#1 |
Vendor Sales Rating: (192)
Member#: 136396
Vehicle:2012 wrx white |
http://www.grimmspeed.com/catalog/pr...roducts_id=121
An External Wastegate (EWG) allows exhaust gases to be diverted prior to entering the turbo; thus creating a quicker turbo spool. GrimmSpeed’s EWG has a larger diameter than the stock internal wastegate; this allows the exhaust gas to be released faster, which improves boost control, maintains maximum boost longer in the rpm range, and extends the life of the turbo. Moving the wastegate out of the turbo relieves the turbo from the massive amounts of turbulence that the stock internal wastegate creates. The EWG Up-Pipe is built from 304 SS with thick 13mm 304 SS flanges. A flex section has been added; this will extend the life of the product(allows expansion/contraction of pipe without cracking) and will lead to less exhaust leaks. Users should expect gains in the 15-40hp range when tuned for the EWG set-up. Also included in the EWG Up-Pipe package, a bracket to hold the stock internal wastegate shut. This bracket is helpful because the turbo door does not need to be welded shut, decreasing the chance for leaks and allowing for easy removal if necessary. The GrimmSpeed EWG Up-Pipe Kit fits more downpipes than any other EWG Up-Pipe on the market. Quick Facts:
![]() ![]() ![]() New Tial 38mm V-Band compared to current Tial 44mm V-Band. ![]() IWG Block-Off Bracket Options: TD04 VF Series FP 20G DB 20/18G FP 3" Inlet Green/Red Turbochargers.com 18G Price: 319.99 http://www.grimmspeed.com/catalog/pr...roducts_id=121
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. MSN (IM Only): To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. AIM: GrimmSpd Phone: 612-379-0000 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "I am very pleased with the manifold, crosspipe, and uppipe. All I can say is wow!!, The quality of the products greatly exceeded my expectations. I will be ordering more of your products in the future.Thanks again. John" Last edited by GrimmSpeed; 03-24-2009 at 12:01 PM. |
#2 |
Member Sales Rating: (417)
Member#: 170349
SCIC
Vehicle:2020 STy, too many.. WR Blue w/ carbon bits |
could u pm me letting me know what pipe is most suitable for me?
i want an ewg, but the pipe that lets out the gasses, i've been hearing that people are having problems with certain pipes due to where the exhaust gasses are let out it is melting certain parts. i'm looking for an external wastegate kit that will blow all the gasses directly to somewhere like the ground or an open area so it won't have a chance at melting anything lol. lemme know. |
#3 | |
Member#: 136396
Pm'd Mike
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. MSN (IM Only): To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. AIM: GrimmSpd Phone: 612-379-0000 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "I am very pleased with the manifold, crosspipe, and uppipe. All I can say is wow!!, The quality of the products greatly exceeded my expectations. I will be ordering more of your products in the future.Thanks again. John" |
#4 |
Member Sales Rating: (34)
Member#: 93248
Vehicle:95 20g powered gc8 PPG'd yO! & is250 AWD |
sick ass setup.. i have the non v band version and its been amazing for my setup! +1 for grimmspeed. thanks again justin!
#5 |
Member#: 136396
__________________
#6 |
Member#: 136396
Just started the Nasioc group buy on these!
http://forums.nasioc.com/forums/show....php?t=1785577 Get them at a super low price before it's too late!! Mike
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. MSN (IM Only): To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. AIM: GrimmSpd Phone: 612-379-0000 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "I am very pleased with the manifold, crosspipe, and uppipe. All I can say is wow!!, The quality of the products greatly exceeded my expectations. I will be ordering more of your products in the future.Thanks again. John" Last edited by GrimmSpeed; 06-17-2009 at 05:38 PM. |
#7 |
Member Sales Rating: (3)
Member#: 83514
Vehicle:2006 tr blue |
Hey guys! not sure if this is the right place for this, But, thanks for the factory seconds crosspipe its looks amazing! Can't wait to get it on the car!! Your products look top-notch and I'm sure will perform as well. You have got yourself a repeat customer! thanks, Andrew Williams
#8 | |
Member#: 136396
Let us know if you need anything from us down the line. Mike
__________________
#9 |
Member#: 136396
__________________
| Thread Tools | |
| Display Modes | |
| Grimmspeed 38mm V-Band EWG pipe kit WITH Tial wastegate | wrxgeo | Engine/Power/Exhaust | 22 | 12-14-2009 01:26 AM |
| FS PA: GrimmSpeed EWG Up Pipe w/ 38mm V-Band EWG | Kjott21 | MAIC Private Classifieds | 8 | 10-12-2009 05:50 PM |
| FS PA: GrimmSpeed EWG Up Pipe w/ 38mm V-Band EWG | Kjott21 | Engine/Power/Exhaust | 4 | 10-12-2009 05:50 PM |
| Need help w/ running lines.Grimmspeed ebcs -to- tial 38mm v-band ewg. | obsti2 | Factory 2.0L Turbo Powertrain | 2 | 04-29-2009 08:50 PM |
