Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 09-14-2011, 01:02 PM   #376
eg33GC
Member#: 206851
99 V4
EJ20K RS
fuji you need to play with that h6 head you have had for years!
eg33GC is offline   Reply With Quote
Old 09-21-2011, 12:44 AM   #377
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I'll dig that head out and get some before and after pics. Let me catch up on some engines first.
FuJi K is offline   Reply With Quote
Old 09-21-2011, 09:17 AM   #378
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
be careful on the EZ30R heads as I've been made aware that they have thin spots throughout the port. So use some sonic help
Homemade WRX is online now   Reply With Quote
Old 09-21-2011, 09:21 AM   #379
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I haven't gotten to those yet, but the ones we're talking about are the EG33 heads. Thanks for the heads up!
Old 09-21-2011, 10:02 AM   #380
Homemade WRX
Member#: 33782
96 bastard child
oh, EG33 heads have lots of meat
Old 12-12-2011, 01:00 AM   #381
AREA1320
Member#: 112508
Originally Posted by Homemade WRX
rdrz14: don't gasket match the exhaust side!! leave a stepped lip. It helps to limit reversion....something most noobs don't know to check on a flowbench or even think about with gas flow of an engine.
But if the exhaust manifold is ported the same this theory is void no?
AREA1320 is offline   Reply With Quote
Old 12-12-2011, 03:49 AM   #382
Maxwell Power
Member#: 190729
It's not a theory and the oem header shouldn't be ported.
it's ignorant for people to think that Subaru couldn't make a well flowing exhaust. the steps are there for a reason. if you look it always goes from small to big. this is because you can't rely on any scavenging effect from the other cylinder in the factory header. You have to tune the exhaust like 4 single cylinder engines. When you use an aftermarket header, there is a merge collector that brings all the exhaust pulses to a single point, maintains flow in one direction and provides scavenging. In that exhaust you can port match the head if you desire, but it is still better not to for lower end torque.
Maxwell Power is offline   Reply With Quote
Old 12-12-2011, 08:48 AM   #383
MartinSTi05
Member#: 145145
2006 wrx STi
Agreed, the steps are there and directional. I think there are areas that could use a little clean up though; not because Subaru is incapable of designing an exhaust though. Cost dictates you can only spend so much on finishing for x amount of gain. From an OEM perspective the header is good enough, especially for those power levels.
I firmly believe Subaru configures their single scroll headers in the manner they do because it minimizes the volume between the head ports an turbo an that configuration naturally costs less.
MartinSTi05 is offline   Reply With Quote
Old 12-12-2011, 09:05 AM   #384
AREA1320
Member#: 112508
Yes sir!!! Relax buddy
Maybe i should have been more clear and specified oem manifold vs aftermarket. I understand the reasoning for the oem. Just couldnt find one for the aftermarket
Old 12-12-2011, 10:40 AM   #385
3MI Racing
Member#: 200987
Most aftermarket companies seem to just build off of what fits and not so much as to what is better, an excellent example is Manley and their destroked EJ257 piston. It is completely backwards from what you should have for a piston in the applicatoin but is done for a bottom dollar attempt to get into the market.
Things like manifolds really are way more design intensive than catbacks and intakes, which are easy to make improvements upon for little design time. Making a good intake or exhaust manifold requires lots more R&D and requires more to make without trade-offs.
This is where we find ourselves in the niche market of a car where we can design these things without emissions limitations (see block geometry, cam lobes/timing, combustion chambers, AVCS, etc). Those who have studied what the factory did, not as they did it so it must be right but with they thought 'why was it done this way' and take with a system approach...keeping in mind nagging penny pinchers on the business side
/rant
3MI Racing is offline   Reply With Quote
Old 12-12-2011, 10:50 AM   #386
AREA1320
Member#: 112508
rant noted
Im all about learning, christ my wife yells at me all the time for constantly searching thing on the phone haha. Now that makes me more curious to see what can be improved with our twinscroll manifolds
Old 12-12-2011, 11:51 AM   #387
Maxwell Power
Member#: 190729
I'm calm
A lot of people mistake exhaust for plumbing. we aren't pouring water through pipes. An exhaust is very dynamic with pressure waves that need to be timed/tuned to give a certain result.
The steps provide that function and the average enthusiast has no idea what is going on. Subaru owners seem to have a better grasp on engineering than Evo owners, no doubt.
Old 01-26-2012, 03:44 PM   #388
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
subscrib'd...
maxpowr is offline   Reply With Quote
Old 01-26-2012, 04:28 PM   #389
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
FuJi K,
Have you ever considered using Pipemax? To the point, it's simply the best tool I've ever used. Do a search for Larry Meaux maxracesoftware.
S.
n2xlr8n is offline   Reply With Quote
Old 01-26-2012, 06:54 PM   #390
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Originally Posted by n2xlr8n View Post
FuJi K,
S.
That is a super handy program but the calcs but a bit difficult to apply to a forced induction setup unless your turbo setup is pretty closely optimized to run very close to 1:1 intake/exhaust, drive/boost.
Couple Pipemax with Performance Trends EAS and you've got quite the combo.
ASF Machine is offline   Reply With Quote
Old 01-28-2012, 04:55 AM   #391
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
FuJi K,
S.
i have looked at that a long time ago. very fun thing to play with!
Old 01-30-2012, 10:57 AM   #392
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
is smoother....but it'll be covered in carbon once the car is running.
Old 01-30-2012, 01:50 PM   #393
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
Fuji, can you pm me on how much you charge for porting?
smileyou is offline   Reply With Quote
Old 01-31-2012, 12:41 PM   #394
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
nasty lip on the short turn of the exhaust
Old 02-02-2012, 12:13 AM   #395
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Do you have any flow numbers of your ported heads compared to stock on the same bench?
What exactly is the bottle caps and wrench sockets supposed to signify?
project_skyline is offline   Reply With Quote
Old 02-02-2012, 03:18 AM   #396
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Fuji, do you know how much meat there is on the clover style EJ20G/EJ20K heads to make them more bath tub shaped?
Marnix is offline   Reply With Quote
Old 02-02-2012, 09:38 AM   #397
B.R.E.D
Member#: 289606
06 WRX
white
Why would you want to do that?
B.R.E.D is offline   Reply With Quote
Old 02-02-2012, 10:20 AM   #398
ASF Machine
Member#: 236349
1993 Impreza
OD Green
My only guess would be to better match a donut dish.
That said, the clover style chambers deshroud very beautifully.
Matched to an EJ25 Bore
Still EJ20 bore
Old 02-02-2012, 02:39 PM   #399
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
look through the water jacket holes. I'm sure there is a good amount of meat... the '96 25D heads are a larger chamber similar to the B25 heads; HLA valvetrain.
Old 02-02-2012, 06:14 PM   #400
Maxwell Power
Member#: 190729
I had a set of S20 heads that are on a big bore. I wanted to experiment with the clover style to see if there was any power to be had. So I cut the chambers out to resemble the clover. Obviously I was unable to add material in between the valves like the clover. But I was able to just deshroud around the valves to make the final chamber look very "cloverleafy". I have more room to work than most people because I'm running a 102.3mm bore.
no gains... at all. Total waste of time. Now I'm going back in to open them up like the STi chambers (only a little bigger around) because I know there are gains (I've done it many times already).
Garrett GT Series Turbo port sizes WAYGONE1 Built Motor Discussion 1 08-25-2009 08:11 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
