Old 04-13-2002, 04:58 PM   #1
20mm
Member#: 11607
2004 Impreza WRX STi
Platinum Silver Metallic
Question Heat Shielding?
Ok I could probably find the answer to this question easily if the search function was working but since it isn't and I'm going to the shop this afternoon I need to ask this now
Will removing the factory heat shielding under the car cause any serious problems? I'm sure someone has probably done this. I need to remove the heat shielding because I'm almost certain its causing the metallic pinging I hear when I accelerate briskly. I've got brullen headers/high flow cat, a custom 2.25" midpipe, and an mrt muffler. I keep getting a really annoying metallic sound when I accelerate and its pissing me off, sounds stupid. Ok so problems with removing the heat shielding? Thanks guys.
-Chad
20mm is offline   Reply With Quote
Old 04-13-2002, 07:07 PM   #2
bln scub
Member#: 9497
2001 Legacy L Wagon
blue sapphire
Default ping ping
so i assume its notthe motor pinging?
bln scub is offline   Reply With Quote
Old 04-13-2002, 09:59 PM   #3
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Ping.. Pinga.. BOOM!
You might wanna make sure its not your engine detonating.
I guess what I really want to say is, Is the sound more of a clang then or rattle?
Revision is offline   Reply With Quote
Old 04-13-2002, 11:34 PM   #4
20mm
Member#: 11607
Its a rattle. Cant be detonation, its been going on for over a month, engine would have exploded by now I took the shielding off today and the noise went away, now I have a mean exhaust, not annoying
-Chad.
Old 04-14-2002, 12:15 AM   #5
Jademonkey
Member#: 9213
2000 RS
Red
I had the same problem... make sure there aren't any pebbles stuck between the cat and the cat shielding...
Jademonkey is offline   Reply With Quote
Old 04-14-2002, 09:47 AM   #6
Jayson_K
Member#: 11663
02 RS
platinum silver
hmmm sounded like little rocks hitting the underside? I had that last night, never bothered to look though.
Jayson_K is offline   Reply With Quote
Where to have an intake heatshield made in SoCal?? AM55 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-01-2010 01:48 AM
FS: (IL) TDO4, Spt Turbo Heat Shield matt107 MWSOC Private Classifieds 8 06-10-2010 12:36 AM
FS : (IL) Spt Turbo Heat shield matt107 Engine/Power/Exhaust 5 06-08-2010 01:43 PM
WRX Up pipe, stock heat shields, COBB heat shield... racerX_244 Engine/Power/Exhaust 5 06-02-2008 09:18 AM
Factory 03 up pipe. 2 Factory heat shields and mic factory heat shielding. 03twrx Private 'For Sale' Classifieds 8 07-27-2006 07:19 PM
