Old 03-24-2009, 06:08 PM   #1
binkman88
Member#: 134093
Unhappy mpg bad what to change?
hitting 82xxx 05 RS and have noticed bad mileage for a bit. I changed the plugs but not the wires and got about 75-100 more miles per fill up. What should be next? Im going to get wires for it but dont know where to get them autozone? advanced? This hopefully makes a big difference or else im out of ideas. Anyone else have any info?
binkman88 is offline   Reply With Quote
Old 03-24-2009, 06:21 PM   #2
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
-How are you calculating MPG? (miles per take is not very accurate. Fill up the tank, reset the trip, next time you get gas, fill it up and record the gallons you put in and the mileage on your trip, then divide)
-What numbers are you getting?
-I have 82K on my 01 OBS and get between in the mid to high 20s.
-Are you a lead foot?
-Tires all properly inflated? ( I run a pound or two over what the door jamb says)
-When was the last time the car was tuned up? (air filter, fuel filter, etc)
jetfan2207 is offline   Reply With Quote
Old 03-24-2009, 06:23 PM   #3
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Fuel filter, air filter, check your tire pressure. Any check engine light?
Malfunctioning o2 sensors can sometimes cause poor mileage without throwing codes.
Winter gas is ethanol blend (10% or more in most states, to combat pollution) and will cause a decrease in mileage. I forget when it's usually changed, but a lot more states are running ethanol blends year-round, and without being tuned for it, it decreases mileage. The amount of power (specific something...?) in ethanol is lower than normal gasoline, so you have to burn more of the liquid to get the same power output. A lot of turbo guys who go to ethanol have to run substantially bigger injectors to get the same output.
Cold weather generally lowers mileage if you're making lots of short trips, as these cars run extremely rich when they're cold/warming up.
These cars are not econoboxes per se, AWD eats up some efficiency, as does an automatic transmission (not sure if you're 5MT or 4EAT).
Aaron
fastenova is offline   Reply With Quote
Old 03-24-2009, 06:41 PM   #4
binkman88
Member#: 134093
im getting around 290 per fill up on regular. Im a lead foot here and there but whether i am or not I still get the same mileage. Fuel filter is in the tank on this car is it not? I might have to check that out and im running a aem intake and no CELS for me
5spd manual.
Old 03-24-2009, 06:54 PM   #5
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
The fuel filter is not inside of the tank. It should be under the hood. I believe mine is to the right of the air filter if you are standing at the front of the car. 290 miles isn't THAT bad, that's over 18MPG if you are totally running the tank dry (assuming you have a 16gal. tank). But try calculating it the right way and see what you get.
Old 03-24-2009, 07:35 PM   #6
iluvdrt
Member#: 46248
82 Brat
Tan
clogged cats can kill MPG, and O2 sensors. 80xxx miles, it wouldnt be a bad idea to change the sensors. Coolant temp sensor too I have seen cause bad MPG's.
iluvdrt is offline   Reply With Quote
Old 03-24-2009, 07:35 PM   #7
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
the "correct way" is also the long way. It takes about a week depending on how much you drive but it will yeild a much more accurate answer. The wires are probably the next easiest thing to help get your Mpgs up there.
Not to thread jack, but is my fuel filter under he hood too?
98 legacy 2.5 gt
gunny11218 is offline   Reply With Quote
Old 03-25-2009, 12:05 AM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
yes, 98 legacy fuel filter is under hood, near driver side suspension tower. Get OEM wires from dealer or from Subie Gal, I forget the website. Have you been following regular maintenance? Mods?
Old 03-25-2009, 02:39 AM   #9
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
try calculating MPG vs mileage per fill up I think it is more accurate that way. Also, where are you located? there are 9 million things to affect gas millage. you have to average out your numbers over a longer period of time. It could simply be the gas you are using.. especially if it is a winter blend. On a side note, thats a ton of mileage on an 05. I just sold mine with about 42K.. are you up to date on your maintenance? Ever had the differential fluid changed? That could be a big one for MPG.
Audi20Tdriver is offline   Reply With Quote
Old 03-25-2009, 02:43 AM   #10
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
5spd manual.
Not sure about RS but in my 05 WRX, filter IS in the tank. I was told it doesn't need to be changed but I'm not sure. Dealer part only too.
trueno16v is offline   Reply With Quote
Old 03-25-2009, 11:53 AM   #11
eh1525
Member#: 116619
2005 Impreza RS
Crystal Grey
Almost 100% it is in tank. I have been under my hood alot and have seen nothing that looks like a fuel filter.
eh1525 is offline   Reply With Quote
Old 03-25-2009, 05:01 PM   #12
binkman88
Member#: 134093
yea im pretty sure its in the tank, but ill do wires, then go from there and let you guys know and how would I change the coolant temp gauge wheres it located?
Emmisions coming up, opinions on what to change? (MO) dogfrndnew Mid West Subaru Owners Club Forum -- MWSOC 6 03-17-2006 07:52 PM
What to change to increase redline? blaznc Normally Aspirated with bolt-on Forced Induction Powertrain 12 05-06-2005 02:56 PM
Hit 24000KM what to change SpoonTypeR Service & Maintenance 2 02-05-2004 02:23 AM
Center differential bad- what to do? PRODRIVEN Transmission (AT/MT) & Driveline 12 11-14-2002 03:44 PM
Is it bad to change the engine oil and automatic transmission oil at 2-3000km?? V6 Normally Aspirated Powertrain 1 10-27-2000 10:08 AM
