Old 03-26-2009, 12:03 PM   #1
Member#: 182734
03 Wagon
Default Singlescroll Gt30 vs. Twinscroll Gt35 Results Inside
Fresh off the dyno from last night. I built this twinscroll kit for a customer of ours that uses the car on the road course. He wanted the response of his old Gt30 with a little bit more power. I think we met those requirements! This is not exactly an apples to apples comparison as we did use one of my prototype intake manifolds on the Gt35 setup, but I think it shows even more in favor of the twinscroll setup because the manifold should in theory make it spool slower. The Gt30 used a T3 .82 A/R hotside and the Gt35 is using a T4 twinscroll .84 A/R hotside. Take a look at that power all the way to 8K rpm!!
Brandon
Brandon@TXS is offline   Reply With Quote
Old 03-26-2009, 12:05 PM   #2
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
That's most excellent....Race gas I take it?
TAPOUT is offline   Reply With Quote
Old 03-26-2009, 12:08 PM   #3
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
wow spool was almost the same.....very nice results!
blowbyu24 is offline   Reply With Quote
Old 03-26-2009, 12:09 PM   #4
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
You sure that was a T4 .84 twin scroll? Who made the turbo?
Token-Negro is offline   Reply With Quote
Old 03-26-2009, 12:19 PM   #5
Member#: 182734
03 Wagon
I placed the order for the turbo from FP myself. Fuel was VP C16.
Old 03-26-2009, 01:18 PM   #6
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
wow 35 spooled faster, sweet
seanathanq83 is offline   Reply With Quote
Old 03-26-2009, 02:48 PM   #7
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Very cool, but the 30R spool seem pretty late in the first place? You didn't mention cams, so that could be the key variable.
Just for comparison, look at my torque with the 30R .82:
Your 30R crosses 300 lb-ft at 4500rpm, while this .82 does it at 3800rpm. This is a stock 08 head, built bottom end setup, nothing special. This is however using meth+pump, but I was more interested in the spool area then the peak. What hold and run time were you using?
None the less, that 35R spoolup looks very nice, and the upper end power is very very nice. I like it!
sponaugle is offline   Reply With Quote
Old 03-26-2009, 03:11 PM   #8
Member#: 182734
03 Wagon
You're right, the 30 was a bit lazy. I did forget to mention that the car has Cosworth heads/cams but they were on it for both the 30 and 35. We used a 4 second hold, 16 second ramp time. I am really impressed with the way this car makes power at RPM. I believe that this may be the final design for our intake manifold. With all the Subarus that have been on our dyno, I have never seen one make peak power past 7K!
Brandon
Old 03-26-2009, 04:41 PM   #9
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Brandon
Indeed that is some very good high end flow. I usually see hp falling pretty good above 7500, so you have a good matched setup.
The spoolup difference with the 30R might be something related to the AVCS and the cosworth cams.
Very cool stuff.
Jeff
Old 03-26-2009, 08:07 PM   #10
wrxhard
Member#: 108091
Originally Posted by sponaugle View Post
This is a stock 08 head, built bottom end setup...
Considering this was a customers car, i highly doubt it was an 08, which, correct me if i'm wrong, has dual avcs which GREATLY affects spool characteristics of a given turbocharger.
Plus, dynapack graphs always look lazy They just don't load the car down like a mustang i'm guessing.
I for one am quite impressed with the results, as the 35r made more power EVERYWHERE on the graph. New manifold or not, those are some pretty impressive results.
wrxhard is offline   Reply With Quote
Old 03-26-2009, 09:25 PM   #11
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
While the 08's Exhaust AVCS does help out a bit, I suspect that 30R tune had something setup unusual with it's own Intake AVCS. I had a Dynapak and indeed the loading mechnism sucks as it waits for torque to be applied to start resisting. None the less, the twin scroll setup is nice. 35R is such a nice turbo.
Jeff
Old 03-27-2009, 12:47 AM   #12
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Something is way wrong with the 30r max torque at 5100rpm???? lol no way...
TDagen is offline   Reply With Quote
Old 03-27-2009, 12:56 AM   #13
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
pics....
SuperSTI is offline   Reply With Quote
Old 03-27-2009, 12:56 AM   #14
Member#: 182734
03 Wagon
I will agree with Jeff in regards to the AVCS not being optimized for the Gt30 setup, but we didn't make any changes to the AVCS settings for the Gt35. I think both setups had a bit more in them, but it is what it is.
Brandon
Old 03-27-2009, 10:46 AM   #15
MXJS
Member#: 129793
2004 STI
LSX RX-7
Is this going to become a production turbo kit?
MXJS is offline   Reply With Quote
Old 03-27-2009, 11:24 AM   #16
Member#: 182734
03 Wagon
It's not out of the realm of possibilities!
Old 03-27-2009, 11:29 AM   #17
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Wait, that's flywheel hp ratings?
I saw this car in person when some guy drove it over to Andrewtech. Sounds mean.
D Money is offline   Reply With Quote
Old 03-27-2009, 11:34 AM   #18
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
no they are wheel hp.
Paul
trbowrx is offline   Reply With Quote
Old 03-27-2009, 12:52 PM   #19
MXJS
Member#: 129793
2004 STI
LSX RX-7
I am running the TXS singlescroll kit right now and i love it, especially for how much it costs and the ability to buy it without a turbo. If you do produce it and price it competitively like you do with the singlescroll, i will be ordering one!
Old 03-28-2009, 01:53 AM   #20
rcebowl
Member#: 170246
Look for new
subie
ya any pictures of the kit too =D?
rcebowl is online now   Reply With Quote
Old 03-28-2009, 03:01 AM   #21
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Great stuff, thanks for posting this.
Twinscroll Borgwarner vs Twinscroll GT35R Full-Race Geoff Proven Power Bragging 345 09-24-2010 01:14 PM
GT30 vs GT35 on V7 motor wrxss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 48 02-20-2007 11:59 PM
Is this a modified GT30, GT32 or GT35? reddevil Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-05-2007 03:40 AM
More twinscroll dyno results. typer_126 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 01-05-2005 01:46 AM
