Old 03-23-2009, 09:23 PM   #1
Mittelstadt
Member#: 184301
Default Let's talk O2 sensors and exhaust
I'm installing Borla Replica's and a 2005 STI catback on my 2006 2.5i. I was happy to see the pics from a users recent install on his 07, but he has a stromung setup that seemed to make it too easy! I've already made new flanges and have to bend and weld some pipe to make the catback work.
I have a car lift so the install should be crazy easy, but I lifted it up to check it out today (and I threw the muffler on since I had it up anyway) and I was seeing that there appear to be 2 O2 sensors. I was under the impression that there was only one. One is orange and the other was white (I think).
So I have weld in bung's to put the sensors in, however my question is where do I need to put them. I believe that I need to put one in the header and the other behind the cat? I can just drill in at the base of the header right before the connection to the cat if that's where it needs to go.
I can go throw it on the lift again and take pictures if need be, and I would have had I had the camera with me. TIA!
Mittelstadt is offline   Reply With Quote
Old 03-23-2009, 09:54 PM   #2
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Hey to answer your question since i JUST did this lol(and it was really easy with the stromung!!!!) But there are two 02 sensors. Pay attention which one goes after the cat because when you put them on your new exhaust the same one has to be after the cat. Now the one before the cat is on the header on your stock exhaust setup. However on the it DOES NOT need to be. My borla header had no o2 sensor plug ins. You just need to make sure the one is after the cat and the other is before it. Soooooo to simplify it, One 02 sensor right before the cat, one right after. DOES NOT have to be on the header.
07ImprezaMB is offline   Reply With Quote
Old 03-24-2009, 09:35 AM   #3
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
I guess my answer was so correct no one else wanted to chime in lol.
Old 03-24-2009, 11:42 AM   #4
Mittelstadt
Member#: 184301
Yeah, you should have ended your post with "/thread" lol
Thanks 07ImprezaMB, that makes perfect sense, I was just confused because I was only expecting to find 1 o2 sensor. It won't be too difficult. I'll take pictures after I get all this stuff fabbed up this weekend.
Old 03-24-2009, 09:38 PM   #5
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Hey good luck with the exhaust. Post them pics!!!!! im going to try and get a video of mine on here real soon. Gotta get the camera back from my friend first though.
can i zip tie second o2 sensor and put wideband o2 in that spot? sidwin AccessPort 2 02-11-2008 06:18 PM
Cats,O2 sensors, and exhaust - 2 simple questions Back Road Runner General Community 2 09-15-2006 08:12 PM
Front O2 sensor and/or EGT sensor (02 WRX) crazyhorse Private 'Wanted' Classifieds 1 11-03-2003 08:35 PM
O2 sensors and pass inspection with a full turbo back exhaust jfalcon001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-09-2002 09:04 PM
O2 sensor and speed sensor Seca2man New England Impreza Club Forum -- NESIC 3 04-06-2001 04:16 PM
