Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 03-24-2009, 11:42 PM   #1
MNsuby
Member#: 186530
02 Bugeye
MBP
Default I need help with my header
WHAT Is the horrible vibration from?????
ok so today i installed a borla replica header
it sounds odd.. i dont know if its because it needs to be broken in or what
but, there is a wierd vibration and it sounds like a bad leak
the leak also sounds raspy.. so if i heat wrapped them would that raspiness and vibration go away/...
someone help
OR is it pulsing on the tubing because its so thin? heat wrap will get rid of the pulsing right?
MNsuby is offline   Reply With Quote
Old 03-25-2009, 01:24 AM   #2
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
duuuuuude, if it sounds like a leak, likely it is a leak. There is a big difference between a leak and oter sounds.. check your fitments. My borla replicas were pretty thin as are almost any aftermarket header. they did make a noise but it was more a of a ticking sound from the pulses. Wrapping the headers will remove the clicky pulse they make outside the car; however, in your location you really need to be careful as the wetness and salt combined with the wrap will either deteriorate those very quickly, crack them or both depending upon your exposure. Arizona was a good location for me to wrap them.. no moisture or salt.. and it would have helped performance wise and the exhaust flow temps are higher and it helps the scavenging effect. Maybe look into having them coated with jet hot or something like that vs wrapped.
hope that helps
Audi20Tdriver is offline   Reply With Quote
Old 03-25-2009, 01:28 AM   #3
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
PS.. when I threw those on the RS.. I got different gaskets then the ones it came with. If you are leaking at your gaskets, get OEM ones and use those with the OEM bolts for the replicas.. same with the connection to your cat.
Old 03-25-2009, 01:30 AM   #4
MNsuby
Member#: 186530
02 Bugeye
MBP
ya it sounds more ticky than a leak.. its kind of annoying
if they crack i know a guy that will weld them lol
im gonna drive it for while and see what happeneds
i think maybe they just need to be broken in for while
Old 03-25-2009, 01:32 AM   #5
MNsuby
Member#: 186530
02 Bugeye
MBP
and yes i bought all new gaskets. the guy that helped me is an exhaust guy and he made sure there would be no leaks.
so what im thinking is that its just the pulseing/ticking sound.
Old 03-25-2009, 01:45 AM   #6
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
it is a bit annoying.. but it sounds 150% better warmed up. it's night and day but that tick never goes away. the corrosion from the wrap would be beyond and easy fix weld crack but it would fix the tick.. again.. look into getting them coated.. maybe wrap it then coat that.
Old 03-25-2009, 01:47 AM   #7
MNsuby
Member#: 186530
02 Bugeye
MBP
thermal coated? jet hot
what kind of coating you reccomend
Old 03-25-2009, 03:01 AM   #8
Hites
Member#: 138997
0000 Nothing
That's just how they sound. At least on the singleports, they are.
Hites is offline   Reply With Quote
Old 03-26-2009, 02:30 AM   #9
MNsuby
Member#: 186530
02 Bugeye
MBP
bump.. i need help with the vibration. it sounds like its coming from header and where it bolts to cat
ahhhh!
Old 03-26-2009, 06:57 AM   #10
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
its prolly all the useless heat shields from under your car, since you put on the borla headers there is ALOT more vibration going on and i know it made mine sound like ass until i ripped them all off, also if you changed your catback i know the borla reps sat on mine just alittle off from the stock headers and it made my catback sit up against the rear driveshaft gaurd, its a big heavy metal piece so i ripped it off(i figure i saved some weight too=])
smithrcing17 is offline   Reply With Quote
Old 03-26-2009, 01:12 PM   #11
MNsuby
Member#: 186530
02 Bugeye
MBP
alright ill check that out today thanks smith
Old 03-26-2009, 05:24 PM   #12
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
np man, hopefully that fixes it, if you watch my vid you will hear what i mean by it sitting up against my driveshaft gaurd, (its at the end of the vid)
http://www.youtube.com/watch?v=_GQ7UgTYc1M
Old 03-26-2009, 11:29 PM   #13
MNsuby
Member#: 186530
02 Bugeye
MBP
ahh thanks for the vid.. im gonna work on it tonight
Old 03-27-2009, 02:26 AM   #14
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Question
I just a week ago put full exhaust on my 2.5i, borla header, stromung high flow cat, apexi n1 catback. And from the outside of the car it sounds good, but on the inside i hear the same thing, and i thought that it sounds like it was coming from the header or where the header bolts onto the cat pipe. So i got a torque wrench cranked it up a lil higher and tightened every bolt until my lil arms couldnt crank anymore. I know there is no exhaust leak, and the thing is it only makes the sound under 3000 rpms and once i drive it for about 15 to 20 mins it goes away....... i think it may just be my new headers breaking in and still being cold when i start it, i dont know...
07ImprezaMB is offline   Reply With Quote
Old 03-27-2009, 02:58 AM   #15
rougeben83
Member#: 115154
2005 Outback XT
White on grey
check for any heatshield near the exhaust pipes. This is especially true if youre getting an RPM specific rattling.
I never got any rattling on the 2 sets of headers and exhaust that I had on mine.
rougeben83 is offline   Reply With Quote
Old 03-27-2009, 10:31 PM   #16
MNsuby
Member#: 186530
02 Bugeye
MBP
ya it was the huge heatshield above where header connects to cat
thanks for al the help guys
I need some assistance, need help with my build Harnicka Built Motor Discussion 9 09-08-2009 01:58 PM
Need help with my hoses! Need a tech Please darkcrave Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-17-2009 03:06 PM
Need help with my 32 Mods for my 32'nd birthday effort Koji North West Impreza Club Forum -- NWIC 9 09-08-2008 07:46 PM
I need help with my 02 Wagon Suspension! Hate my Teins natoli4 Brakes, Steering & Suspension 50 03-23-2006 08:21 PM
I need Help with my install! HELP! mrubino83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2004 01:11 AM
