Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 04-23-2012, 11:21 AM   #426
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by maxpowr
very nice mr fuji. how many hours do you estimate in a single head in your last youtube video?
looking forward to showing my machinist the limits you have found.
up to 16hrs doing the JDM to Double-D sized ports. This includes the full porting in all the runners, around the valve guide, and valve seat blending to the runners. I don't ever enlarge the exhaust port outlets at all. The intake inlets of the 2L heads i gasket match, excluding the injector area. All the porting is done inside the runners.
FuJi K is offline   Reply With Quote
Old 04-23-2012, 12:05 PM   #427
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
you're my hero FUJI K!!
simer1228 is offline   Reply With Quote
Old 05-03-2012, 10:46 AM   #428
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
exhaust short turn comparison on B25 heads.
Old 05-03-2012, 10:58 AM   #429
Scargod
Member#: 260314
2008 STI hatch
I thought material removal on short turn or "floor" areas were fairly inconsequential and actually decreased flow rate (relatively).
I thought you were supposed to concentrate on "ceiling" areas or the big, outer radius (other than normal cleanup and blending).
Please explain.
Scargod is offline   Reply With Quote
Old 05-03-2012, 02:05 PM   #430
3MI Racing
Member#: 200987
You can actually find gains in 'flattening/widening' the floor. You don't want to lower it though. It makes for a more acute angle of flow and going too much, you'll start to get separation of flow on the inside of the turn.
3MI Racing is offline   Reply With Quote
Old 05-03-2012, 06:30 PM   #431
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Please explain.
Generally speaking some heads are very good from factory, i.e. B18 ITR honda head. Some heads really suck and start off with room for improvement.
If the head allows you to reshape the port, have at it. When its wall thickness limits you on reshaping, you just have to work with what you got.
With that said, the B25 heads could use an improvement on the exhaust ports as seen in the pictures. You can gain 30+cfm by just smoothing up the short turn and widening it up.
Old 05-04-2012, 11:18 AM   #432
3MI Racing
Member#: 200987
^^I still wonder what on earth Subaru was doing when they put that harsh turn on the dogleg side of the B25 heads.
Old 05-04-2012, 11:31 AM   #433
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
they should have kept it like the WRX head. I show all the STi guys the exhaust ports they have. I tell them to finger the ports so they can feel the difference. lol
Old 05-06-2012, 05:29 PM   #434
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
having a vacuum helps keep them shavings to a minimum
2L head for 257-like chamber work
Old 05-06-2012, 06:17 PM   #435
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i wish i was having fun like that...
maxpowr is offline   Reply With Quote
Old 05-06-2012, 06:45 PM   #436
Scargod
Member#: 260314
2008 STI hatch
Fuji, I am surprised that you use single-cut burrs. Do you finish with a double-cut before you sand? How do you have good control with a single cut?
I believe you use electric power with a flex shaft, like a Foredom, correct? I used to have that. Only does 15,000 RPM. I currently use air, as I have just started porting my own Subie heads. I have another set to do in the near future.
Just wondering why you use what.
Old 05-06-2012, 10:18 PM   #437
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
i use the single cut to bring what ever I'm porting out to where I want it before switching to a double cut. then yes finally sand rolls, tapers from 80, 120, 240 grit. The single cut is a little catchy, but you can master it. My Makita is the GD0800C model with a low rpm of 7000 to start off, which is where I run it.
tools for chamber work
with the single cut
Old 05-06-2012, 11:06 PM   #438
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Is that makita the rotary tool you're using? If it is what model is it? I'm wanting to get back into porting just don't have the space for a big air compressor.
2gnt2wrx is offline   Reply With Quote
Old 05-06-2012, 11:10 PM   #439
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
i have the model posted above.
here is after the small oval double cut bit, next is just sand roll and then round off the edges on the sides. porting this head as we speak
Old 05-07-2012, 12:52 AM   #440
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
and here is the finished with sand roll on the right VS double cut on the left.
Old 05-07-2012, 04:07 AM   #441
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
and the finished chambers
Old 05-07-2012, 11:19 PM   #442
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
What do you use to measure the ports and combustion chamber? Do you cc both or just go off of flow charts?
wrxsubiemod is offline   Reply With Quote
Old 05-07-2012, 11:31 PM   #443
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
the ports are all ported the same way, whichever style it is.
the bottle cap makes a good reference. I also have a few templates that i made. I only remove material in certain areas.
Old 05-07-2012, 11:50 PM   #444
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Yeah I understand that just wondering if you measure how much you port out or how you ballance them.
I guess best way would be to flow each runner. Cc'ing them would be nice but really can't get a real world reading of how they would do that way.
Great job on the heads man! When you cut the valve guide's inside the head is it just that? Use a reemer and call it good? Was looking into doing that but just unsure if I need to use smaller guides or just cut and port them out
Old 05-08-2012, 01:07 AM   #445
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
i don't mind grinding away at the valve guides. Our guides don't come out as far as some other heads out there. Also there is extra clearance at the top part of the guides if you look closely into the guide from the combustion chamber side. Just make sure to clean up the inner edge with a reemer if you have one so excess material doesn't start scraping away at the valve stem.
I've flowed tested these heads in the past and they've given me a good feel of where they flow. They get ported a certain way depending which it may be; DD, Baby D, etc. The ports get reshaped.
Old 05-10-2012, 01:58 AM   #446
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
after looking at the clock... seems to take up to 6hrs to gut the intake ports out along with shaping the splitter with my single cut bit. i left room for the double cut to come in to bring the ports out to where they should be. These are going to get the Double-D treatment.
Old 05-10-2012, 02:22 AM   #447
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
here is a stock B25 vs ported one i just recently finished for a friend.
Old 05-10-2012, 09:30 AM   #448
Scargod
Member#: 260314
2008 STI hatch
Default My porting work and engine build
Mine look a lot like what you have done but I was afraid of taking out so much of the divider in the intake.
See the rest of the pictures, too. I'm in the process of buttoning up the engine.
I want to build a downdraft grinding table with attachments so I can also suck directly on the ports I am working on. I have a wood shop, so I have a powerful Rockwell dust collector in the basement to do the sucking.
I have another engine to build in the future so I will be doing more heads. Just my own and just for the fun of it... I think a Foredom is in my Christmas stocking already.
Old 05-18-2012, 04:45 AM   #449
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
here is a 2L head with 257-like chamber work and all assembled
Old 10-01-2012, 04:25 PM   #450
Dr. octagon
Member#: 171127
GDA Cyborg T4
Not waving back
there's not so much more room on these USDM heads anymore to really make them big. You come really close to almost porting through the water jackets! The USDM 2.0L have good meat though as with your JDM big port heads. I think I need to pick up a bad USDM STi head to see how are out I can go. lolz
I'm just concern about the roof. The floor is already shaped like so... and so I have to go off of that... unless I go CNC. Yours look great!! I'm sure they can breath well up to 9000rpms!!!! Drag motor??
So i assume that double d port is not an issue on ej205 head correct? Thinking 2.1l more and more
Also, do you have any idea on price (general/rough idea) to convert to shimmles buckets?
Dr. octagon is offline   Reply With Quote
Garrett GT Series Turbo port sizes WAYGONE1 Built Motor Discussion 1 08-25-2009 09:11 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 01:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 07:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 10:47 PM
