Old 03-23-2009, 04:10 PM   #1
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
Default Any Build Hybrids Making Decent Power
Ifso, please post up your numbers and componets. During my search im only finding mid-low 300 bybrids. Anyone running 400+ on a hybrid.? Ifso post up.
smileyou is offline   Reply With Quote
Old 03-23-2009, 05:58 PM   #2
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Check my post "hot mess"... Its in the mid 300's now with a 20g but when I had a bolt-on 35r in land of 93 octane pump, it put out 417.
Fongers is offline   Reply With Quote
Old 03-23-2009, 06:01 PM   #3
Brisky
Member#: 148078
2001 Legacy GT
Birch White
Like an eltric / gas drivetrain hybrid?
Edit:
Epic Fail on my part...
Didn't figure people were throwing parts of EJ engines together...
Meh bad.
Brisky is offline   Reply With Quote
Old 03-23-2009, 07:31 PM   #4
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, DGM
Rotated EFR 6758
^ Fail.
Krang is online now   Reply With Quote
Old 03-23-2009, 07:50 PM   #5
andya
Member#: 200134
andya is offline   Reply With Quote
Old 03-23-2009, 08:06 PM   #6
smileyou
Member#: 152045
2003 PIA wrx
Any others .....
Oh yeah.. Failx2 lol
Old 03-23-2009, 08:12 PM   #7
andya
Member#: 200134
Sorry, no real numbers to post on hybrid engines that I built, but the transmissions are keeping me in business.
Old 03-23-2009, 08:15 PM   #8
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
My hybrid setup makes more than 400.
BTW proven power might be a better place for this .
LiquidForce is offline   Reply With Quote
Old 03-24-2009, 08:40 PM   #9
smileyou
Member#: 152045
2003 PIA wrx
Liquid what mods have you done to your heads? What's your setup
Old 03-24-2009, 08:44 PM   #10
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
There are lots of different hybrids, which specific one are you looking at?
Old 03-25-2009, 06:34 AM   #11
LiquidForce
Member#: 12811
2002 2.5l Wrx
They are ported v6 heads (same as usdm v7 heads) with oversized valves, upgraded springs and v6 sti cams. I thought they were v5 originally but I finally heard from the previous owner that they were indeed v6. Not sure if there is any difference.
The rest of the mods
2.5 block with Mahle pistons
t3/t04s rotated kit from Ultimate Racing
ebay FMIC
SMC meth kit
Perrin twin tip cat back
Original stock 5mt
Old 03-25-2009, 10:18 AM   #12
smileyou
Member#: 152045
2003 PIA wrx
ebay FMIC
SMC meth kit
Original stock 5mt
Your whole post intrigues me. Your making 500 on what type of gas? I didnt think that kit from UR would get you to 500. What type of dyno was this on. Can you elaborate please? What headgasket did you use?
Im wondering whether a non-rotated turbo can hit those numbers like a dom4 or atp gt35r?
Old 03-25-2009, 12:38 PM   #13
smileyou
Member#: 152045
2003 PIA wrx
Bump for an answer
Old 03-25-2009, 03:29 PM   #14
M3GTR
Member#: 21965
V-mounted 40R...what
I built an interesting hybrid.
Block: EJ22t
Crank: 2.5L Sti
Heads: 02 wrx polished with built valvetrain
I ran a GT4088 and made 488whp on pump gas on a low reading dyno dynamics dyno. Made almost 600whp on C16. Revs a little past 8k. Poor baby is in storage now because I moved and have yet to gather up the funds to bring it to me.
M3GTR is offline   Reply With Quote
Old 03-25-2009, 06:50 PM   #15
smileyou
Member#: 152045
2003 PIA wrx
where did you find that block.............ej22t's are apparently hard to find. What internals did you have inside the block?
Old 03-25-2009, 07:02 PM   #16
M3GTR
Member#: 21965
I was lucky enough to find a totaled 91 legacy turbo. I sent the block to the machinist to have it inspected and cleaned. I'm using some 9:1 cp pistons and pauter rods. The cams are Kelford 274/276. The rest of the valvetrain consists of Ferrea components.
Old 03-25-2009, 07:04 PM   #17
Kaldar142
Member#: 151090
S197 boosted V8 FTW
2.5L EJ257
CP OE bore pistons
Cosworth H Beam Connecting Rods
Cosworth Forged Billet Crank
Cosworth Race Bearings
Cosworth upgraded oil pump
Moroso oil pan
Tomei engine oil pan baffle upper and lower
Ported WRX Heads
Crower intake valves OE size
Crower exhaust valves OE size
Crower springs and titanium retainers
Crower non-AVCS 272 cams
FP HTA Green 2.4"
93 octane + 50/50 meth - 450Awhp
93 octane - 380awhp
full boost by 3400-3500, holds till 7200
car has a decent amount left in it, but i wanted to keep it safe since i will be beating the piss out of this car on the road course...
