Old 11-29-2012, 12:11 PM   #2101
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by NoGraffix View Post
It'd be great if the community would have someone continue this
You're hired
Old 11-29-2012, 12:21 PM   #2102
NoGraffix
Member#: 276209
I am Rub
Function>Form
Originally Posted by kellygnsd View Post
You're hired
If it's just to keep a thread updated and plot airboy's I could easily do that
NoGraffix is offline   Reply With Quote
Old 02-26-2013, 01:20 PM   #2103
abelconce
Member#: 346909
2003 ADM WRX
Code:
Time (msec)	A/F Correction #1 (%)	A/F Learning #1 (%)	A/F Sensor #1 (AFR)	Engine Load (Calculated) (g/rev)	Engine Speed (rpm)	Feedback Knock Correction* (degrees)	Fine Learning Knock Correction* (degrees)	IAM* (raw ecu value)	Ignition Total Timing (degrees)	Injector Duty Cycle (%)	Intake Air Temperature (F)	Manifold Absolute Pressure (psi)	Manifold Relative Pressure (Corrected) (psi)	Mass Airflow (g/s)	Mass Airflow Sensor Voltage (V)	Throttle Opening Angle (%)	Vehicle Speed (mph)
357594	0	0	14.7	1.11	2032	0	0	14	19.5	11.46	95	16.25	1.6	38.24	2.5	100	23
357672	0	0	14.01	1.11	2066	0	0	14	19	11.62	95	16.4	1.74	38.63	2.52	100	24
357750	0	0	13.09	1.12	2078	0	0	14	19	11.53	95	16.4	1.74	38.75	2.52	100	24
357828	0	0	12.86	1.11	2101	0	0	14	19	11.65	95	16.54	1.89	39.02	2.52	100	24
357906	0	0	12.4	1.11	2146	0	0	14	19	11.9	95	16.54	1.89	39.82	2.52	100	24
357969	0	0	12.4	1.14	2113	0	0	14	19	11.98	95	16.69	2.03	39.69	2.54	100	24
358047	0	0	12.4	1.12	2160	0	0	14	19	12.1	95	16.69	2.03	40.22	2.56	100	24
358125	0	0	12.52	1.12	2181	0	0	14	19	12.12	95	16.69	2.03	40.62	2.56	100	26
358203	0	0	12.52	1.13	2185	0	0	14	19	12.37	95	16.83	2.18	41.85	2.58	100	26
358281	0	0	12.52	1.13	2227	0	0	14	19	12.35	95	16.98	2.32	41.84	2.54	100	26
358344	0	0	12.4	1.12	2243	0	0	14	19	12.44	95	16.98	2.32	41.71	2.58	100	26
358422	0	0	12.63	1.12	2282	0	0	14	19	12.59	95	16.98	2.32	42.54	2.6	100	26
358500	0	0	12.52	1.13	2270	0	0	14	19	12.85	95	17.12	2.47	42.54	2.6	100	26
358578	0	0	12.52	1.14	2316	0	0	14	19	12.83	95	17.27	2.61	44.06	2.6	100	26
358656	0	0	12.63	1.14	2313	0	0	14	18.5	12.93	95	17.41	2.76	44.47	2.6	100	28
358735	0	0	12.52	1.14	2372	0	0	14	18.5	13.16	95	17.41	2.76	45.16	2.62	100	28
358797	0	0	12.52	1.15	2372	0	0	14	18.5	13.16	95	17.56	2.9	45.57	2.64	100	28
358875	0	0	12.63	1.14	2397	0	0	14	18.5	13.81	95	17.56	2.9	45.72	2.66	100	28
358953	0	0	12.52	1.18	2417	0	0	14	18	14.01	95	17.7	3.05	46.7	2.66	100	28
359031	0	0	12.63	1.18	2432	0	0	14	18	14.1	95	17.7	3.05	47.54	2.7	100	28
359110	0	0	12.86	1.18	2448	0	0	14	18	14.22	95	17.85	3.19	48.53	2.68	100	30
359188	0	0	12.63	1.19	2470	0	0	12	17	14.24	95	17.99	3.34	49.1	2.72	100	30
