Old 03-25-2009, 05:06 PM   #1
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Default Need Your Help Sti V8 Problem!!!!
Hi ALL!!!!
I just completed a 2002 WRX AUTOMATIC conversion to STI V8 JDM engine and transmission.
THis is the the problem I have.
Whe the car is cold It will start and idle A ok.After driving it to a first stop sign when I stop the car idles BAD like it runs on 2-3 cyl. only.When I start to drive it from the stop light and go I can feel the car is hasitating and it is rough.
Once the car worms up it is LITTLE diferent.
Once I pul up to the light the car rpm will drop like they supose to and it will iddle rough BUT after 5-6 second the ecu will corect it and the car will iddle ok.
NOW if i take of the light hard and put the car -1-2-3 gear all the way to the red line there is this hasitation 6800-8000 RPM like there is bad timing,Not enough fuel or just no proper spark IT HAS A LACK OF POWER THAT YOU CAN FEEL IT!!!ALSO WHEN IM PULING FROM THE RED LIGHT BEFORE I PUT IT THROUGH 8000 RPM IT FEELS HESITANT AND WEAK.!!!!
NOW WHAT IS INTERESTING IF I TURN OF THE CAR AT THE RED LIGHT AND TURN IT BAKC ON, AND THE PUT IT THROUGH 1-2-3- ALL THE WAY TO 8000 RPM THE IT SEEMS LIKE NEW CAR NO HESITATION FROM STARTLINE AND NO PROBLEM IN TH 6800-8000 RPM range.
BUT AS SOON AS I PULL UP TO THE RED LIGHT THE SAME THING HAPPENS RUNS ROUGH CORECT IT SELF IN 5-6 SECONDS AND THE CAR RUNS LIKE *&*&^% AS DESCRIBED ABOWE.
As many local GURUS I ask I get as many answers.
1.fuel pump old
2. vacum leak
3.spark plugs adjusted incorectly
and so on.
PLEASE HELP!!!
Thank you in ADVANCE
MARKSTIV8 is offline   Reply With Quote
Old 03-25-2009, 06:01 PM   #2
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
Sounds an awful lot like the symptoms of a dirty maf (not sure if your year has one, but if you do, clean it).
rockcrete is offline   Reply With Quote
Old 03-25-2009, 07:05 PM   #3
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Yes I have the MAF just like wrx 02-and on.
What is the best way to clean it???
Old 03-25-2009, 07:32 PM   #4
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
take it off and give it a good spray of brake cleaner or electric contact cleaner...........
Old 03-26-2009, 10:57 AM   #5
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Well I did clean the MAF sensor and it didnt help.
Any other sugestions?
Old 03-26-2009, 12:14 PM   #6
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
Takew the rest of your brake cleaner and spray it around your hose/turbo/intercooler connections with the engine idling and see if it changes your idle at all (this will find vaccuum leaks).
Old 03-30-2009, 04:17 PM   #7
MARKSTIV8
Member#: 206393
2008 STI
BLUE
well I did the break cleaner thing with vacum leaks and every thing seems to be ok.The problem is stil there.
Can this be coused to a bad ground?As we replaced the whole wireing harnes behind the dash as this was a automatic before?
What do you think???
Old 05-04-2009, 08:17 PM   #8
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Ok
All If you do the swap like my and have same symptoms or simillar
The first think you want to check IS HAW DID YOU (OR SOMEONE WHO WIRED YOUR AVCS) DID THE JOB!!!!!
IN MY CASE IT TURNS OUT THE GAY WHO DID THE WIREING SWITHED THE 2 CABLES THE ONE FROM LEFT SIDE AVCS WAS IN PLACE OF THE RIGHT ONE AND VICEWERSA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Good luck to you all on your CURENT AND FUTURE PROJECTS!!!
Mark
Old 05-05-2009, 03:08 PM   #9
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
wow...
elislider is offline   Reply With Quote
Old 05-05-2009, 03:12 PM   #10
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
lol someone sounds mad XD
Rei_Akira is offline   Reply With Quote
I need your help diagnosing this noise/problem Six Stars Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-21-2007 10:23 AM
com port problems, need your help!! 2gnt2wrx AccessPort 1 10-13-2006 06:40 PM
problem with utec need your help dlowman UTEC 6 04-04-2006 09:18 PM
OT need your help with lower back problems RSimport Off-Topic 19 09-18-2005 11:03 PM
O2 sensor problem. I need your help please... jlee81 Engine Management & Tuning 8 03-29-2005 10:00 PM
