Old 03-24-2009, 09:42 AM   #1
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Default What does it mean to "break in cams"
I've seen this more than once on here and it boggles my mind.. How exactly are you suppost to break in new cams? I guess I understand if you trying to get the coating off of the lobes or something like that.. I've heard a few goofy theories about how to it as well.. I just put in a set of 11.3 Kelford 272's and I have no intentions of any sort of break in.. Can someone explain this to me??
bigmike25rs is offline   Reply With Quote
Old 03-24-2009, 10:14 AM   #2
JMack
Member#: 183773
1997 Legacy GT Wagon
Red
You should break in your cams, it will prevent flattening of the cam lobes.
make sure you use EOS and not Synthetic for the break-in period.
It is basically a poor-mans form of heat / use treating, similar to tempering from what I have read.
If I were you, I would just do it for the sake of peace of mind, if nothing else. Plus if you don't break them in, and you have a problem, the manufacturer may not honour their warantee...
GL with whatever you choose to do!
JMack is offline   Reply With Quote
Old 03-24-2009, 10:23 AM   #3
jays05
Member#: 78165
05 STI 35r + e85
Skipping cam break-in = problems. I ran mine at 2k rpms for 30+ minutes to break them in. It's not like you're doing a 1000 mile breakin or anything.
jays05 is offline   Reply With Quote
Old 03-24-2009, 10:34 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yup...most companies recommend about 2krpm for 20 minutes...don't use synthetic oil either, as already mentioned.
Old 03-24-2009, 01:43 PM   #5
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Ok, that makes sense.. I'm not sure why Kelford has nothing about it on their spec sheet though.. I just figured since the cams were steel and everything in the heads is aluminum that nothing could really "break in" as far as the cams.
Old 03-24-2009, 02:30 PM   #6
rodder
Member#: 86128
2005 OBP STi 355 whp
RIP :(
cam break-in comes from the days of flat tappet cams when you absolutely HAD to break in the cams or you'd risk wiping the lobes. To do this you don't want to run the engine at one rpm, you want to vary rpms to make sure you get an even wear pattern. Doing this meant each cam lobe was "broken-in" to it's corresponding lifter and also meant when rebuilding you always had to reinstall the lifters in the original bores they came out of.
I have a feeling with our suby motors, while not as critical as with a flat-tappet cam, the cam lobes do somewhat "mate" with the buckets which is why some guys recommend a break-in procedure.
rodder is offline   Reply With Quote
Old 03-24-2009, 06:03 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
If cam breakin was so important way dont OEM's do it? evos come with full synthetic with aluminum heads and steal cams. Subies dont come with some crazy cam break in either just the normal motor break in. Crap my motor was a demo and never even got the oem break in and has 109k with no problems. I think cam break in has gone the way of lifters and pushrods.
scby rex is offline   Reply With Quote
Old 03-24-2009, 06:12 PM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
When you buy a car you weren't the first one to run the engine. I've never seen an engine with zero miles on it on a lot.
Old 03-24-2009, 09:31 PM   #9
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
kelford puts their breakin procedure on the back of the spec sheet nad it is also on hteir website.It is very crucial for it to idle at 1800-2000 for the first 20 minutes.
john 1badSTI is offline   Reply With Quote
Old 03-24-2009, 10:32 PM   #10
twigg107
Member#: 119718
2008 STI
sense when does the odometer monitor how long the motor has been on?
twigg107 is offline   Reply With Quote
Old 03-24-2009, 10:58 PM   #11
checque
Member#: 68562
RIP Edwin
If you look hard enough I'm sure you'll find some documentation about how to break in your cigarette lighter. I drive my fresh built motors and trans like I drive at Bondurant. Call me lucky or crazy, but I believe in advances in technology.
checque is offline   Reply With Quote
Old 03-24-2009, 11:35 PM   #12
kellygnsd
Member#: 32669
LINK G4 hybrid STi
It doesn't but at least you know the engine has been run at the factory and driven and possible idled for a bit at the appropriate rpm for cam break-in. Probably a stretch but one can dream can't I
What does it mean to be a "Shriner"? Shrine, something along those lines? plunk10 Off-Topic 28 11-27-2009 08:14 PM
What does it mean to be a "good snow driver"? skimmilk68 Off-Topic 145 12-04-2008 10:22 AM
piston slap: and what does it mean to you? WRXwannbe Normally Aspirated Powertrain 16 02-02-2006 05:48 PM
What does it mean to be a Road Scholar? boysetsfire Off-Topic 17 05-19-2003 06:31 AM
What does it mean to run rich? DoctorNick Newbies & FAQs 14 07-23-2001 07:14 PM