359250	0	0	12.75	1.2	2507	0	0	12	17	14.44	95	18.14	3.48	50.1	2.72	100	30
359328	0	-0.78	12.86	1.2	2540	0	0	12	17	14.63	95	18.14	3.48	50.67	2.72	100	30
359406	0	-0.78	12.86	1.21	2535	0	0	12	17	15.14	95	18.28	3.63	51.24	2.74	100	30
359485	0	-0.78	12.98	1.23	2552	0	0	12	17	15.53	95	18.43	3.77	51.38	2.74	100	30
359563	0	-0.78	12.75	1.23	2600	0	0	12	17.5	15.48	95	18.43	3.77	52.52	2.78	100	31
359625	0	-0.78	12.86	1.22	2592	0	0	12	17	15.71	95	18.57	3.92	53.33	2.78	100	31
359703	0	-0.78	12.75	1.24	2630	0	0	12	17	15.85	95	18.86	4.21	54.76	2.78	100	31
359781	0	-0.78	12.98	1.25	2632	0	0	12	17	15.72	95	18.86	4.21	54.76	2.8	100	31
359860	0	-0.78	12.98	1.25	2680	0	0	12	17	16.58	95	19.01	4.35	55.94	2.84	100	31
359938	0	-0.78	12.98	1.28	2693	0	0	12	17	16.71	95	19.15	4.5	57.33	2.86	100	31
360016	0	-0.78	12.98	1.3	2702	0	0	12	16.5	17.03	95	19.3	4.64	57.33	2.88	100	33
360078	0	-0.78	12.86	1.33	2752	0	0	12	16.5	17.52	95	19.3	4.64	60.8	2.88	100	33
360156	0	-0.78	12.98	1.32	2738	0	0	12	16.5	17.8	95	19.59	4.93	61.33	2.9	100	33
360235	0	-0.78	12.86	1.37	2786	0	0	12	16	18.42	95	19.88	5.22	63.64	2.92	100	33
360313	0	-0.78	12.98	1.37	2813	0	0	12	15.5	18.6	93	20.02	5.37	64.18	2.92	100	33
360391	0	-0.78	12.98	1.39	2854	0	0	12	15.5	19.48	93	20.17	5.51	66	2.98	100	33
360469	0	-0.78	12.86	1.4	2862	0	0	12	15.5	19.87	93	20.31	5.66	67.46	3.02	100	33
360547	0	-0.78	12.86	1.47	2911	0	0	12	15.5	20.5	93	20.6	5.95	69.3	3	100	35
360610	0	-0.78	12.86	1.48	2911	0	0	12	14.5	20.54	93	20.75	6.09	71.87	3.04	100	35
360688	0	-0.78	12.75	1.51	2918	0	0	12	14.5	21.42	93	21.18	6.53	74.3	3.08	100	35
360766	0	-0.78	12.63	1.53	2988	0	0	12	14.5	22.31	93	21.47	6.82	75.98	3.1	100	35
360844	0	-0.78	12.52	1.55	3004	0	0	12	14.5	22.43	93	21.76	7.11	77.5	3.12	100	35
360922	0	-0.78	12.52	1.58	3020	0	0	12	14.5	23.84	93	22.05	7.4	79.46	3.1	100	35
360985	0	-0.78	12.4	1.58	3051	0	0	12	14	25.04	93	22.35	7.69	80.86	3.2	100	37
361063	0	-0.78	12.29	1.66	3089	0	0	12	14	25.63	93	22.64	7.98	82.69	3.2	100	37
361172	0	-0.78	12.4	1.67	3080	0	0	12	14	26.17	93	22.93	8.27	87.35	3.24	100	37
361235	0	-0.78	12.29	1.72	3152	0	0	12	14	26.9	93	23.65	9	90.53	3.2	100	37
361297	0	-0.78	12.17	1.73	3179	0	0	12	14	27.81	93	23.94	9.29	91.67	3.24	100	37
361375	0	-0.78	12.29	1.78	3200	0	0	12	14	29.35	93	24.38	9.72	94.66	3.28	100	37
361453	0	-0.78	12.17	1.82	3249	0	0	12	14	30.51	93	24.81	10.16	97.55	3.34	100	39
361516	0	-0.78	12.17	1.89	3251	0	0	12	13	31.77	93	25.1	10.45	101.06	3.4	100	39
361594	0	-0.78	12.17	1.92	3310	0	0	12	12	32.38	93	25.54	10.88	105.83	3.44	100	39
361672	0	-0.78	12.17	1.95	3299	0	0	12	12	33.7	93	26.41	11.75	108.98	3.48	100	39
361750	0	-0.78	12.17	2.02	3395	0	0	12	12	35.49	93	26.99	12.33	114.41	3.46	100	39
