Old 03-23-2009, 07:31 PM   #1
CarbonCJC
Member#: 202081
2002 WRX/STi
Other
Default Fuel Problems (Fuel Pump Controller?)
Hey there,
I have a bit of an issue on my hands... I have an engine code P1230 which I've found means the "fuel pump controller". I have a high flow fuel pump that has always worked great but has recently been making a lot of noise (maybe its going out) and is now getting quiet again.
I have a basic scanner that gave me the P1230 code after my engine just died out under normal driving conditions... I turned the key off and then back on and the car started and ran fine. About ten minutes later that same problem happened... the car died, but restarted and ran just fine until it happened again, and again, until I finally made it home to park it and fix it.
Where/What is the "Fuel Pump Controller"? Could this problem be connected to a faulty fuel pump or is this an entirely different issue?
Thank you so much for your help!
-Cameron
CarbonCJC is offline   Reply With Quote
Old 03-23-2009, 07:57 PM   #2
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
The fuel pump controller is located in your trunk on the passenger side near the gas door behind the carpet. Its held on to a bracket with two 10mm nuts.
Noah is offline   Reply With Quote
Old 03-23-2009, 08:02 PM   #3
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Old 05-25-2011, 08:44 PM   #4
rexwagon615
Member#: 274335
experience same problem on my 02 wagon did you ever end up fixing it?
rexwagon615 is offline   Reply With Quote
Old 04-09-2012, 11:14 AM   #5
03silverbullitt
Member#: 316218
I am also having the same problem how do u fix this
03silverbullitt is offline   Reply With Quote
Fuel pump controller related problems kromHASaWRX Subaru Conversions 4 01-06-2010 10:25 PM
USDM STI Fuel Pump Controller vs USDM WRX Fuel Pump Controller Boeleni Subaru Conversions 8 11-06-2009 10:33 AM
05 WRX Fuel Pump Controller, New 650 Injectors, STI Fuel Pump,TXS Catch Cans mrtrex Engine/Power/Exhaust 16 06-09-2008 06:55 AM
NEED ASAP!: 04/05 STI Fuel Pump Control Unit aka Fuel Pump Controller. dan2304k Private 'Wanted' Classifieds 0 05-25-2006 07:25 PM
stg 4 fueling problem//fuel pump?? wyowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-28-2004 07:06 PM
