Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 04-07-2009, 08:55 AM   #26
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by Crystal_Imprezav View Post
Lets see the exhaust side. Thats where the magic happens!
isn't that the truth...funny thing is I got my dogleg so well with my first few times going to the bench that I spent the majority of the time matching the intake to the exhaust. that and trying to get the straight port to catch up.
Old 04-07-2009, 10:12 AM   #27
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by bmxpunk View Post
have you had these on a flow bench yet Fuji? I would like to see what you get. also I have some ej257 and 255 heads that I may be interested in parting with.
Not flow tested yet. I will get the current head flow tested to see where the improvements are after I finish with the exhaust tonight. After work I'll get back into the exhaust.
There's almost a corner on the short turn side to the floor. I looked at it and I was like... eewwwWWW!!! Once that is smoothed out, it makes quite a difference. I don't want to touch the exhaust valve guide because it's HOTTER on the exhaust side than intake. Most work on the exhaust would be the valve throat area. After the valve throat area, it's pretty large in size, so you don't really need to make it BIGGER after the valve guide.
I'll get some pics later tonight. Hopefully this helps those who are porting at home as well.
FuJi K is offline   Reply With Quote
Old 04-11-2009, 10:19 PM   #28
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The STOCK STi exhaust ports sucks. I hate them. Hard to make out how much room I have before going through. What I did instead was improve the exhaust ports on cylinder #1 and will try to replicate on it on cylinder #4.
Old 04-24-2009, 08:36 AM   #29
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Valves installed. Should be interesting to see some numbers
Old 04-24-2009, 11:59 AM   #30
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Video of the exhaust ports since I can't get a camera in there.
http://www.youtube.com/watch?v=c1VwqhwDVBE
Old 04-26-2009, 04:17 PM   #31
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Missed some spots on the exhaust side! JK, there is that one corner on the dogleg that is impossible to get any kind of bit into.
Crystal_Imprezav is offline   Reply With Quote
Old 04-26-2009, 11:11 PM   #32
Homemade WRX
Member#: 33782
96 bastard child
I can touch all of the dog port...
Old 04-27-2009, 04:14 PM   #33
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I can't ever seem to get a carbide bit into the immediate left wall of the dogleg outlet where it makes a fairly sharp turn towards the combustion chamber. If I remember correctly, I can skim it a bit and end up just smoothing it out when I get the cartrige roll to finish up the port.
Maybe I just need to remove more material prior to it to get to it
Old 04-27-2009, 09:17 PM   #34
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
^^^^ That's pretty much how the process has to be with hand porting, IMO. One step at a time. It's hard to shape these STi heads to be like the WRX heads. What I can do is just make it smoother and make the DOGLEG side smoother flowing to match the straight exhaust port.
The carbide bits I'm using are 6" bits shanks. I cut off 1.5" so it doesn't vibrate as my Makita's lowest rpm is 7000rpms.
How are you getting at the Dog Leg, Homemade WRX?
Old 04-27-2009, 11:25 PM   #35
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I am also using both 6" and standard non-ferrous carbide bits as well as the same combo in Dremel size carbide bits to cater to the STi's cavities.
I guess when it is all said and done, I like most others w/o CNC's and the balls to destroy a set of STI heads you own/paid for effects your judgment. I have two sets I often swap and flow to to play around with flow and refuse to let myself cut into a coolant chamber.
I will also say that, with each round of porting on my heads, I have improved my performance a ton. Truth be told, I haven't touched my intake ports since my first round of porting and with every pass of the exhaust ports, performance has jumped ridiculously. One huge characteristic I have noticed, especially with the dogleg is to my each bowl/out as oval as humanly possible. I'm sure all the head guru's will say duh, but I have to try everything out on my own.
Old 04-27-2009, 11:31 PM   #36
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
My next adventure is to seek options in reshaping or unshrouding the valves and/or combustion chamber. I was speaking with one of my machine shop guys a few months back while getting my heads decked and he showed me a old set of ej22 heads before and after minor unshrouding of the valves (literally a new set of heads he was working on in front of me) and the flow increase was amazing, but this is not so say it will help in a real world application. You got me a bit motivated again lol. I have had my other set of heads sitting on the bench for the past few months since I have been happy with their performance. I will post up any findings if their are any.
Old 04-27-2009, 11:39 PM   #37
Homemade WRX
Member#: 33782
96 bastard child
I use 6" carbide bits, Standard Abrasives deluxe porting kit and a few various other flap wheels.
3/4" cartridge roll on the 4" mandrel usually reaches it easily to simply clean up the casting. I don't remove much from that side of the dogleg. It doesn't help get the exhaust out of the head.
Old 04-28-2009, 09:27 PM   #38
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I just dropped off the heads at the Machine shop here (DG Motors) and I'll pick them up either tomorrow night or Thursday. Let see what the work cut out to be. Not really looking at high numbers from the exhaust because they have smaller valve bowls than the WRX heads. Also the floor isn't D with the flat part on the floor like a STOCK WRX head.
Old 04-29-2009, 01:59 AM   #39
Nuke209
Member#: 108089
2003 WRX
NF Performance
D & G Motors to be exact.
Nuke209 is offline   Reply With Quote
Old 04-30-2009, 02:09 PM   #40
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Flowed on a SF-600 @ 28"
Intake
.1" - .2" - .3" - .380" (couldn't get the stock cam to hit .4" lift??)