361828	0	-0.78	12.06	2.07	3389	0	0	12	12	36.87	93	27.42	12.77	117	3.54	100	39
361891	0	-0.78	12.06	2.13	3451	0	0	12	12	39.76	93	28	13.35	122.72	3.64	100	40
361969	0	-0.78	12.06	2.15	3477	0	0	12	11.5	42.92	93	28.44	13.78	125	3.66	100	40
362047	0	-0.78	11.94	2.32	3529	0	0	12	12	44	93	29.02	14.36	131.99	3.66	100	40
362125	0	-0.78	11.94	2.3	3556	0	0	12	12	43.98	93	30.04	15.38	135.98	3.76	100	40
362203	0	-0.78	11.94	2.43	3639	0	0	12	12	47.35	93	30.62	15.96	147.26	3.82	100	40
362281	0	-0.78	11.94	2.56	3620	0	0	12	11.5	49.42	93	31.34	16.69	154.73	3.86	100	40
362360	0	-0.78	11.94	2.62	3735	0	0	12	11	52.59	93	32.21	17.56	162.9	3.96	100	44
362422	0	-0.78	11.94	2.65	3711	0	0	12	10.5	55.87	93	32.65	17.99	162.9	3.94	100	44
362500	0	-0.78	11.94	2.79	3796	0	0	12	10.5	56.94	93	33.37	18.72	173.99	3.94	100	44
362578	0	-0.78	11.94	2.82	3813	0	0	12	10.5	58.22	91	33.37	18.72	180.44	4.02	100	44
362656	0	-0.78	11.94	2.8	3844	0	0	12	10.5	59.22	91	34.39	19.73	182.71	4.02	100	44
362735	0	-0.78	11.94	2.84	3910	0	0	12	10.5	60.47	91	34.82	20.17	186.03	4	100	44
362813	0	-0.78	11.94	2.8	3976	0	0	12	10.5	61.93	91	35.55	20.89	185.79	4.04	100	44
362875	0	-0.78	11.94	2.8	3978	0	0	12	10.5	61.11	91	35.4	20.75	185.47	4.06	100	47
362953	0	-0.78	11.94	2.75	4080	0	0	12	10.5	62.44	91	35.26	20.6	189.07	4.04	100	47
363031	0	-0.78	11.94	2.76	4065	0	0	12	10.5	62.93	91	35.84	21.18	189.51	4.06	100	47
363110	0	-0.78	11.94	2.7	4155	0	0	12	11	62.29	91	35.69	21.04	187.43	4.04	100	47
363188	0	-0.78	11.94	2.73	4171	0	0	12	11	62.88	91	35.4	20.75	191.46	4.1	100	47
363250	0	-0.78	11.94	2.66	4268	0	0	12	11.5	63.74	91	34.82	20.17	189.51	4.12	100	47
363328	0	-0.78	11.94	2.57	4308	0	0	12	11.5	62.49	91	34.97	20.31	184.75	4.06	100	50
363422	0	-0.78	11.94	2.63	4315	0	0	12	11.5	63.52	91	34.82	20.17	188.87	4.14	100	50
363485	0	-0.78	11.94	2.64	4383	0	0	12	11.5	64.52	91	34.68	20.02	192.91	4.14	100	50
363563	0	-0.78	11.94	2.65	4412	0	0	12	11.5	67.14	91	34.68	20.02	196.52	4.12	100	50
363953	0	-0.78	11.94	2.64	4496	0	0	12	11.5	67.47	91	34.68	20.02	197.6	4.12	100	50
363995	0	-0.78	11.94	2.61	4518	0	0	12	11.5	67.88	91	35.11	20.46	200.5	4.12	100	50
363995	0	-0.78	11.94	2.62	4545	0	0	12	11.5	68.66	91	34.82	20.17	200.86	4.14	100	53
364012	0	-0.78	11.94	2.54	4598	0	0	12	11.5	67.2	91	34.97	20.31	195.8	4.12	100	53
364046	0	-0.78	11.94	2.55	4632	0	0	12	12	68	91	34.82	20.17	199.05	4.14	100	53
364062	0	-0.78	11.94	2.5	4728	0	0	12	12	67.59	91	34.82	20.17	197.24	4.12	100	53
364250	0	-0.78	11.94	2.51	4817	0	0	12	12	69.87	91	34.68	20.02	201.21	4.16	100	53
364266	0	-0.78	11.94	2.52	4759	0	0	12	12	69.03	91	34.82	20.17	200.13	4.16	100	53
364297	0	-0.78	11.94	2.53	4864	0	0	12	12.5	70.55	91	34.68	20.02	205.41	4.2	100	58
