Welcome to the North American Subaru Impreza Owners Club Friday September 19, 2014
Old 05-13-2011, 10:39 AM   #351
Nuke209
Member#: 108089
2003 WRX
NF Performance
Yay, now I can get those heads cleaned and installed
Nuke209 is online now   Reply With Quote
Old 05-14-2011, 04:22 PM   #352
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
E85,2007 6mt,No traction
^So your running a set of wrx heads on the bullet eh? They really seem to work well... Mine aren't even ported and mine have been ok, so those should really kick some major ass ! No avcs now though huh?
TDagen is offline   Reply With Quote
Old 05-15-2011, 04:25 AM   #353
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
For your viewing pleasure!!!
FuJi K is offline   Reply With Quote
Old 05-15-2011, 09:20 AM   #354
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
Wow those look killer Fuji! That makes me want DD's....
Old 07-03-2011, 02:05 PM   #355
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Here's some chamber work... These are going on a 2.5L block. I've rounded off the sides of the chambers after widening them up. They just have a little bit of clean up at the valve seat to the port runners. Funny cause one heads casting shifts one way and the other shifts the other direction.
Old 07-03-2011, 04:39 PM   #356
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
I been searching here and a few other areas but cannot seem to find a good answer on the topic of Reversion. Can anyone here please explain the concept to me when it comes into tearms of high performance?
I notice oem subarus do not have a step from head to exhaust manifold, but I have noticed the use of a larger ID gaskets which most companies use to gasket match the header to. I can see this causing a reversion effect. How well does the stock gasket work to control reversion when it is used with a non ported manifold? Most I've seen, tomei, gt spec still need a little porting.
Also, when heads get ported why do most people not gasket match the exhaust ports? What would be the negative and positive sides of doing this to a race engine?
Thanks in advance and sorry if I thread jacked or if this is off topic
-Ruben
wrxsubiemod is offline   Reply With Quote
Old 07-04-2011, 09:17 PM   #357
Maxwell Power
Member#: 190729
53cc chamber?
Maxwell Power is offline   Reply With Quote
Old 07-04-2011, 09:17 PM   #358
Maxwell Power
Member#: 190729
53cc chamber?
Casting shift is terrible on the s20 heads.
Old 07-05-2011, 01:47 AM   #359
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by Maxwell Power View Post
53cc chamber?
these are 50cc chambers. I'll work on the ones I had cc'd to 53cc later. Gotta catch up on engine builds first.
Some S20 heads are decent. They all vary.... Same with the B25's. If you bring the valve throat all the way out to almost not having a bottom cut, it'll get rid of the step.
Old 07-06-2011, 08:14 PM   #360
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
-Ruben
Having the larger diameter after the port helps with off boost driving because you're running similar to an NA. However when boosted it doesn't do much because you are relying on the turbo to get you power. Ported stock ex-mani's makes the car drive with a bit more punch in the lesser throttle inputs aside from WOT when you're just punching it around town.
http://www.google.com/#hl=en&xhr=t&q...w=1366&bih=642
Old 07-06-2011, 08:53 PM   #361
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
put simply it helps knock down the strength of the reversion pulse from coming back into the port and to the valve. Thus it helps keep exhaust reversion and residual gas lower.
Old 07-06-2011, 09:08 PM   #362
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Thanks fellas, I knew I could count on you guys to help.
Old 07-22-2011, 03:24 PM   #363
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
JDM style. Double-D width, Baby-D height.
Ported to shape, next is the exhaust work, blending, then finish up the surface texture on the intakes.
Old 08-01-2011, 12:04 AM   #364
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Porting to shape is all done. Just final touches and valve seat blending, then intake port texture finish. Time to start on the 2nd head tomorrow morning.
Old 08-28-2011, 11:24 AM   #365
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
For those who didn't know....
Double D ports on this engine!
http://forums.nasioc.com/forums/show....php?t=2213041
Old 08-29-2011, 06:57 PM   #366
054eatwagon
Member#: 203288
05 wagon
cgm
cant wait! mine are ready for some luvin'
054eatwagon is offline   Reply With Quote
Old 09-07-2011, 09:34 AM   #367
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
valve seat blending. from stock 1.17ish" to 1.23" at the troat
Old 09-07-2011, 05:08 PM   #368
Homemade WRX
Member#: 33782
96 bastard child
glad to see the flat break showing itself on that floor
Old 09-10-2011, 11:17 AM   #369
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
a standard feature on the JDM heads.
Old 09-11-2011, 10:19 AM   #370
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Old 09-11-2011, 10:38 AM   #371
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Old 09-14-2011, 01:40 AM   #372
rdrz14
Member#: 199004
04 WRX BuiltHybrid
Black & Gold
This is my first porting or any type and I just have two quick questions...
Set-up: 04 wrx Hybrid with S&R Performance 2.5L Stage 0 Built block with 2.0 Heads(Stock valves and cams)
Question 1: I have grimspeed ported headers and crosspipe and am wondering if its ok to just port/blend match around the exhaust side of the head about an inch or so in, rather than porting all the way out to the valves... I am not going for a crazy DD style port just something to help the flow. Is this going to be ok or am I making a mistake?
Question 2: On the intake side, is it ok to gasket match the head and port/blend the first inch or 2 in toward the valves?
Thanks guys!
rdrz14 is offline   Reply With Quote
Old 09-14-2011, 09:11 AM   #373
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
no mistake, but gains are minimal to zero. valve seat blending and widening the chamber's sides would be better.
Old 09-14-2011, 10:50 AM   #374
Homemade WRX
Member#: 33782
96 bastard child
rdrz14: don't gasket match the exhaust side!! leave a stepped lip. It helps to limit reversion....something most noobs don't know to check on a flowbench or even think about with gas flow of an engine.
Old 09-14-2011, 12:56 PM   #375
rdrz14
Member#: 199004
04 WRX BuiltHybrid
Black & Gold
Thanks Guys! I'll smooth things up and call it a day!
Garrett GT Series Turbo port sizes WAYGONE1 Built Motor Discussion 1 08-25-2009 08:11 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
