Old 04-02-2009, 10:10 AM   #26
dalehatestheriaa
Member#: 170616
2006 Impreza WRX
Red
pull the code. i think autozone / pep boys do this for free!!
if not you can by a crap scanner that just gives you the code for 20 bucks, then just google the code or post it here.
Also check your wire's? they make tests for these. A compression test will tell if its the engine itself or something else.
The injectors might be dirty, the gas might be bad.
Reset the ECU also.
dalehatestheriaa is offline   Reply With Quote
Old 04-02-2009, 10:12 PM   #27
Lemanschamp
Member#: 114741
1999 Outback
Flat Black
Clearing a CEL on an OBDII vehicle isn't the whole issue. Once that's been done, what you've more or less done is hit the reset button. The car needs to relearn alot of things, like basically what to expect with your driving habits. The computer looks at each systems monitor (drive cycle monitor, readiness moniter, yadda yadda) and checks out if everything involved with that system is normal. Now the trick is, there are some interesting criteria for the computer to even run a test on a given system. For example, for the computer to test the EGR monitor, the car must be travelling at ~60 and decelerate to ~30 WITHOUT downshifting or braking. O2 monitors are run 5 minutes after the car is shut off IF the driving that preceded the shutoff met it's own criteria.
That's why some people bitch about how it can take forever for a car to be inspected, because sometimes you have to jump through alot of hoops to have the computer merely run each test.
Oh, and if the CEL is blinking, for the love of god pull over and shut the car down as safely and quickly as possible. It takes alot to make that thing blink. It's kinda like the oil pressure warning light, when it goes on at like 4 psi. By the time you see it, it's kinda too late to avoid some harm.
Lemanschamp is offline   Reply With Quote
Old 04-03-2009, 12:01 AM   #28
Baja820
Member#: 196860
Could it be a cam sensor or bad O2 sensor?
Baja820 is online now   Reply With Quote
Old 04-03-2009, 01:02 AM   #29
tomthedancinghobo
Member#: 207473
Default Checked the timing?
I know it sounds dumb... but could it be a timing issue?
tomthedancinghobo is offline   Reply With Quote
Old 04-03-2009, 01:10 AM   #30
Baja820
Member#: 196860
how would the timing be off?...... bad timing belt?
Old 04-03-2009, 08:24 AM   #31
Lemanschamp
Member#: 114741
1999 Outback
Flat Black
Im not gonna start guessing at least until we see what code it is!
Old 04-03-2009, 09:34 AM   #32
Baja820
Member#: 196860
Fair enough..... Ill try to get over to auto zone after work.....
Old 04-04-2009, 12:40 AM   #33
Benaiah
Member#: 207502
98 impreza l
green
sometimes, if i take right off in my 98 impreza 2.2 without letting it warm up, and then try to accelerate quickly from a stop, the same thing happens; blinking light and gutless sputtering. however, if i just let off the gas a little, it will drive normally. after about a minute of the motor running, the car drives normally regardless of how i drive it. im ashamed to say ive never taken the time to check the code, and the girl could really use a tune-up.
Benaiah is offline   Reply With Quote
Old 04-05-2009, 11:12 PM   #34
Baja820
Member#: 196860
so it runs perfect until it warms up!...... gotta be the o2 sensor right?!?
Old 04-15-2009, 12:02 AM   #35
Baja820
Member#: 196860
Ok so I finally got my codes read...... P0106 & P0130. bad o2 sensor! not sure about the other one
Old 04-15-2009, 02:08 AM   #36
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
MAP sensor and O2 Sensor errors.
If either one of those is malfunctioning, there's a decent chance the other one will look like it's malfunctioning due to how the ECU calculates fueling in your car. The ECU won't know which one to believe. Replace the O2 sensor and see if the problem goes away. If the problem continues, replace the MAP sensor.
Old 04-15-2009, 09:36 AM   #37
Baja820
Member#: 196860
^^^Cool .... thanks for the info
Check engine light blinking!?! Chonojake Factory 2.0L Turbo Powertrain 30 03-11-2006 09:06 PM
check engine light blinking jimball21 Tri-State Area Forum 20 01-25-2005 12:31 AM
Check engine light blinking!!! rageatm007 Electrical & Lighting 5 07-26-2004 07:54 AM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 5 08-26-2003 09:08 PM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 2 08-26-2003 08:59 PM
Message Board Statistics All times are GMT -4. The time now is 06:37 PM.
