Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 01-31-2014, 11:04 PM   #601
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
2007 V25 SOHC AVLS
FuJi K is offline   Reply With Quote
Old 02-01-2014, 09:03 AM   #602
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Fuji,
when will you get to the heads Joe sent you?
Ben
Old 02-11-2014, 09:51 PM   #603
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by jaxscuby View Post
Fuji,
Old 02-15-2014, 09:24 AM   #604
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
ok, bead blasting...when double-d goodness?
Old 02-15-2014, 01:00 PM   #605
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I was waiting for these two to come in. my double cut bent at 32,000rpms! I run my Makita at 7000rpms, which is the lowest setting. Vibrations get crazy at more speeds with these 6 inch shanks.
Old 02-15-2014, 02:52 PM   #606
Scargod
Member#: 260314
2008 STI hatch
I straighten mine! It is tough though to work with that length. I wonder about a small handpiece that could get farther in there?
BTW, I use floor paste wax as a lubricant. What do you use?
Scargod is offline   Reply With Quote
Old 02-15-2014, 04:15 PM   #607
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I usually just chop off an inch to shorten the shanks. I use Murrays Black Beeswax.
Give me a few hours. Brb!
Old 02-15-2014, 07:44 PM   #608
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
32k rpm lol wtf you trying to break your wrist?
spoolinsti05 is offline   Reply With Quote
Old 02-15-2014, 07:59 PM   #609
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
That's what happens when someone else uses your tool.
Old 02-15-2014, 08:28 PM   #610
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I see. I use a bluepoint die grinder harder for me to control but I set my middle finger under the trigger and hit it with my pointer.
One day I'll trim a wood block trigger stopper to get the rpm I like using when porting aluminum. Keep up the good work. Have any pics of v25b ports? mostly would like to see how you treat the exhaust ports.
Old 02-16-2014, 04:04 PM   #611
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I treat them the same way S20, W25, D25 since they are the same casting shape. Not much bad spots really, just smooth out the turns. I don't have much comparison pictures of those vs the B25.
My arm tires out quickly since i don't port often.... Gotta get back in shape. Lol
these will flow easy 260cfm+ as they are in this picture (baby D size). They are getting full DD enlargement when done.
Old 02-16-2014, 04:23 PM   #612
cowboy_Rob
Member#: 194062
2003 Impreza WRX
What's the hole/pit on the ports on the left? Is that gone too far or a casting mark or?
cowboy_Rob is offline   Reply With Quote
Old 02-16-2014, 04:25 PM   #613
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Valve guide area
Old 02-16-2014, 05:13 PM   #614
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Valve guide area
Oh yea. Just looked weird cuz it was full of shavings and you couldn't see them on the other cylinder
Old 02-16-2014, 08:08 PM   #615
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
DD yo! Single cut bit finish. Look forward to a double cut bit finish.
Old 02-16-2014, 11:29 PM   #616
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Single cut bit finish on both intakes.
Old 02-17-2014, 05:55 AM   #617
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
drool..nice..
Old 02-17-2014, 08:52 AM   #618
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I know what you're saying about the fatigued hand! You ever try a final finish with emery by hand? It's so pretty..
Old 02-17-2014, 11:16 AM   #619
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
aluminum would destroy my double cut bits just like iron would destroy my single cuts.
wrxsubiemod is offline   Reply With Quote
Old 02-17-2014, 11:38 AM   #620
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I run mine threw the wire wheel after and they are good as new. But if you let the dermal do the work at low rpm it tends to cake up less. For some reason my 6" bit didn't last :-( but that's good because I only use it around the valve guides and to smooth tight angles.
Old 02-17-2014, 12:26 PM   #621
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This is Polish after 1000grit wet sand. I won't be doing that anymore for the exhaust.
Gotta keep the bit lubed. You'll notice when it starts to clog up. I stop porting to clean the bit with another bit by hand running it in the grove with its teeth.
Old 02-17-2014, 12:49 PM   #622
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Man but those ports look so pretty.
Old 02-17-2014, 12:50 PM   #623
Justin V
Member#: 98747
07 WRX
Holy jeebus I know its just a picture but I can still see myself in those ports!!!
Justin V is online now   Reply With Quote
Old 02-17-2014, 12:53 PM   #624
cowboy_Rob
Member#: 194062
2003 Impreza WRX
You need to post an idiots guide to porting step by step guide. I've done turbo exhaust housings, ex manifolds and some minor gasket matching/smoothing work on a buddies spare cylinder head but I have no idea how much or where I should cleanup mine. I was informed after I built it that I should've ported it to get the most outta my big cams. Now its coming apart again so its time. Otherwise I guess I poke through all 40 pages of this till I'm not scared.
Old 02-17-2014, 01:14 PM   #625
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
This is Polish after 1000grit wet sand. I won't be doing that anymore for the exhaust. Gotta keep the bit lubed. You'll notice when it starts to clog up. I stop porting to clean the bit with another bit by hand running it in the grove with its teeth.
I've only done 120grit emery dry sand. Why no wet sanding lol no fun right?
Garrett GT Series Turbo port sizes WAYGONE1 Built Motor Discussion 1 08-25-2009 08:11 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