84 - 172 - 246 - 276
Dog Leg
.1" - .2" - .3" - .4"
72 - 152 - 192 - 205
Straight Leg
75 - 155 - 203 - 219
Old 04-30-2009, 03:06 PM   #41
Homemade WRX
Member#: 33782
96 bastard child
did you do any probe varifaction of velocities? flow #'s are honestly pretty useless alone.
Regarless, not a bad intake to exhaust ratio at all. I'd work on improving the intakes flow and matching the dogleg to the straight leg...try and balance the cylinders.
try dropping the roof on the dogleg, essentially causing a taller port for it. Try and aim it so that the convergence of the two valve's flow hits outside the head/at the gasket.
Old 04-30-2009, 03:42 PM   #42
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I didn't get any on velocities. I just dropped off the head to get flowed. I wished I had a bench all to my self. I'd flow the heads with the intake manifold and exhaust manifold.
I'll get some work on the DogLeg some more, then mirror the unported head to it. We'll see if I'll get to flow more heads over there. Should be interesting this summer.
What's the ideal intake-exhaust ratio?
Here are the sheets.
straight exhaust ---------Dog leg & intake
Old 04-30-2009, 07:42 PM   #43
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Great work!!!
Im assuming the dog leg on the exhaust, out flows the strait port when the head is stock before the PNP work?
Also what grit are you using in thye intake runner, and bowl? And what grit for exhaust? Flapperwheels on the intake side for the finish work etc?
rexworx is offline   Reply With Quote
Old 04-30-2009, 09:05 PM   #44
Member#: 210128
2004 2.7L WRB WRX
2011 GT-R
Looks good fuji!! How have you been, have not seen you all winter!
aj@adrenalinrush is offline   Reply With Quote
Old 04-30-2009, 10:41 PM   #45
Homemade WRX
Member#: 33782
96 bastard child
a lot of people/sources say exhaust should be 2/3 of the intake. Of course if this is off, valves and or cams can be used to equalize the flow.
I use 120 grit flapwheels for finishing my ports and TGV's.
Old 05-01-2009, 01:31 PM   #46
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by rexworx View Post
Great work!!!
The straight port flows more than the dogleg, always unless you put work into it.
It's hard to fine stock numbers that'll work. However.. I found these numbers, and it gives us an idea.
http://forums.nasioc.com/forums/show....php?t=1202574
I converted the Cosworth heads to 28"
WRX head Intake Port flow @ 28" IIRC (as reported on Jorge's site):
Lift = CFM
.1" = 81
.2" = 177
.3" = 234
.4" = 234
Stock STi Intake Port Flow @ 28" (as reported by Cosworth):
Lift in mm = Flow in CFM
.1" = 67
.2" = 164
.3" = 215
.4" = 232
Lower lift numbers on the STOCK STi heads probably from the imperfections of the valve seat to the port. I've seen this in the STi head I have, as well as the STI head [email protected] The step of the valve seat isn't as apparent on the WRX 2.0L or the WRX 2.5L head.
Here's some stock WRX numbers:
http://rs25.com/forums/showthread.ph...84#post1688784
Lift Intake Exhaust
.050 16 cfm 11 cfm
.100 61 cfm 44 cfm
.200 188 cfm 147 cfm
.300 240 cfm 194 cfm
.400 248 cfm 205 cfm
Again, it's hard to compare numbers because also temperature plays a role and such. This gives you an idea.
The tools I'm using at the moment. I also have sand rolls 3/4" diameter by 1" tall?
Old 05-01-2009, 01:39 PM   #47
Homemade WRX
Member#: 33782
96 bastard child
you should check out Foredom grinders...I've used one with the foot pedal option before. Its now on my to buy list
Old 05-04-2009, 05:40 PM   #48
rexworx
Member#: 103232
Thanks Homemade, Im in the process of pnpinga set of EJ205 heads...
Old 05-04-2009, 06:08 PM   #49
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
I'm doing some now too! Thanks for the pics.
06rexwagon is offline   Reply With Quote
Old 05-04-2009, 10:17 PM   #50
charliew
Member#: 125304
You can build a very good flow bench with Audie Tech. Electronics and check material thickness with a Phase II thickness checker in the ports or on anything you can't get to both sides of.
If subaru thought it was a good idea to shorten the guides for more flow they would not have wasted their money on longer guides. A shorter guide lets the valve wobble on it's way down and it won't set in the same place each time as the guide wears also the heat won't be transfered as well with a smaller surface area.
If you have your own flow bench it is easy to see when you are removing material in the wrong places before it gets too out of hand. The only place to start is with the head at the begining and flow it as using other flow numbers is not the same as doing the same head from start to end on the same bench. It's real easy to loose 20 cfm at low lift removing the material from the wrong places.
The best flow numbers are the highest averages across the span from .0 to .450 not the maximum flow. The valves spend more time at low to mid lift. Thats where you want the largest gains. Usually you will loose low lift numbers trying to gain high lift numbers.
I really haven't written anything new as this info has been posted on other earlier threads but I just thought I would bring it up for new readers.
charliew is offline   Reply With Quote
Garrett GT Series Turbo port sizes WAYGONE1 Built Motor Discussion 1 08-25-2009 08:11 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
