Old 03-25-2009, 08:19 PM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default Double-D Series head ports!!!
USDM heads with the Double-D treatment. This is some porting I've been doing. You can follow along and make your heads flow well too! All the details are in the pictures! I have some flow numbers throughout the thread of some findings. I also have pictures of other heads I've worked on for a few friends.
These are my personal heads I've been working on. A set of '06 WRX D25 heads with my fancy "Double-D" porting. Basically it resembles the JDM Ver8 big port heads in the intake port runners. The JDM heads flow very well so might as well duplicate them!!!
'06 EJ255
Valve lifts are measured with STi cams fitted and rotated for measurement. Dial gauge was measured at an angle so actual lift points are actually a tad shorter than what they really are.
Stock '06 EJ255 heads
Intake:
.100" = 86cfm
.200" = 177cfm
.300" = 237cfm
.397" = 253cfm
Exhaust (straight)
.100" = 72cfm
.200" = 145cfm
.300" = 185cfm
.398" = 203cfm
Exhaust (dog leg)
.100" = 72cfm
.200" = 142cfm
.300" = 180cfm
.400" = 192cfm
New numbers with a 5angle valve job with blending afterward. A bit more work on the exhaust ports especially the dog leg to bring out some more CFM.
Intake:
.100" = 90cfm
.200" = 185cfm
.300" = 251cfm
.390" = 283cfm
Exhaust (straight)
.100" = 84cfm
.200" = 165cfm
.300" = 208cfm
.400" = 225cfm
Exhaust (dog leg)
.100" = 90cfm
.200" = 164cfm
.300" = 206cfm
.400" = 220cfm
Stock valves, no valve job. [email protected]"
Intake:
.100" = 87cfm
.200" = 177cfm
.300" = 254cfm
.398" = 283cfm
Exhaust (straight)
.100" = 81cfm
.200" = 160cfm
.300" = 202cfm
.400" = 225cfm
Exhaust (dog leg)
.100" = 75cfm
.200" = 150cfm
.300" = 191cfm
.400" = 211cfm
Here are pics of some of my porting work for your pleasure.
B25 head with Double-D treatment and +1mm valves with multi-angle valve job
http://forums.nasioc.com/forums/show...&postcount=166
http://forums.nasioc.com/forums/show...&postcount=286
S20 head with Baby-D treatment
http://forums.nasioc.com/forums/show...&postcount=305
S20 head with Type-C treatment
http://forums.nasioc.com/forums/show...&postcount=314
Stock USDM small ports vs Type-C vs Double D port runner size
http://forums.nasioc.com/forums/show...&postcount=317
Combustion chamber work; 257-look-a-like
http://forums.nasioc.com/forums/show...&postcount=449
Combustion chamber work; Flared out to match 97mm+ bores
http://forums.nasioc.com/forums/show...&postcount=355
http://forums.nasioc.com/forums/show....php?t=1475616
FuJi K is offline   Reply With Quote
Old 03-25-2009, 10:56 PM   #2
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Doesn't look like you got too much into the bowl. Get in there and do some work as that is where you will get the most improvement. Just make sure you know the limits and don't go into the coolant passages.
Crystal_Imprezav is offline   Reply With Quote
Old 03-25-2009, 11:27 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
See if this video help see better...
Ya, I just am not sure where my limits are. However I have removed quite a bit of the sides, say probably 2-3mm. More research!!! I need to find a dead head so I can cut it apart to see how thick it is. ekkkKK!!!
'04 EJ257
[size=1]
Intake
.100" = 84cfm
.200" = 172cfm
.300" = 246cfm
.398" = 276cfm
Exhaust (straight)
.100" = 75cfm
.200" = 155cfm
.300" = 203cfm
.400" = 219cfm
Exhaust (dog leg)
.100" = 72cfm
.200" = 152cfm
.300" = 192cfm
.400" = 205cfm
stock '05 STi heads flowed after a bead blasting. Same casting '04-'06 EJ257
Intake:
.100" = 81cfm
.200" = 166cfm
.300" = 231cfm
.402" = 248cfm
Exhaust (straight)
.100" = 84cfm
.200" = 166cfm
.300" = 188cfm
.396" = 195cfm
Exhaust (dog leg)
.100" = 78cfm
.200" = 155cfm
.300" = 174cfm
.396" = 178cfm
Old 03-26-2009, 01:48 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
STOCK EJ257. eewwWWWW
Old 03-26-2009, 09:24 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
wow, looking at the stockers and then looking at my heads made me laugh...I had forgotten how much I took off of the roof and in the bowl...also check your floor on the turn, as you'll be pushing some high cfm due to shape. It'll also try and push your air out instead of turning into the valve.
Also be sure that you aren't helping to impenge flow on the cylinder wall with your ports...if you are getting flowbenched, a decent place should have a pitot tube setup for you to use.
Getting those critiques (the velocity that is) will help you take out the 'rough' spots of the port. Looking good!
