Old 03-26-2009, 12:08 AM   #1
RallyColtTurbo
Member#: 16819
Default AVCS head interchange
Having a hard time nailing down pics and solid info, but can anyone say with certainty that all the single AVCS heads use the same AVCS solinoid and electrical connectors?
I'm using a complete '05 Legacy GT harness for a Subaru based "kit" type car. I'm assuming I can use any single (intake only) AVCS head and the connectors will plug in.
IIRC the '04-'08 FXT, Baja turbo, '06-'07 WRX, '05+ LGT, V7/V8 STI, JDM/EDM GD/GG AVCS WRX and '04-'07 USDM STI heads should all be compatable. Not concerned with flow/cams/compression ATM, speaking strictly physically and electrically for now.
I think I have it figured out, but I'd feel better with some first hand confirmation.
RallyColtTurbo is offline   Reply With Quote
Old 03-26-2009, 02:22 AM   #2
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i know the sti and v8 jdm sti use the same if that helps you out
seanathanq83 is offline   Reply With Quote
Directions how to install AVCS heads in a non AVCS car and not use AVCS sgiord86 Built Motor Discussion 1 11-19-2009 04:31 PM
AVCS Heads on Non-AVCS blocks. readymix Built Motor Discussion 43 03-27-2009 10:30 PM
AVCS Heads in a non AVCS Car? Token-Negro Built Motor Discussion 1 04-29-2006 11:15 AM
AVCS heads ---> non-AVCS use??? Peeblesmx445 Built Motor Discussion 14 03-19-2006 10:06 PM
Running AVCS heads without AVCS? Rizzo314 Subaru Conversions 5 06-01-2004 05:46 PM
