Old 03-23-2009, 04:35 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default No wonder Ej205's spin bearings..
Well, not sure how many have spun ej205's with stock ecu mapping but after spending the weekend doing some tuning and logging my car, i can see why these things spin bearings/seize up.
My total timing @ peak load on a STOCK map was 27 degrees on 93 octane.
WTF was subaru thinking??
I wonder if its really a bearing issue after all..
EDIT ~~ POTENTIAL INLET LEAK
mxpunk is offline   Reply With Quote
Old 03-23-2009, 05:54 PM   #2
j.r
Member#: 201800
2007 STI
gt30r
At the last tuning session I went to in Austin, we had an 09 wrx spin a bearing. Sucks.
j.r is offline   Reply With Quote
Old 03-23-2009, 07:40 PM   #3
andya
Member#: 200134
Meeting Federal Emissions........
andya is offline   Reply With Quote
Old 03-23-2009, 09:59 PM   #4
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
how often are cars run @ peak load? its retarded..
Old 03-23-2009, 10:04 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
not a ej205^^
Stupid 09 wrx, emissions changed in 09 also, so they lean out on the onset of boost...then pop! My buddy lost one at 4k stock. The one in austin popped b/c they tried to lod one run after doing a dp...then pop, instead of flashing a richer map BEFORE the actual tuning started.
scby rex is online now   Reply With Quote
Old 03-23-2009, 10:48 PM   #6
andya
Member#: 200134
With (RETARDO'S) like me....... EVERY CHANCE I GET..
That's why the first thing I do is re-tune, but we don't have to worry about passing emissions either.
Old 03-23-2009, 11:37 PM   #7
JSarv
Member#: 163445
l33t *******
[email protected]
That wasn't a stock map then bud.. Sorry... Stock mapping a 16bit sees about 2.0 g/rev load at peak torque and falls to 1.75 g/rev at redline..
Tell me at peak torque you were hitting 27* of timing.. Was not stock..
Total timing for a 16bit 205 - including advance IFFF your IAM was at 16..
You didn't have a stock map - or you have a HUGE 80+mm intake...
I'm not trying to be a dick - but I can assure you at peak load you ARE NOT seeing 27* of timing on the stock map. Not only that I can assure you - your not holding 2.0 g/rev on anything less than 14psi of boost at redline - which itself is not easy..
You either have a huge intake - NON- stock map...
-Jerod
And on 93 I could run 30-31* of timing at redline with the stock turbo and 13psi or so boost. I could run about 14* at peak torque...
Peak torque with a stock turbo is between 3800-4200rpms and peak hp is between 5800 and 6400 rpms... Max load will always be at or close to peak torque..
JSarv is offline   Reply With Quote
Old 03-23-2009, 11:55 PM   #8
Disaster646
Member#: 135382
02 6spd hybrid wrx
fpgreen+E85 ftw [email protected]
on my hybrid wrx.. i hit 20psi all the way.. with a vf39.. 11.1a/f and 10-11degrees on peak and 18-20 at redline.. hauls ass ... blew 3rd gear last night when doing a
3rdgear pull.. lol my loads are up to 3.71 the max i saw.. by red i have 2.75..
Disaster646 is offline   Reply With Quote
Old 03-24-2009, 12:02 AM   #9
JSarv
Member#: 163445
l33t *******
[email protected]
Load is honestly irrelevant... Intake size and scaling can blow it out of proportion..
If I scale my injectors to 700cc's and scale my maf to meet my fueling needs I see 3.80-3.90 load (4.0 being max) and 300 g/s by 5000 rpms.. but I only see 4.74v on a 65mm or stock size intake...
You might run a txs intake (which is actually smaller than 65mm or a aem intake which actually is 65mm but reacts like a smaller piping diameter (I think because of turbulent airflow and MAF positioning)
I only refer to his load - because it is "stock" and "stock" maf scaling (which I use) on a stock boost should see around 2.0 load at peak torque..
If you are at that load - what intake are you running? What maf v do you see?
