Old 11-15-2010, 09:46 AM   #201
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This was fun and I will have to buy more silicone to make more molds.
FuJi K is online now   Reply With Quote
Old 11-15-2010, 09:54 AM   #202
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
We'll see what kind of a powerband this helps with. Heads will have GSC cams on them, stock valves, crower springs and retainers.
I'll be working with the exhaust ports on the D25 heads again. All the newer '07+ STi heads run this bigger exhaust port as well. We'll see what I can pull off with stock valves.
I'm trying to get them to flow as close to the B25 heads I've been working on. The difference is the width of the valve bowls between the two.
Old 11-15-2010, 12:03 PM   #203
frayz
Member#: 106909
2002 V7 STi Prodrive
Edition... Black!
Silicone moulds look really interesting. Is that between the small ports and JDM big ports?
frayz is online now   Reply With Quote
Old 11-15-2010, 12:54 PM   #204
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
fuji, what silicon did you use for your molds? looks like it finished really well and was easy to remove...never had both in the same silicon before
Old 11-15-2010, 06:48 PM   #205
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
That's between my ported D25 head and stock small port.
Ohh... it isn't as easy as it looks. hahah A tip was said to use WD40 to help remove the mold from the ports. You can't really pull it out. Takes some pushing from the combustion chamber side and also spraying some more WD40 on the sides, and down the valve guide.
you'd need TWO 1lb kits to really get two ports. I ALMOST got two ports but there wasn't enough to fill the 2nd port; which in this case the stock port.
Old 12-04-2010, 01:43 AM   #206
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Here are D25 exhaust ports. Mainly worked on the short turn radius and edges. Dog Leg work is done on the splitter near the roof. Where ever my bit touched, that's where porting was done. This is just a clean up without enlarging much. I DID cut down the guides and guide support on the roof. I did NOT enlarge the throat where the valve seat is so it still is stock there and also stock valve angles. We'll see how they flow compared to the stock numbers I already have. All the S20/D25/V25B/W25 heads run this exhaust port. The B25 heads do NOT run this exhaust port.
Old 12-04-2010, 09:07 AM   #207
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
dude, you post a lot of car related pron
Bad Noodle is offline   Reply With Quote
Old 12-06-2010, 10:16 AM   #208
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Short turn radius?? D25 head
Old 12-11-2010, 10:45 PM   #209
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
ok I have some heads that I want to start work on. Yet how do I remove the valve guides so I can get started?
Old 12-11-2010, 11:56 PM   #210
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Subaru has a valve guide remover. It slides into the guide, then comes to a stop. A press is used. Some machine shops may have different ways of removing guides such as using an air punch?
I made a tool just like this one. But my steel was too weak as I bought it from Menards. It serves the same goal.
For manual
http://www.cylinderheadsupply.com/handdrivers.html
For Air punch
http://www.cylinderheadsupply.com/airdrivers.html
Old 12-12-2010, 08:36 PM   #211
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Sounds like something I can't do with hand tools. Thanx
for the info.
Old 12-13-2010, 09:24 PM   #212
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Fuji removing valve guide material on the exhaust side is not recommended since it helps to pull heat from the valve head. It would be safer to shape the guide but leave it full length. That silicon is a cool idea, it really gives a good view of whats going on inside those ports.
Scoobie Steve is offline   Reply With Quote
Old 12-13-2010, 09:57 PM   #213
Homemade WRX
Member#: 33782
96 bastard child
So I'll order the 4lb kit to do a full head. Both exhaust ports, combustion chamber and an intake.
Old 12-16-2010, 01:39 PM   #214
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Flow numbers for post #206
Stock valves, stock valve angles, stock valve throat, measured on stock cams.
