Old 03-24-2009, 06:37 PM   #1
r0n
Member#: 91839
Default HG question
got a quick question guys.. mods list below
04 wrx
2.5 block
cp 100 MM pistons
V7 heads
fpred
etc etc
Should I use a 100 Mm cosmetic HG?
r0n is offline   Reply With Quote
Old 03-24-2009, 07:31 PM   #2
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
I used OEM head gaskets for my 100mm bore.
AKSubieDubie is offline   Reply With Quote
Old 03-24-2009, 08:19 PM   #3
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I'm using OEM as well with 99.75mm pistons.
alcoolaid is offline   Reply With Quote
Old 03-25-2009, 01:15 AM   #4
Maxwell Power
Member#: 190729
I'd use the 040 cometics to lower your compression.
I hate using headgaskets to lower compression, but you have an fpred on there and that's going to put you closer to your limits. Get that compression down by having someone modify and cc the chambers or use the 040 cometics.
Maxwell Power is offline   Reply With Quote
Old 03-25-2009, 01:15 AM   #5
Maxwell Power
Member#: 190729
Old 03-25-2009, 09:34 PM   #6
r0n
Member#: 91839
ok thanks guys
Hg question... AK_HMK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-27-2009 09:09 PM
Some blown HG questions CKxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-01-2009 07:09 PM
EJ25 HG Questions... Experts needed! fastenova Normally Aspirated Powertrain 16 09-02-2006 05:00 PM
HG Question Zynski10 Forester Forum 0 03-17-2005 10:59 PM
Tein HG questions William LaPalme Brakes, Steering & Suspension 0 06-22-2002 08:12 PM