Kaldar142 is offline   Reply With Quote
Old 03-25-2009, 08:34 PM   #18
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Originally Posted by Kaldar142 View Post
2.5L EJ257
CP OE bore pistons
Moroso oil pan
Ported WRX Heads
FP HTA Green 2.4"
93 octane - 380awhp
Nice numbers! How does that HTA spool on the pump tune?
slowmike is offline   Reply With Quote
Old 03-25-2009, 08:52 PM   #19
LiquidForce
Member#: 12811
2002 2.5l Wrx
The 517 was on c16 and meth and 30 psi. The everyday tune on meth and 93 is 450whp 438tq at 26 psi.
Stock headbolts and stock STi gaskets ftw.
Old 03-25-2009, 11:28 PM   #20
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
i am supose to be getting my motor back from the machine shop tomorrow, it should be up there once i get it tuned...
STI SB w/100mm CP pistons
ACL race bearings
Cometic 100mm .040 headgasket
04 wrx heads w/ radius cut and back-cut valves.
DPR Stage 3 Cams
BC springs and retainers
FP Red 7cm 3in inlet
APS inlet pipe
70mm SRI intake
825cc stock injectors
255lph fuel pump
parallel fuel mod
gt-spec coated uel headers w/ grimmspeed coated 38mm EWG upipe and Tial EWG
FMIC
4EAT tranny with ipt high stall TC, and modded valvebody
p&p TB, intake mani, tgv deletes
should be together with in a week, then have to get time to tune it, and take it to the dyno and track...
im hoping for 450+ on 93oct and closer to 500+ on race juice..
might be a roll cage in my near future...
Twiztidunreal is offline   Reply With Quote
Old 03-26-2009, 12:29 AM   #21
Kaldar142
Member#: 151090
S197 boosted V8 FTW
on pump its actually more responsive then the meth tune.. turbo starts spoolin high 2000s and low 3000s, by bout 3500 its ready to GO
Old 03-26-2009, 12:29 AM   #22
Kaldar142
Member#: 151090
S197 boosted V8 FTW
i want a race gas tune!!
Old 03-26-2009, 05:53 PM   #23
amazingmumford
Member#: 121998
2003 WRX
here is my build:
EJ22 closed deck block with T sleeves
Cobb 79 mm billet crank
Calico coated bearings
Oliver billet conneting rods
Wiesco 100mm pistons/moly graphite treated skirts/ceramic coated tops/offset hollow pins
Custom copper heads gaskets
Stage 4 heads/1mm larger stainless steel intake and exhaust valves titainium retainers custom porting
Stage 4 cams 280 dur 415 lift
Arp head studs
RC engineering 1000cc injectors
Aps TGV delets/ with spare ports
Aps fuel rails
Modified Magnus intake manifold
Custom built 80 mm BBK thottle body
Gt 35r turbo .63ar
here are the numbers that I was making in 2005
Dyno video
http://s118.photobucket.com/albums/o...t=MVI_0357.flv
This was on a mild tune on 87 octane with the 35r .63 housing. I have made many changes and adjustments since then. I know that it is making more power now. I just don't know how much.
This is what happened last year. I have not had it on a dyno since but I know it is making alot more power know, enough to do this.
First clutch:
Fused the dual disk clutch shifting in third. Exedy warrented it and sent me this.It has held up.
Then this happened. Again in third gear. The PPG parts held up, but the case just could not hold up.
I have now installed a 06 six speed and a new R180 diff. I hope they hold.
amazingmumford is offline   Reply With Quote
Old 03-27-2009, 07:34 AM   #24
LiquidForce
Member#: 12811
2002 2.5l Wrx
Did you have straight cut ppg's or helicals?
Old 03-27-2009, 08:47 AM   #25
amazingmumford
Member#: 121998
2003 WRX
Helicals, no problems with the gears, just the case.
Any aftermarket turbo with VF39 spool that makes more power and torque? JDM addict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 75 05-26-2006 04:28 PM
any guess on how much power ill make with my setup? jimtweet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-24-2005 12:42 PM
Toyota to build hybrid cars at Lafayette? Alleggerita News & Rumors 3 10-06-2005 11:14 AM
How do you make decent money w/out a degree? Stroke Off-Topic 51 06-28-2003 01:17 PM
Is this setup up good for a decent power gain?? 1-JDM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-30-2002 02:23 AM
