Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 03-25-2009, 11:12 PM   #1
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Default Cometic Gasket... looks warped?
I just got my cometic .040" gaskets for my 2.1 stroker I bought from MPS and they look all warped and wondere if it is normal since this is the first cometic I've ever held in my hand.
Here are some pics:
They are obviously tight where they are riveted together, but they just seem all curved and oil can like, if that makes sense. the layers are all spread apart at the edges where they are not riveted. I just want to make sure I contact the seller if these are not right.
Anybody with cometic experience please let me know.
Thanks
morrocco88 is offline   Reply With Quote
Old 03-26-2009, 12:35 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
They may look like that now. When they are installed, everything lays down and matches up like they should.
No worries!
Jay
Old 03-26-2009, 02:50 AM   #3
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
I was thinking they would all lay down, but wanted to make sure. I just thought they should not be all arched like they are. It makes me feel a little better though. I read that some have a rubber like layer on the mating surface and that you should not use a copper spray, but these are all metal, so I think I will use the spray. What do you think?
Old 03-26-2009, 08:33 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
That black surface on each outer layer is a coating. Copper spray is not necessary, but proper head and deck surface prep IS NECESSARY. Get them to the 50 RA or whatever that little ticket in the wrapper says.
Jay
Old 03-26-2009, 11:33 AM   #5
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
This situation raises another question all together. If Subaru went to great lengths to engineer a gasket system that would seal under the "changes" heat/boost/misuse.... Why change it? For those of you that have done any research you will see changing trends in MLS gaskets. It is no coincidence that the 03-04 Cobra or the New Zr1 corvette have 4-5 layer MLS gaskets over just adding a thicker steel core. The block/heads/fasteners have to "hold" the gasket into place, it's a system... Even Cometic is moving into adding more thin layers over a single thick core. On some engines like the Honda platforms you go back in and re-torque after a heat cycle to get the gasket to work well because of the fastener yield that is lost in the first heat cycle.
So what is the winning combination on this platform? I know that stock head bolts/stock gaskets work well.. So do you move into a headstud/cometic gasket system to improve on that? I have stopped using Cometic gaskets on the Stock block small block Fords because between the thin deck and small fasteners the thick gasket doesn't work out well. But in contrast a aftermarket block with 1/2 studs the cometics work perfectly...
I am not saying as a whole that the cometic is a bad idea for the EJ. I have not used them because I have not run into HG issues on the EJ's I work on. Maybe some members with more experience in this app can add there experience?
Jay Meagher
RealStreet is offline   Reply With Quote
Old 03-26-2009, 12:18 PM   #6
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
yes i must ask, why use cometic hg? arent the OEM ones good for enormous power numbers?
mxpunk is offline   Reply With Quote
Old 03-26-2009, 02:04 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Without diluting an otherwise informative thread, I will say that I have had OEM gaskets fail, but haven't had any failed Cometic gaskets. Maybe I'm lucky, unlucky, or just special.
Jay
Old 03-26-2009, 04:02 PM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
My cometic's looked like that, they seem to work just fine.
mick_the_ginge is offline   Reply With Quote
Old 03-26-2009, 05:41 PM   #9
benw
Member#: 103320
1998 swapped
Forester L
people who have milled heads, custom pistons, or who desire a specific combustion chamber shape/size. The OEM won't always work for everyone.
benw is offline   Reply With Quote
Old 03-26-2009, 05:47 PM   #10
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
^^^ Thanks Mick, now I really feel better!
I went to a Cometic to get a .040" thickness as recommended by MPS. This was due to the amount of metal taken off when the deck was surfaced, and the heads were surfaced. So they are both finished with the proper RA.
Since these do not have the rubber/viton layer, I think I will use the copper spray. I think Mick has used the spray with good results.
Old 03-26-2009, 05:51 PM   #11
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
FYI - I think all Cometic's have the viton layer: http://www.cometic.com/faq.aspx
Cometic does not recommend any additional glue as such. I don't do everything by the book. Works for me, may not work for others. Just putting that out their.
Old 03-26-2009, 06:08 PM   #12
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Copper spray + Comectics, over 15K now and no issues...
Fongers is offline   Reply With Quote
Old 03-26-2009, 10:41 PM   #13
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
I wonder if I got an older set then, because these are all steel with no viton layer. That's why I wanted to use the spray.
Old 03-26-2009, 11:36 PM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
See how the outer surfaces are black? That's the viton layer. If yours are bare metal, send them back.....but I can see the black in the pics.
Jay
Old 03-27-2009, 01:58 AM   #15
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Trust me, there is no black on them, and there is no rubber or viton or anything. They are just steel. The part number is C4261-040. They should be fine right?
Old 03-27-2009, 08:21 AM   #16
Storm
Member#: 5218
96L Most Over-
Developed Beater
Post another picture looking down on them please. They should have a black coating on the outer surface layers..... If they don't, the layers are either mixed up or something else. It's a relatively small operation at the factory.....I can't see how they could get out the door that way.
Additionally, if you can PM me....I can likely get you a set that is correct and turn those back in.
Jay Storm
Urgent Wtb Ej22 Cometic Gasket macaws Private 'Wanted' Classifieds 0 09-11-2006 03:33 PM
Cometic Gasket for hybrid swap k_thaosta Private 'Wanted' Classifieds 8 03-28-2006 11:49 AM
Stock or Cometic Gaskets? powerlabs Built Motor Discussion 19 03-21-2006 11:58 AM
Cometic gaskets and 2.0 compression ebeck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-28-2004 05:36 PM
Cometic gasket and 2.5 STI hybrid users RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-06-2004 07:52 PM