Old 03-26-2009, 11:56 AM   #6
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
may be a stupid quesion, but what keppened to the valve guide? and how would you go about using a dead head to see how much you can port out?
seanathanq83 is offline   Reply With Quote
Old 03-26-2009, 06:48 PM   #7
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Homemade, you got any good pictures of how much bias you put in the short turn towards the cylider wall?
slowmike is offline   Reply With Quote
Old 03-26-2009, 07:30 PM   #8
cribbie
Member#: 184505
2003 WRX
Sonic yellow
is it good to remove that much of the divider (knifed edged) on the intake?
cribbie is offline   Reply With Quote
Old 03-26-2009, 09:29 PM   #9
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
This may help you visualize how much and where you can port.
Old 03-26-2009, 10:57 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Awesome pic!!! That's what I need to do to a dead head.
Originally Posted by seanathanq83 View Post
may be a stupid question, but what happened to the valve guide? and how would you go about using a dead head to see how much you can port out?
The valve guide was "killed" to allow a tiny it more CFM flow in that valve bowl area. Finding a dead head so I can cut top to bottom and sideways to see how THICK the walls are so I know how much I can widen and and how much taller I can go. Kind of like the pic above of the head cutaway pic. Allows you to see the coolant and oil passages.
Old 03-27-2009, 12:00 AM   #11
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
if you look at the picture its looks as it it is a cosworth cutaway, meaning those ports or ported out alot. i would asume the port walls would be similar thickness on a stock head, perhaps cosworth takes more off the bottom. both look beautiful thought
bugeyesubie is offline   Reply With Quote
Old 03-27-2009, 01:44 AM   #12
seanathanq83
Member#: 173241
i ihave a dead big port 207 head, if you want maybe we can work a deal, where we can use it to contribute to the scooby community
Old 03-27-2009, 01:45 AM   #13
seanathanq83
Member#: 173241
also looks like the exhause can be cleaned up alot right behing the valve
Old 03-27-2009, 11:37 AM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
These are the only two detailed pics of the COSWORTH heads I have.
Old 03-27-2009, 12:13 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
I have pics on my build thread...its in built motor with my name in the title.
I had never noticed how they flattened the floor too...I wonder how they blended it into the valve seat area though.
Old 03-27-2009, 12:16 PM   #16
seanathanq83
Member#: 173241
so should i be making sure the guides are cut down to where they are even with the port?
Old 03-27-2009, 12:26 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
I don't cut mine away as I know of several cases where it has caused premature wear.
You can if you want.
Old 03-27-2009, 12:42 PM   #18
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
i have a dead big port 207 head, if you want maybe we can work a deal, where we can use it to contribute to the scooby community
You can if you want for a few CFMs when you're at high rpms. I'll do it to mine just because it's easy gains. These '06 WRX heads are a bit different from my '03 WRX heads... *sigh*
The JDM Big port is nice, but I want to cut away at a USDM one. I don't want to cut the JDM one, it'll hurt it!! hehehehe
Here's some JDM Version 6 STi heads for reference.
http://forums.nasioc.com/forums/show...1#post26035191
They kept the splitter like OEM. This allows them to just go lower in the middle. For my D-style I can't because I made a corner at the splitter. If I was making it flat from the middle of the runner to the splitter, I think I'd go through the head. lolz
Old 03-27-2009, 01:05 PM   #19
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
are you seeing any substantial gains with porting?
mxpunk is offline   Reply With Quote
Old 03-27-2009, 01:57 PM   #20
Homemade WRX
Member#: 33782
96 bastard child
I think you are missing the point of what I'm talking about...notice how the bottom doesn't look so much like a semi circle but more like a flat buttom with radiused corner...the splitter has nothing to do with it. Its also normally bad joo-joo to removed from the floor. It makes for an even harder turn for the flow into the cylinder.
I just realized how awesome that block is for checking piston to valve clearances for new cams and pistons.
Old 03-27-2009, 03:46 PM   #21
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Yes, I see what you mean. However the phase 2 DOHC heads are much better than the phase1 heads. The phase2 the ports are further away from the block than phase1. They aren't that bad because the head cutaway shows it. As long as the intake isn't like the exhaust side, which the phase1 where close to being the same slope/shape. The short turn is where it's gonna matter.
Old 04-05-2009, 10:10 PM   #22
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The work so far. Cleaned up the valve throat area.
Old 04-06-2009, 01:58 AM   #23
Maxwell Power
Member#: 190729
are you asking about his porting or in general?
if in general:
yes huge gains can be had by porting. 40+% gains in exhaust flow and 20+% intake are standard with properly ported heads.
Maxwell Power is offline   Reply With Quote
Old 04-06-2009, 08:36 PM   #24
bmxpunk
Member#: 89599
1995 almost 22B:)
red
have you had these on a flow bench yet Fuji? I would like to see what you get. also I have some ej257 and 255 heads that I may be interested in parting with.
bmxpunk is offline   Reply With Quote
Old 04-06-2009, 10:55 PM   #25
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Lets see the exhaust side. Thats where the magic happens!
Garrett GT Series Turbo port sizes WAYGONE1 Built Motor Discussion 1 08-25-2009 08:11 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