-Jerod
Old 03-24-2009, 01:05 AM   #10
pinoiboi13
Member#: 143107
04 wrx cam-tuned
blue(sold)
i was there. my o4 wrx spun bearings and so did the grey wrx before me on sunday.that sucked.i'm getting a motor built right now. i hear that spun bearings are pretty common.
pinoiboi13 is offline   Reply With Quote
Old 03-24-2009, 01:45 AM   #11
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
It would appear from your profile that you have a 2002 WRX. I see that not many of the more popular people in BMD have not responded, in part because the starting topic is somewhat incoherent.
Yes, a stock 02 WRX car can run 27 degrees at timing at higher rpm. As mentioned below a happy 02 can actually run a bit more. It is also obvious from just spending a few seconds looking at the 2002 rom that a stock car is not going to run 27 degrees of timing at peak load.
It was suggested that perhaps you have a different intake that is scaling the MAF, but that would not explain the claimed timing reference. As well, if it is true that you do have said aftermarket intake, your postulation about the stock tuning being problematic is, well, somewhat in error. The problem is in the person running the stock car on an aftermarket intake.
For those reading this thread, please spend some time reading other threads that can help you understand a bit more about tuning.
Any generic postulation about how 'XX' degrees of timing is somehow to blame for widespread bearing failure is a good indication that you should hit the 'next' button.
Correct.
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 03-24-2009, 08:43 AM   #12
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
-Jerod
i was doing logging the other day and i hit a max g/rev of 1.4 and it was knocking real bad @ 5500-6K rpms until redline. no modifications other then up and down pipes (catless). my total timing w/ an IAM of 16 was 27 degrees, the map is stock too. i didnt see any errors with my boost either since i was hitting my target boost levels (stock)
Old 03-24-2009, 11:51 PM   #13
JSarv
Member#: 163445
l33t *******
[email protected]
You have issues...
1.4 g/rev is WAY to low... Infact on stock maf scaling and intake I seen that at less than 10psi... I'll dig up a log if you want.
You have a leak between your turbo and maf sensor... I bet your also running so lean its gross...
Infact I got $10 that you have a leak - Don't drive it hard till its fixed or YOU will be replacing your engine soon...
Start with your intake box - your maf sensor could be loose... Check for cracks - good chance your stock turbo inlet has dry rotted and cracked...
^^^ Start there - don't drive it hard though - unless you have money for a shortblock... And then probably a long block because your egt's are probably so high your heads have cracked from the plug to your exhaust/intake valve ports....
-Jerod
Just for reference - g/rev = rpms/60/grams per second... meaning at peak torque - we'll say 4000 rpms - that means t 1.4 g/rev your moving 93 grams per second... meaning your around 3.6v on your maf sensor... Your target afr for that region is almost 13-1 afr... the stock map runs a bit leaner than given targets... In boost - thats bad... Very Very Very bad especially at 27* of timing... and anything over 0psi...
Old 03-25-2009, 08:47 AM   #14
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
You have issues...
-Jerod
The night I was doing pulls I hit a max load of 1.67 and my boost was building properly and tapering properly as well.
i made a mistake in my original post..1.4 was what i was seeing near the top of my pull.
Old 03-25-2009, 04:51 PM   #15
JSarv
Member#: 163445
l33t *******
[email protected]
You should be closer to 1.9-2.0 on stock boost... Check for leaks before anything...
Your probably running lean to boot.
-Jerod
Wtf so many 2.0L motors spin bearings? tankd0g Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 214 03-10-2009 12:19 AM
wondering about a bearing issue Hedbergsuby07 Tire & Wheel 0 04-24-2008 09:51 AM
the "what do you think causes so many ej20k's to spin bearings?" thread/poll 2slofouru Subaru Conversions 91 03-12-2008 12:45 PM
Bah! No wonder my car rolls more than others. Snoopy Mid Atlantic Impreza Club -- MAIC 7 03-21-2001 05:17 PM
No wonder it was faster tonight... Tarmac RS Mid West Subaru Owners Club Forum -- MWSOC 3 03-29-2000 11:43 AM
