Notices
Old 03-25-2009, 03:21 PM   #1
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Default 4EAT - Where did you weld your bung for wb02 sensor?
I just got my LC-1 today, and I'm looking for a good spot to weld the bung.
Unfortunately, the 4EAT is quite a bit larger than the 5MT and there is little space to place the bung.
I don't know how to weld myself, and I don't know anyone else who does, so I went to the exhaust shop and they told me that they couldn't do it because they did not want to risk damaging the cat if they made a hole a little before or after the front O2.
I asked if they could weld a hole right before the gasket in the header and they said they couldn't do it from a 10-2 o'clock (recommended spot to put wb02 according to the manual) because they didn't want to risk damage to the header or engine.
I was looking for a spot and everything looks very tight in terms of space, but I'm sure there's a way I could get a wbO2 on right next to the front O2.
Any suggestions?
formula91 is offline   Reply With Quote
Old 03-25-2009, 07:11 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
get the car off the ground... open the hood to get some light in there... get under the car and find a spot between 10/2 o'clock and measure to make sure there is room to install/remove the sensor, not just enough room for it to be in the pipe. The closer to the cat the better. On a stock 05 system, i think you might be able to fit it in right at the 90 degree bend before the cat. I put mine there, but it was also an aftermarket cat pipe and I have 5MT. The factory heat shield will have to be modified if you want to reuse it obviously. the best part is that i can remove/reinstall the WBO2 sensor through the hood, instead of having to raise the car every time I want to recalibrate. that is definitely something to consider
Old 03-25-2009, 07:41 PM   #3
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I remember reading your supplementary guide for installation. It was really helpful, but I can't do squat if I can't find a spot.
I might just ditch the heat shield, is that bad?
Old 03-26-2009, 01:47 AM   #4
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
Mine is on a 90 degree bend before the cat. I just ditched part of the heat sheild, haven't had any problems also I welded it down so it wouldn't rattle. Make sure you get it before the cat so you will get a proper reading.
2.5i is offline   Reply With Quote
Old 03-27-2009, 12:11 AM   #5
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Of course, thanks for the help.
The exhaust shop thought the whole front section was a cat. Obviously not!
-edit--
But you are an 06, I thought the exhaust system completely changed after 05.
I'm not sure if the cat sections are the same.
Old 03-27-2009, 12:41 AM   #6
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Did anyone ever play with an O2 sensor extension with a wideband just to see if it gets a different reading? I was always curious how that would change a wideband's readings like it "fools" O2 sensors on trackpipes.
HamFist is offline   Reply With Quote
Old 03-27-2009, 01:37 AM   #7
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I thought wb02 sensors couldn't be connected to the ECU because of some wacky polynomial no one figured out yet.
Old 03-28-2009, 01:39 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
potentially yes.. i would at least try to modify the heat shield to protect your CV boot on that side. At the least, cut out just enough to make the O2 sensor fit.
-edit--
yes, after 05 they completely changed design/route before the midpipe. maybe he is referring to an aftermarket setup he has.
Old 03-28-2009, 08:33 PM   #9
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
If anything I'll just put them on the headers if everything else fails.
But I hate getting new gaskets. Blah.
where did you get your HIDS from for 06-07 wrx gindobuck Electrical & Lighting 4 03-23-2009 11:46 PM
Greddy. Where did you put your sensor? Dexter Interior & Exterior Modification 0 09-30-2002 04:22 PM
How/Where did you install your suspension? SK00Impreza North West Impreza Club Forum -- NWIC 6 04-07-2001 06:58 PM
S-AFC Where did you mount yours tmaler13 Technical Forum Archive 1 09-02-2000 10:54 AM
KC- where did you get your tires? price? Fitz New England Impreza Club Forum -- NESIC 19 08-01-2000 12:46 AM
