Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 03-25-2009, 03:05 AM   #1
hansj3
Member#: 192571
Default whats the best junkyard hybrid?
i have a 93 Impreza with the dual port 1.8 that is starting to get tired. It has no torque... Less than normal 1.8 until 3k. It has 270 thousand miles and compression is down between 130 and 135. I know the spread is still in check but its low. I want to put something in there that would be worth the swap. but i am also cheap and don't want to spend much if any on tuning. there are a couple of 2.2s and first gen 2.5s out in the local u pull. i guess what i am tring to ask is out of those block combos what would net me a decent boost in power, be easy on gas and run pump gas and still kinda work with the stock injectors/ecu
hansj3 is offline   Reply With Quote
Old 03-25-2009, 08:28 AM   #2
98 OBS for me
Member#: 200575
1998 Impreza OBS
I'm not 100% sure, but I think your stock injectors and ECU just won't work with a 2.2 or 2.5.
I can tell you though that between a first gen 2.5 and a 2.2, I'd get the 2.2. The early 2.5's had a lot of headgasket issues that the 2.2 just didn't have. Neither motor will accept a hell of a lot for mods, but both can have some small stuff like intake and exhaust with no problems. I would suggest swaping in a 2.2 purely because it's a more reliable motor.
98 OBS for me is offline   Reply With Quote
Old 03-25-2009, 10:01 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Those who don't know, should not guess. You can use your Ej18 ECU and wiring to run either an Ej22 or an Ej25. The problem with junkyard Ej25's is that many of them need to be gone through. Finding an Ej22 that you trust is easier. And if you go that route you don't need to fiddle with any sensors or components. You just bolt your intake manifold to the EJ22 engine and go. Just make sure you get a dual port Ej22 and you don't have to change anything.
Old 03-26-2009, 01:19 AM   #4
hansj3
Member#: 192571
I went and looked today and i couldn't find any dual port ej22's. is it possible to put the ej18 heads on, or am i better off working over a ej25. I am not really going for the power... too much more might be too torquey for the 2wd. i have also heard that if you get a decent 2.5 head gasket the problems would go away
Old 03-26-2009, 02:20 AM   #5
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Just pull the exhaust manifold along with a singleport 2.2 (which will be newer and make more power anyway) and otherwise do what Matt suggested.
BAN SUVS is offline   Reply With Quote
Whats the Best and Worst day of the week for the common OT folk? brucelee Off-Topic 21 06-23-2008 07:25 PM
Whats the Best Tuning Shop for the WRX in the NYC Area? WRXWAGON04NYC General Community 3 10-03-2004 11:44 AM
So whats the best FMIC for the VF23? codean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-18-2002 12:08 AM
what the best suffolk county shop with the best prices sochico Tri-State Area Forum 2 06-11-2002 06:00 PM
Whats the best carwash in the area? ChannelZ28 Tri-State Area Forum 0 06-20-2001 01:23 PM
