Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 03-24-2009, 05:47 PM   #1
meola23
Member#: 144384
2004 wrx sedan
wr blue
Default leak?
i figured this thread would be best for this.
i just attempted to install the aps turbo inlet on my 04 wrx
which requires you to remove the intake manifold
after doing so and fitting the inlet under the manifold tightening everything up
it seemed like i had a leak
so i had replaced the gaskets the next day
i go through this process again it sounds a little better
but seems to be some sort of leak and my power steering is now shot
i can assure my self that i have done every single little thing correctly aside from maybe not tightening the intake manifold enough or something
after all that i reinstalled the old turbo inlet and i am still where i was left off
sounds like theres a leak
and no power steering
meola23 is offline   Reply With Quote
Old 03-24-2009, 05:51 PM   #2
SYBugeye
Member#: 200805
03 WRX
Sonic Yellow
did you take the power steering lines off, if so you might have gotten air into the system as far as the leak goes just make sure you tighten everything down again and make sure you put everything back like before you took it off
SYBugeye is offline   Reply With Quote
Fuel leak / vacuum leak mmm3587 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-01-2004 08:38 AM
coolant leak, but without the leak iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-30-2003 12:30 AM
leak or no leak..that is the question polobee69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-31-2003 08:29 PM
leak or no leak? blaznasn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-14-2002 07:56 AM
First it's radiator leaking, then clutch master cylinder resorvoir leaking, and then. davidm_sh Warranty Issues & SOA Problems 1 03-24-2002 01:43 AM