364313	0	-0.78	11.83	2.59	4857	0	0	12	12.5	70.46	90	34.68	20.02	209.33	4.22	100	58
364391	0	-0.78	11.83	2.55	4957	0	0	12	12.5	71.91	90	34.68	20.02	210.55	4.22	100	58
364500	0	-0.78	11.83	2.61	4947	0	0	12	12.5	72.82	90	34.68	20.02	215.42	4.24	100	58
364547	0	-0.78	11.83	2.56	5030	0	0	12	12.5	72.97	90	34.68	20.02	214.2	4.24	100	58
364625	0	-0.78	11.83	2.55	5088	0	0	12	13	73.81	90	34.53	19.88	215.83	4.24	100	58
364703	0	-0.78	11.83	2.57	5088	0	0	12	13	75.56	90	34.53	19.88	219.47	4.28	100	58
364766	0	-0.78	11.83	2.57	5133	0	0	12	13	76.29	90	34.39	19.73	221.91	4.28	100	62
364844	0	-0.78	11.83	2.56	5183	0	0	12	13	76.99	90	34.39	19.73	221.91	4.28	100	62
364930	0	-0.78	11.71	2.56	5230	0	0	12	13	76.99	90	34.39	19.73	222.72	4.32	100	62
365008	0	-0.78	11.71	2.61	5259	0	0	12	13	77.42	90	34.24	19.59	228.62	4.32	100	62
365081	0	-0.78	11.71	2.57	5357	0	0	12	13	78.86	90	34.39	19.73	229.4	4.32	100	62
365156	0	-0.78	11.71	2.57	5372	0	0	12	13	79.08	90	34.39	19.73	230.18	4.34	100	62
365232	0	-0.78	11.71	2.62	5372	0	0	12	13	80.8	90	34.39	19.73	236.04	4.36	100	65
365307	0	-0.78	11.71	2.62	5411	0	0	12	13	79.94	90	34.39	19.73	236.04	4.34	100	65
365382	0	-0.78	11.71	2.58	5430	0	0	12	13	79.94	90	34.39	19.73	233.69	4.34	100	65
365459	0	-0.78	11.71	2.58	5519	0	0	12	13.5	81.24	90	34.53	19.88	237.6	4.36	100	65
365533	0	-0.78	11.71	2.56	5519	0	0	12	13.5	80.65	90	34.53	19.88	237.6	4.38	100	65
365614	0	-0.78	11.6	2.56	5560	0	0	12	13.5	81.19	90	34.53	19.88	237.6	4.38	100	65
365686	0	-0.78	11.6	2.57	5597	0	0	12	13.5	81.19	90	34.39	19.73	239.94	4.38	100	68
365763	0	-0.78	11.6	2.54	5699	0	0	12	14	82.67	90	34.24	19.59	241.5	4.4	100	68
365836	0	-0.78	11.6	2.54	5699	0	0	12	14	82.8	90	34.24	19.59	241.89	4.38	100	68
365913	0	-0.78	11.6	2.54	5708	0	0	12	14	83.03	90	34.24	19.59	241.89	4.42	100	68
365988	0	-0.78	11.6	2.52	5809	0	0	12	14	83.03	90	34.1	19.44	244.02	4.42	100	68
366066	0	-0.78	11.6	2.51	5836	0	0	12	14	83.42	90	34.1	19.44	244.47	4.42	100	68
366139	0	-0.78	11.6	2.53	5836	0	0	12	14	83.42	90	34.1	19.44	245.81	4.42	100	71
366217	0	-0.78	11.6	2.53	5836	0	0	12	14	83.42	90	34.24	19.59	245.81	4.42	100	71
366294	0	-0.78	11.6	2.49	5938	0	0	12	14.5	83.61	90	33.95	19.3	246.71	4.42	100	71
366365	0	-0.78	11.6	2.45	5938	0	0	12	15	83.93	90	33.95	19.3	246.71	4.44	100	71
366443	0	-0.78	11.6	2.45	6053	0	0	12	15	83.93	90	33.95	19.3	246.71	4.44	100	71
366519	0	-0.78	11.6	2.47	6082	0	0	12	15	85.64	90	33.95	19.3	250.75	4.44	100	71
366587	0	-0.78	11.48	2.47	6082	0	0	12	15	85.92	90	33.95	19.3	251.2	4.46	100	75
366672	0	-0.78	11.48	2.47	6102	0	0	12	15	85.92	90	33.66	19.01	251.2	4.46	100	75
366748	0	-0.78	11.48	2.43	6198	0	0	12	15.5	85.95	90	33.66	19.01	251.2	4.44	100	75
