009, 01:16 PM   #14
MrSlowbaru
Member#: 129231
2005 wrx
cgm
it cant hurt to do a leak down test.
MrSlowbaru is offline   Reply With Quote
Old 03-23-2009, 01:42 PM   #15
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
dom i wasnt arguing, just asking....and i didnt knock anyone either! just looking for help thats all
Old 03-23-2009, 02:04 PM   #16
gto7419
Member#: 44256
05 outback xt
while you may think that nothing has changed, removing and reinstalling the entire fuel system opens a ton of variables for dirt to enter the system... Injectors go bad.... Ive personally experienced the same situation...
I would seriously recommend you sent the injectors in to be tested...
Old 03-23-2009, 06:36 PM   #17
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
ya DW is down the road if that ends up being the case
Old 03-30-2009, 01:03 AM   #18
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
thank u cameron we got the IAM to stay up at 16!!! tho still a bit of FBKC and FLKC...it should be fixed eventually...i hope
Old 03-31-2009, 11:38 PM   #19
SVT_WRX
Member#: 164830
G61 III OVE 58e
What did you do to fix the problem you were having?
SVT_WRX is offline   Reply With Quote
Old 03-31-2009, 11:54 PM   #20
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Yeah what did you do I have a hybrid and I have experienced this before....And this year I have a brand new set of bosch injectors haven't even run yet.....
TDagen is offline   Reply With Quote
Old 04-01-2009, 12:17 AM   #21
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Noisy motor will pull timing even under light accel or cruise.
TopSpeed is offline   Reply With Quote
Old 04-01-2009, 08:42 AM   #22
06rexwagon
Member#: 114730
[email protected]
The IAM is staying at 16, but even at wastegagate pressure I am getting feedback and fine learning correction. I moved the afr to 11.3
Old 04-01-2009, 02:05 PM   #23
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
i may end up trying that capacitor thing
http://www.romraider.com/forum/topic4591.html
Old 04-01-2009, 02:46 PM   #24
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
great!
Good luck!
unsubscribing
Welcome to Nasioc!
irascible is offline   Reply With Quote
Possible Tranny issue, grinding with no load battlewaggin Transmission (AT/MT) & Driveline 3 06-06-2010 01:02 AM
Strange "knock" after 28psi tuning TurboQueef Built Motor Discussion 19 03-27-2009 10:59 AM
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2006 09:45 PM
Boost issues or Gauge Issues? IwantONE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-12-2006 05:18 PM
Issues, issues, issues.. trying to install stage 4.. and it just doesnt want to happn ctwrxwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-06-2004 02:52 PM