Exhaust (straight)
.100" = 81cfm
.200" = 160cfm
.300" = 194cfm
.396" = 213cfm
Exhaust (dog leg)
.100" = 78cfm
.200" = 155cfm
.300" = 186cfm
.396" = 202cfm
As with ALL the heads I flowed, they where measured with the stock cam lift profiles. I didn't check clearances to see how much but I did put on the thickest bucket I could find. Really the stock lift doesn't come close to .4" lift at all from what the dial gauge came out to be. I'll have to put on a fixture so it'll come out to what the actual lifts are. So to speak, with stock cams, this is what the flow numbers come out to be at maximum lift.
Old 12-16-2010, 03:34 PM   #215
cha86
Member#: 111048
I <3 debt
i see what you did there
cha86 is offline   Reply With Quote
Old 12-20-2010, 06:55 PM   #216
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
heres a bunch of numbers....i have no idea what they mean, but this guy collected lots of data
http://users.erols.com/srweiss/tablehdc.htm#Subaru
Old 12-20-2010, 07:14 PM   #217
CatfaceType-R
Member#: 81102
^^nice
CatfaceType-R is online now   Reply With Quote
Old 01-28-2011, 07:12 PM   #218
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Here's the LIP TREATMENT on the intake side; rounded off the sharp step of the valve seat. Keeping most of the throat size but making sure there is smoother flow from port runner past the valve seat. This lip on the seat is apparent on the B25 001 casting and also some S20 001-003 castings. Newer castings are better and match up better so the lips is less to minimal.
Here's a DD treatment with light valve seat blending. This was a B25 002 casting which had much better port to valve seat casting.
Here is a B25 001 casting. You can see that there is a fatter lip at the valve seat.
Old 01-30-2011, 02:04 AM   #219
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This is what happens when you have extreme DET. This part that chipped off is the part that has more clearance than the rest of the guide, which is the part I grind off. It's like a little relief at the tip of the guides, same with intake guides. It is because of this I was more confident in grinding down the guides. The guides I replaced was both exhaust guides on Cyl#4.
I'mma need a better valve guide remover.
Old 01-30-2011, 07:57 AM   #220
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
always love your write ups and pictures, my Ver8 heads are at the shop i did a light port on them, i should try the silicone just to see what mine look like, also it lookd pretty cool when they put in guides at the machine shop, they have different sizes, and put in the closest one, and run a bore through it with an air hammer to correct the size, and i have even seen them sleeve them.
seanathanq83 is offline   Reply With Quote
Old 01-30-2011, 09:12 AM   #221
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Hey dude, again thanks for the great info. So would you recommend grinding down the valve seats on both the intake and exhaust sides?
Old 01-30-2011, 10:45 AM   #222
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Seats or guides?
Old 01-30-2011, 08:30 PM   #223
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The lip you can round off. The diameter or say valve throat is up to you. Some say the inside diameter should be anywhere from 80-90% of the valve size. 87% throat to valve size is what TK383 uses.
http://forums.nasioc.com/forums/show...&postcount=160
Have your valve angles done first then blend.
Honda heads have some very simple angles and seat angles. They flow well but it may or may not work for our Subaru heads. I would like to find out...
Old 01-30-2011, 09:05 PM   #224
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Originally Posted by kellygnsd View Post
Seats or guides?
Sorry meant the guides. From what I've read, it isn't recommended but from the pics fuji posted it looks like a good idea.
Old 01-30-2011, 09:19 PM   #225
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
The lip you can round off. The diameter or say valve throat is up to you. Some say the inside diameter should be anywhere from 80-90% of the valve size. 85% throat to valve size is what TK383 uses.
Dude, even with all the help you've given me, I'm still lost on this topic. Like the idea hasn't clicked yet. I get lost in all the velocity vs volume vs lift stuff ...
So is do most of the gains come from fixing the factory casting (rounding the seats, knife-edging the dividers, smoothing the casting) or from reshaping the ports?
I don't have access to a flow bench nor the time to do the string flow tests. Original plan was to leave the heads alone, but if there are gains to be had by doing simple stuff like cleaning up the casting, than why not. I dunno, what would you recommend? Just leave it alone?
Garrett GT Series Turbo port sizes WAYGONE1 Built Motor Discussion 1 08-25-2009 08:11 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
