South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 03-23-2009, 05:16 AM   #1
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
Default HELP!!! Car making bad sound...vid
Hey guys tonight my car started making some weird sounds.
Its kind of a grinding sound that sounds like its from te turbo area when Im in boost. At idle or just cruising around it doesnt make any sounds out of normal. But once the turbo starts boosting it makes the sound. I took off the heat shield, and couldnt hear any exhaust leaks. No smoke and the oil is still at full. Also I cant really duplicate it when the car is stopped. It only happens when the car is driving.
I made a crappy video with my cell phone. You can hear the sound when I boost it and it goes away right when I let off of the throttle at the end.
C-grunt is offline   Reply With Quote
Old 03-23-2009, 07:42 AM   #2
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
do you have a boost guage? what does it do?
has your clutch slipped recently?
It's either your turbo is bad or the car is dumping all the boost.
bobturismo is offline   Reply With Quote
Old 03-23-2009, 10:28 AM   #3
chosen_cartel
Member#: 151620
2003 WRX
I am not a mechanic but it seems like the same sound my car was making awhile back and it turned out to be the turbo. When it happened to my car, it was the same parameters, it would only make the noise while the car was under boost.
chosen_cartel is offline   Reply With Quote
Old 03-23-2009, 11:02 AM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Probably a failing turbo. This can happen everyonce and a while. Sometimes oil starvation to the turbo is the cause. The 2.5L WRX's have a small filter screen on the supply line to the turbo that can become plugged with sludge and stuff causing insufficient oil to be supplied to the turbo. I have historically only read about this on larger more oil hungry turbo's though.
I guess my point is you should remove this screen just in case it's the cause when you put a new turbo in. Subaru removed it on later models.
Old 03-23-2009, 12:58 PM   #5
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
what turbo are you running? if its just a stock td04 i have one at jays house. im at school so i cant listen to the video. ill check it out when i get home
SubeSTIle is offline   Reply With Quote
Old 03-23-2009, 01:16 PM   #6
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
Yeah its the stock td04. It still is boosting and desnt seem to be losing much if any power. But I havent been boosting it since it started.
Old 03-23-2009, 03:32 PM   #7
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
idk what mods you have but is it still under warrenty?
Old 03-23-2009, 03:54 PM   #8
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
I cant hear it very well in that vid chase. If it is only on boost it could be the start of a failing turbo or a boost leak at a certain pressure. Take a screwdriver and stick it agianst the exhaust housing of the turbo and to your ear. If your turbo is on its way out you will most likely hear something abnormal, but not a guarantee. I would do a boost leak test first so if it is something simple you dont waste any money on parts. Another area that can make some stupid ass noises under boost is the uppipe to exhaust manifold gasket. That is more of a screaming noise where a boost leak will sound like a turbo diesel ford and a failing turbo will sound like a metal on metal scraping.
v8eaterWRX is offline   Reply With Quote
Old 03-23-2009, 04:13 PM   #9
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
Well I took it over to Christians house and it appears to be several exhaust leaks. The gasket from the turbo to the DP is leaking. Also the DP to catback is open a little. My exhaust sits very very low and I did catch it on a automatic gate guide at Teach's apt complex. Im going to take it to the exhaust shop that did my last exhaust and see if they can cut down the hangers.
Hope this is the problem.
Old 03-24-2009, 01:41 AM   #10
gormonk
Member#: 98960
1978 brat (fo realz)
red
sounds like exhaust leaks (plural) to me
gormonk is offline   Reply With Quote
Old 03-24-2009, 07:58 PM   #11
racingfish
Member#: 60976
1969 LGT
FATURBO
yeah it was coming from tuBRO to dp and then dp to catback... it was pretty bad.
racingfish is offline   Reply With Quote
car making funny sound 20gwrx Service & Maintenance 6 04-16-2008 12:35 AM
Need help, Car jerks bad when starting to build boost. Manoxide069 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 02-20-2008 04:19 AM
Fellow STi owners, does your car make this sound? volkl23 Transmission (AT/MT) & Driveline 0 07-20-2004 07:19 PM
Help car making noise! Problem after uppipe install jbogli Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-20-2003 10:25 AM
Help car making bad sound. White Knight Legacy Forum 5 07-12-2002 01:54 PM
