Old 04-19-2013, 08:15 PM   #551
J3SST3R
Member#: 298926
2007 USDM STI
Satin White Pearl
^^ this is awesome Fuji!
J3SST3R is offline   Reply With Quote
Old 04-19-2013, 08:52 PM   #552
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Only a matter of time.
I had a very nice set of these W25's that I sold a year and a half ago. I got a deal on them and thought I would use them but decided to sell them. I was also speculating a little but maybe a bit ahead of the curve on the DAVCS W25 heads. I remember that you commented on some scratches on the deck surface! The funny thing was the guy I sold them to tried to cut corners on his build and not surface them before hand. The one that did not seal well was the one without the scratches. I told him that I would not have used them without surfacing them first! He learned!!
It's too bad that Subaru does not make any (to my knowledge) a D25 type combustion chamber DAVCS head!
Please make sure your customer adds at least some 272 duration cams to those after you're done with them so that they can really maximize the flow potential!
Old 04-19-2013, 09:19 PM   #553
J3SST3R
Member#: 298926
2007 USDM STI
Satin White Pearl
I have a set of JDM Z20 dual avcs heads you can get Fuji to open up with DD and D25 chamber if you want
Old 04-19-2013, 09:31 PM   #554
manitou
Member#: 193757
2006 XTI Limited
Do the Z20 heads have the hemi shaped D25 type combustion chamber? When you say open up, you mean the ports correct? The D25 combustion chambers are actually lower in volume than the B25 and W25 combustion chambers. it's 49-50 cc's of the D25 vs 56 cc's B25 and W25 heads. The hemi shaped combustion chambers of the D25's vs the penta shaped combustion chambers of the B&W25's are the reason they are more efficient in their flow and burn cycle and usually more desirable. The downside for some is the lower volume of the CC will raise the compression ratio but a good tuner and good fuel can exploit the higher CR!
Old 04-19-2013, 10:27 PM   #555
J3SST3R
Member#: 298926
2007 USDM STI
Satin White Pearl
Unfortunately not. They are just about perfectly square shaped, I have them for sale in my threads if you wanna look at pictures,
But you could get him to open up the chambers to replicate the D25.
As for the ports I'm pretty sure the Z20's differ from the D25. But I haven't put them side by side.
I think Fuji has seen and worked with them? And I remember Micah saying he had a set(s) before..
Correct me if I'm wrong.
Old 04-19-2013, 10:31 PM   #556
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Fuji K I Needz Teh Dd Heads
ckyguy68 is offline   Reply With Quote
Old 04-19-2013, 11:32 PM   #557
manitou
Member#: 193757
2006 XTI Limited
Thanks, I already have a nice set of PnP'd D25 heads on my current XTI build so I am not in the market, you can see my heads in an earlier post here. If I do another build I would use the D25 heads again!
Old 04-20-2013, 12:18 AM   #558
J3SST3R
Member#: 298926
2007 USDM STI
Satin White Pearl
Don't worry, I've been subscribed to your build for a while manitou! Love the XTi!
Old 04-20-2013, 12:33 AM   #559
manitou
Member#: 193757
2006 XTI Limited
Oh, cool thank you and thanks for mentioning that!
Old 04-20-2013, 12:36 AM   #560
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I haven't worked on those Z20 heads, but i have a very good idea how they are going to be like after porting
From the pictures the chambers do look round, but squares off. Hard to see fully with the carbon build up.
FuJi K is offline   Reply With Quote
Old 04-20-2013, 12:05 PM   #561
manitou
Member#: 193757
2006 XTI Limited
What car did they come off of, late model JDM STI, Spec C.....? Any idea on the specs of these heads?
Old 04-20-2013, 12:50 PM   #562
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I'm not sure which model. The JDM Impreza STi runs W20 heads (dual avcs).
Old 04-20-2013, 04:22 PM   #563
J3SST3R
Member#: 298926
2007 USDM STI
Satin White Pearl
They came off a JDM version 9 legacy
Old 04-26-2013, 03:41 PM   #564
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Radius valve job next.
Old 05-13-2013, 11:00 AM   #565
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
'10 Legacy GT E25. Nothing new. Intake porting is going to be limited on going large. I could possibly go the DD shape. Subaru really thinned it out resembling B25 heads when i looked at the intake runners through the valvetrain. However i do like the little cam driven oil pump on the passenger head. These wont be ported, sorry. Maybe when i get a set for myself.
Old 05-14-2013, 04:45 PM   #566
Maxwell Power
Member#: 190729
The gear driven pump is a scavenge pump used to get the oil from the turbo back to the pan.
Maxwell Power is offline   Reply With Quote
Old 05-15-2013, 12:51 AM   #567
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Wow they also went with a flat top exhaust valve
Crystal_Imprezav is offline   Reply With Quote
Old 05-15-2013, 01:44 AM   #568
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Yup that's what the pump is for. The valves are still the same as before. They're not flat face.
Old 05-16-2013, 08:55 AM   #569
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
W25 radius valve job and seat blending. 120 grit exhaust and bit finish intakes
Old 05-25-2013, 01:10 PM   #570
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Just testing..... Seats blended and ready for assembly; GSC beehive, Supertech SS intake, inconel exhaust, GSC S2 cams.
Old 05-25-2013, 04:56 PM   #571
Scargod
Member#: 260314
2008 STI hatch
Not oversized valves on the W25 heads? Will be curious about flow. Had mine flowed before and after +1 valves.
Scargod is offline   Reply With Quote
Old 05-26-2013, 01:43 PM   #572
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
No oversized valves. They will still flow good numbers; 280 cfm. I've flowed head with +1mm valve before and they average around 10 cfm more.
Old 06-11-2013, 09:58 PM   #573
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Type C! Simple...
DD Revision
Old 06-21-2013, 11:49 PM   #574
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Here are the exhaust ports with the oem gasket. I don't gasket match the exhaust ports.
Old 08-27-2013, 03:27 PM   #575
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This is right after porting. Getting a radius valve job with +1mm valves. WRX S20 heads with DD ports and chamber flare.
Garrett GT Series Turbo port sizes WAYGONE1 Built Motor Discussion 1 08-25-2009 08:11 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