366821	0	-0.78	11.48	2.42	6198	0	0	12	15.5	86.74	90	33.66	19.01	251.2	4.46	100	75
366899	0	-0.78	11.48	2.42	6255	0	0	12	17.5	86.74	90	33.66	19.01	252.55	4.46	100	75
366975	0	-0.78	11.48	2.41	6318	0	0	12	17.5	87.61	90	33.66	19.01	253.89	4.46	100	75
367052	0	-0.78	11.48	2.41	6318	0	0	12	17.5	86.27	90	33.66	19.01	253.89	4.48	100	75
367148	0	-0.78	11.48	2.4	6366	0	0	12	17.5	86.92	88	33.52	18.86	254.34	4.48	100	78
367214	0	-0.78	11.48	2.38	6366	0	0	12	17.5	87.74	88	33.52	18.86	254.34	4.48	100	78
367278	0	-0.78	11.48	2.38	6426	0	0	12	17.5	87.74	88	33.52	18.86	254.79	4.48	100	78
367353	0	-0.78	11.48	2.36	6426	0	0	12	17.5	87.04	88	33.52	18.86	255.24	4.48	100	78
367434	0	-0.78	11.48	2.36	6476	0	0	12	17.5	87.04	88	33.52	18.86	255.24	4.48	100	78
367507	0	-0.78	11.37	2.34	6544	0	0	12	17.5	87.95	88	33.52	18.86	254.79	4.48	100	78
367579	0	-0.78	11.37	2.34	6544	0	0	12	17.5	87.95	88	33.52	18.86	254.79	4.48	100	81
367657	0	-0.78	11.37	2.33	6608	0	0	12	18	87.4	88	33.37	18.72	256.59	4.48	100	81
367720	0	-0.78	11.37	2.33	6608	0	0	12	18	87.4	88	33.37	18.72	256.59	4.48	100	81
367798	0	-0.78	11.37	2.33	6654	0	0	12	18.5	88.02	88	33.23	18.57	258.51	4.48	100	81
367876	0	-0.78	11.37	2.33	6654	0	0	12	18.5	88.89	88	33.23	18.57	258.51	4.5	100	81
367954	0	-0.78	11.37	2.31	6720	0	0	12	18.5	88.89	88	33.23	18.57	258.51	4.5	100	81
368032	0	-0.78	11.37	2.31	6720	0	0	12	18.5	87.45	88	33.23	18.57	258.51	4.48	100	84
368111	0	-0.78	11.37	2.29	6720	0	0	12	19	87.45	88	33.37	18.72	257.04	4.48	100	84
368173	0	-0.78	11.37	2.29	6720	0	0	12	19	87.45	88	33.37	18.72	257.04	4.48	100	84
368251	0	-0.78	11.37	2.29	6781	0	0	12	19	88.24	88	33.37	18.72	258.51	4.5	100	84
368329	0	-0.78	11.37	2.29	6781	0	0	12	19	88.24	88	33.37	18.72	258.51	4.5	100	84
368407	0	-0.78	11.25	2.25	6900	0	0	12	19	88.31	88	33.37	18.72	258.51	4.5	100	84
368486	0	-0.78	11.25	2.25	6900	0	0	12	19	88.31	88	33.37	18.72	258.51	4.5	100	86
368564	0	-0.78	11.25	2.25	6906	0	0	12	19.5	86.92	88	33.37	18.72	258.51	4.48	100	86
368642	0	-0.78	11.25	2.25	6906	0	0	12	19.5	86.92	88	33.37	18.72	258.51	4.48	100	86
368704	0	-0.78	11.25	2.21	6906	0	0	12	19.5	87.81	88	33.37	18.72	258.51	4.48	100	86
368782	0	-0.78	11.25	2.21	6976	0	0	12	19.5	87.81	88	33.37	18.72	256.59	4.48	100	86
And these are my mods:
Car: ADM 2003 WRX
Engine: EJ20
Turbo: vf48
Turbo Intake: short Cobb
Intercooler: Oem 2008 Sti
Filter/Intake: -
MAF size: stock
Exhaust: 3" Apexi turbo back / Megan Racing Uppipe
Injectors: Oem sti 2008
Fuel Pump: Wallbro 255
Log gear: 3rd
Tyre Size: 235/40/18
Delta Weight: 250
abelconce is offline   Reply With Quote
Old 05-12-2013, 01:46 AM   #2104
ogboot
Member#: 170906
psm
Do we have an official vdyno thread?
