Old 03-26-2009, 01:24 PM   #1
madmax718
Member#: 172501
Default Reusing Head Gaskets
May seem silly, and I have a set of new already, but...
can you reuse a set of MLS head gaskets? (in particular, I have the 4 layer subaru oem). Its for the same block.
It was only on for 200 miles. when I took it off, it looked new, no deformation, no shape change.. not even a dent.
madmax718 is offline   Reply With Quote
Old 03-26-2009, 01:26 PM   #2
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
I wouldn't chance, especially if you have new ones. The amount of time it takes to replace them(if they go bad) is enough to make me put new ones on for piece of mind.
quadtard is offline   Reply With Quote
Old 03-26-2009, 01:35 PM   #3
madmax718
Member#: 172501
That was my train of thought. Thats why I have new ones. Just seems like such a waste to toss a set of gaskets that might be reusable.
Old 03-26-2009, 02:05 PM   #4
wgknestrick
Member#: 32576
04 STI
Why would you ever, ever, ever think of doing this? You shouldn't even reuse head bolts, but the head gasket........
wgknestrick is offline   Reply With Quote
Old 03-26-2009, 02:05 PM   #5
MrSlowbaru
Member#: 129231
2005 wrx
cgm
def use your better judgement, and use new ones
MrSlowbaru is offline   Reply With Quote
Old 03-26-2009, 04:07 PM   #6
madmax718
Member#: 172501
it saves 30 bucks toward another rebuild?
I have it, just ,.. you know, why waste something that can potentially be reused?
Old 03-26-2009, 06:11 PM   #7
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I have done it a few times, and no issues. But the one time I was FORCED to reuse one it failed.
Even I, king of cheap, buy new headgaskets.
Old 03-26-2009, 11:06 PM   #8
wgknestrick
Member#: 32576
04 STI
Old 03-26-2009, 11:19 PM   #9
Brydon
Member#: 107569
1998 Forester S
SRP
Why does everyone say never reuse head bolts?? I've done this at least 20 times with no issue and cars up to about 500whp. Does anyone see problem reusing bolts?
Brydon is offline   Reply With Quote
Old 03-26-2009, 11:22 PM   #10
Abest10
Member#: 190962
00 STM RS
04 FXT
You never reuse headgaskets.
Abest10 is offline   Reply With Quote
Old 03-26-2009, 11:37 PM   #11
madmax718
Member#: 172501
You can reuse head bolts, but there is an overall length that needs to be checked. Sometimes they stretch, other times, they dont. Just variances in the metal.
Head gasket.. Lets just say Im not going to use it, but, Im not throwing it away either. Might need it for a rainy track side rebuild or something...
Old 03-26-2009, 11:42 PM   #12
edo2000
Member#: 68709
2012 WRX
red
One school of thought says that the bolts can fatigue/elongate/weaken by being installed more than once. It never made sense to me for applications where you are staying somewhere in the same ballpark as stock power. I too have reused headbolts successfully.
On the other hand, if you are more than doubling stock power (500whp), maybe you need aftermarket headbolts for strength....
edo2000 is offline   Reply With Quote
Old 03-27-2009, 12:06 AM   #13
Brydon
Member#: 107569
1998 Forester S
SRP
Strength, maybe. The stock ej257 rods failed after about 50,000ish miles of excessive power but never had gasket issues. I now use ARP bolts mostly because my stock bolts are in my other car which is under 300whp I would guess.
Anyway when I started college I wanted to do mechanical engineering but then switched to Electrical Engineering. I remember playing in the strength of materials lab with metal and stretching them. I'm sure there are a lot of people that know a lot more but I believe that the type of metal the factory bolts use can be stretched over and over without an issue. The only issue I would think could happen would be if the bolts were severely over torqued the metal would deform and could not be reused. Since I have been the only one to use my bolts I trust that this has not happened.
Old 03-27-2009, 08:29 AM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
HEADGASKETS PEOPLE...........HEADGASKETS.
There are dozens of threads regarding the reuse of headbolts. We don't need another one.
I've reused MLS gaskets once, but they had only been torqued(incorrectly)....not run through a heat cycle. It probably boils down to just how cheap you wanna be. It's not even frugal if you save the $$$ here but pay even more later if they fail. You're always going to question them if you reuse them and they work out..... You'll have more confidence if you just replace them. Recycle the metal if throwing them out bothers you. I'm kind of the same way.....hate to pitch or replace something that is for the most part, still good. That's why my garage looks like Sanford & Sons house! Headgaskets are just one of those places that is not worth chancing it.
Jay
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 10:38 PM
reuse exhaust gaskets? wiresix17 Newbies & FAQs 8 09-22-2009 03:38 AM
reusing head bolts hypoxvi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-01-2009 07:22 AM
Is torqueing down the head, then removing the head, considered reusing the gasket? mokujin22 Built Motor Discussion 8 10-20-2006 09:29 AM
Opinions needed: Reusing Exhuast Gasket Zongo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-28-2003 09:20 AM
