Old 03-26-2009, 02:08 PM   #1
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Default what size cams for my build?
I will be running an atp 35r stock location on meth 25-26 pounds daily. the heads are completely stock, while the block has custom cp pistons, crower rods, new crank, studs, gaskets, bearings, etc.
what would be a good size and company to upgrade my cams to?
also what kind of benefits would i really see? is it worth it for me?
thanks for any help anyone can provide.
godforbid67 is offline   Reply With Quote
Old 03-26-2009, 04:12 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
talked to my builder/tuner and he said 272/272 crower is the way to go. he also mentioned "buckets" which are 25 dollars a peice and hes unsure how many i need as many as 16 but most likely only 8 what are these?
Old 03-26-2009, 05:11 PM   #3
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
The tops of the valves that are micorns different in width/hieght. They are used to set valve lash. You can proably move a few of the ones you have now to get to the right spec and buy as little as 2/3 or as many as 10 but you're liekly to have some already that can be moved around and reused...
Fongers is offline   Reply With Quote
Old 03-26-2009, 06:05 PM   #4
Kaldar142
Member#: 151090
S197 boosted V8 FTW
i'm very satisfied with my crower 272s, hold power all the way to 7200.
by the way, go with CROWER not brian crower
Kaldar142 is offline   Reply With Quote
Old 03-26-2009, 06:25 PM   #5
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
+1 for Crower cams
slowmike is offline   Reply With Quote
Old 03-26-2009, 06:25 PM   #6
godforbid67
Member#: 137168
06 Built SGM WRX
after further talk with my buddy, i think im going to do 280/280 crowers with springs and retainers. he said that they do not make them for my engine though, he said he talked with crower and they will make a custom set at the same price (for an ej255) of 725. i think im going to do this. keep the input coming. he said with the springs retainers and cams and buckets, it will be abut 1900 installed, my engine is already pulled. does this seem like a good fair price?
Old 03-26-2009, 06:55 PM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
What's the lift on those?
You maybe killing your spool with that size of an exhaust cam profile.
mick_the_ginge is offline   Reply With Quote
Old 03-26-2009, 07:33 PM   #8
godforbid67
Member#: 137168
06 Built SGM WRX
with the 280's? think its too much?
Old 03-26-2009, 09:24 PM   #9
godforbid67
Member#: 137168
06 Built SGM WRX
can you get into more detail with that?? how much do you think it could hurt the spool?
my buddy said the 272's should be about 20 wheel or so and the 280's should be about 40 wheel. does that sound about right?
Old 03-26-2009, 10:42 PM   #10
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
To the right of the graph maybe at the cost of spool on the left. What's the lift? 10.5, 10.7, 11........... 272 for example denotes the duration which is only part of the equation. What's the max lift?
I'm however useless with cams, I run a 272/264 mixed set. I get great spool, my 35R is at full boost by 4000 but the top end drops off starting at 6300.
Old 03-26-2009, 11:19 PM   #11
godforbid67
Member#: 137168
06 Built SGM WRX
i want to say the lift is 10.5, i dont remember what he said it was just over 10, and he said the 272 were 9.xx.
how much do you really think that would affect it? im running a green now and would not mind losing a little spool for 30-40 wheel but im going to upgrade to the atp 35r and kinda do not like how it spools already. i NEED full boost by 4500, i mean ill see what happens maybe ill go with something a little smaller then the atp.
Old 03-27-2009, 09:14 PM   #12
ki11switch
Member#: 176422
I have 280/280 brian crower cams and brian crower springs and retainers in my 06 wrx tr. So does that mean they are the custom order like you are talking about? whats different about them?
ki11switch is offline   Reply With Quote
Old 03-27-2009, 09:28 PM   #13
godforbid67
Member#: 137168
06 Built SGM WRX
can you show me a link to exactly what you bought?
i think my builder was talking about brian crower cams maybe.
Old 03-27-2009, 10:10 PM   #14
godforbid67
Member#: 137168
06 Built SGM WRX
also do you have a video of your car idling or anything? also when do you hit full bost on your 35r? whats your set up exactly? did you feel the cams hurt your spool at all? any info will help thanks man.
Old 03-27-2009, 10:42 PM   #15
ki11switch
Member#: 176422
i bought my car already built. Saved me some cash haha but anyway heres a link to my dyno graph and info on my car http://forums.nasioc.com/forums/show....php?t=1707229
I didnt know brian crowler and crowler were different?
Old 03-28-2009, 02:14 PM   #16
godforbid67
Member#: 137168
06 Built SGM WRX
can you make a video of the car idling?
Old 03-28-2009, 02:15 PM   #17
godforbid67
Member#: 137168
06 Built SGM WRX
do ej257 cams pop into the ej255 ok?
Old 03-28-2009, 02:25 PM   #18
ki11switch
Member#: 176422
i would but my engines coming out today! the idle is deffinetly more rough compared to the stock cams
Old 03-28-2009, 04:11 PM   #19
godforbid67
Member#: 137168
06 Built SGM WRX
true well i want to hear that thing if its ready before my car, and from your other post- you dont like the rough idle? i love how that sounds and can not wait!
also do you have avcs still? or could you not get those cams to do it?
my builder said that the ej255 cams are very similar to the ej257 but hes not sure i will retain the avcs if i use ej257 cams.
so my question is still do ej257 "drop in" to an ej255.
Old 03-28-2009, 04:18 PM   #20
ki11switch
Member#: 176422
here is a vid of my car on the dyno before i bought it, i dont know if it will help
http://www.youtube.com/watch?v=744vgIgzr4g
i dont know if my car has avcs, i am trying to find out or i will find out when i pull the engine out...
Old 03-28-2009, 04:22 PM   #21
ki11switch
Member#: 176422
my idle sounds alot like this car http://www.youtube.com/watch?v=aNyIAmsX3QU
Old 03-28-2009, 04:49 PM   #22
godforbid67
Member#: 137168
06 Built SGM WRX
when are you hitting full boost? and what turbo set up?
Old 03-28-2009, 04:56 PM   #23
godforbid67
Member#: 137168
06 Built SGM WRX
so its not so lopey its kinda quick lopes right?
Old 03-28-2009, 06:19 PM   #24
ki11switch
Member#: 176422
yeah more quick
Old 03-28-2009, 11:51 PM   #25
06njsti
Member#: 150986
06 LSB STi
AWDM.NET-LMM Powered
talk to your tuner with big plans like that
06njsti is offline   Reply With Quote
What cams should I use for my build? ScoobyJD Built Motor Discussion 129 01-31-2010 01:52 PM
What size tire for my rims??? (zaksti) Tire & Wheel 22 01-23-2010 10:08 PM
What size speakers for my sti? wrxroberts Car Audio, Video & Security 2 11-30-2008 04:11 PM
What size wheel for my 04Wrx w/ Sti suspension? ScoobyDudeRPM Tire & Wheel 4 03-12-2008 11:18 PM
What size tires for my 17s? nick robinson Tire & Wheel 2 05-17-2003 03:17 PM
Message Board Statistics All times are GMT -4. The time now is 02:56 AM.