ogboot is offline   Reply With Quote
Old 05-12-2013, 09:44 AM   #2105
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Nope!
Old 06-11-2013, 04:07 AM   #2106
775WRX
Member#: 348189
2003 Impreza WRX
Midnight Blue
I am un aware how accurate this is for Dyno plots but im running 176 hp with a custom tune haha
775WRX is offline   Reply With Quote
Old 06-20-2013, 07:14 AM   #2107
juanmedina
Member#: 133146
Airboy record
As far as I know this is the 3rd car breaking 500whp with Airboy road dyno.
Old 06-20-2013, 04:47 PM   #2108
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I'll send some logs of my 67mm to you and car weight at say 33 psi and we can see what it does
stretchedk7 is offline   Reply With Quote
Old 06-22-2013, 06:31 AM   #2109
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Originally Posted by juanmedina View Post
Airboy record
Looks like i need to do one Juan. Can't let you win. Lol
renosubby is offline   Reply With Quote
Old 06-23-2013, 10:13 AM   #2110
juanmedina
Member#: 133146
Sure!
Haha sounds good.
Old 06-23-2013, 10:50 AM   #2111
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
at least that way i can have an idea of what it makes on wastegate and on up as i tune it.
Old 06-27-2013, 02:17 AM   #2112
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
sorry juan
Old 06-27-2013, 07:11 AM   #2113
juanmedina
Member#: 133146
You had to ruin my vacation, Ron! .....
Very nice, you must be liking that E85
Old 06-29-2013, 05:32 PM   #2114
juanmedina
Member#: 133146
Old 08-01-2013, 11:58 AM   #2115
Tadder
Member#: 296842
2008 Impreza
E85 is great, but for those of us that dont want to change injectors and pump are there any E30, 40, 50 tunes out there. We have blender pumps here in SD that sell different blends of E. I guess it might be interesting to see what blend of E would be ideal and safe for stock injectors and fuel pumps, say for a stock 08 STi.
Tadder is offline   Reply With Quote
Old 08-01-2013, 04:03 PM   #2116
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
FYI, I just tuned an 09 STI on 15%E and it max out with stock boost levels. He is definitely getting 1000cc injectors next paycheck .
gaby is offline   Reply With Quote
official? sporename buddy list thread daveB Off-Topic 18 09-20-2008 07:22 PM
Smashing Pumpkins tribute record OFFICIAL ARTIST / TRACK LISTING released! chris619 Off-Topic 38 06-09-2005 10:58 PM
Official Dealer Pricing Lists forcefedfour STi Forum Archive 149 09-09-2003 06:25 PM
Home Dyno/Road Dyno Thumper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-20-2002 09:23 PM
Official GT3 Car List direwlf General Forum Archive 8 01-02-2001 12:10 AM
