Welcome to the North American Subaru Impreza Owners Club Monday September 1, 2014
Old 04-14-2002, 12:14 AM   #1
STiTuner
Member#: 5778
09 135i
Jet Black
Default GOO by my ECU
Today when Graham and I were pulling out or carpeting we noticed that both of our cars have a puddle of GOO!!! by the ECU about there the passenger would put their feet. At first I noticed it in Grahams car and I just thought nothing of it and Blamed his girlfriend for it.. but then I noticed it in my car and thought.. His girlfriend hasn't been in my car.
It looks like Sounddampining that got heated up and started to melt and its very very sticky and blackish brown.
What is this myster puddle? cause its not me and its not his girlfriend.. and he said it wasn't his... so what is it and where did it come from???
Brad
STiTuner is offline   Reply With Quote
Old 04-14-2002, 03:07 AM   #2
Andrew
Member#: 1170
2005 STi
didnt you know? thats where the trunk monkey relieves himself. he woulndt do it in the trunk right? that would be like doing the deed in your own room, not cool. so he crawls up there and does #2.
n00b.
Andrew is offline   Reply With Quote
Old 04-14-2002, 05:55 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
n00b.
you don't crap where ya sleep do ya?? it's prolly just sound shielding...relax, breathe...it'll be okay i promise
jeremy
Old 04-14-2002, 10:41 AM   #4
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
It probably just is sound shielding, but what the heck is causing it to melt...
I think I'm gonna stick with the trunk monkey theory for right now......
Graham
Graham is offline   Reply With Quote
Old 04-14-2002, 12:18 PM   #5
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Does your downpipe pass close to the floor there? Those things aren't that cold ya know
Impreza Rider is offline   Reply With Quote
Old 04-14-2002, 12:22 PM   #6
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
I pulled the carpet back on my 2002 after only having it for a few weeks and it was sticky there too. I think it is too keep the carpet in place, but who knows... I guess a trunk monkey would have had to go by then.
PunKidd is offline   Reply With Quote
Old 04-14-2002, 01:54 PM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
My downpipe passes relatively close, but not enough to start melting the inside of my car! We touched the area right underneath the melting spot right after the car was turned off and it was hardly hot. Also, this happened on STiTuner's car also, and his car is N/A.
Graham
Old 04-14-2002, 01:57 PM   #8
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
I believe that is where your AC water drains out... check above the ECU a little and there will be a tube that connects to the AC water reservoir if you have a lot of condensation that's where the source should be...
HOK is offline   Reply With Quote
Old 04-14-2002, 05:24 PM   #9
Andrew
Member#: 1170
2005 STi
all signs point to monkey dung
Old 04-14-2002, 07:57 PM   #10
kturner
Member#: 8225
Default ECU Location
Please help a newbie who has searched. I'm looking for the ECU in my 01 Legacy. I've started to pull up the carpet under the passenger's feet but didn't see anywhere that looked like a good place to keep a computer. There was a silvery metal plate up towards the front of the car. Is that a likely spot? Otherwise there's a plastic piece closer to the seat. Maybe under there? No gooey stuff to report. I'd hate to pull up the whole interior to find out the ECU is next to the spare tire or something. Thanks.
kturner is offline   Reply With Quote
Old 04-14-2002, 08:55 PM   #11
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Your ECU is behind that silver plate. Grab some sockets (12mm if I remember correctly) and pull it off. Don't mess around with it unless its for a good purpose.
Graham
Old 04-14-2002, 09:15 PM   #12
STiTuner
Member#: 5778
09 135i
Jet Black
I think it was a 11 or a 10. I 11 I was using to unbolt the plate was kinda slipping.
Brad
Old 04-14-2002, 10:14 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
all 10mm bolts.
Old 04-14-2002, 11:16 PM   #14
kturner
Member#: 8225
Default Thanks guys!
You guys are amazingly prompt and detailed! I'll get right on it with that 10 mm. Graham - Is working towards a Link II with an eye to a turbo charger a good purpose? Depends who you ask I guess. The car is currently perfectly fine at the moment with only 9,000 miles on it. I wanted to get a look at the ECU to see if Gerry's wonder plugs would work or if I "should" get a spare ECU to hack up. I don't think I will cut the harness.
Old 04-15-2002, 09:33 AM   #15
STiTuner
Member#: 5778
09 135i
Jet Black
you would need not only a spare ecu but the spare pigtails offa wire harness to make them tie in together right.
I would love to go that route but I already hacked the harness and 100-300 bucks is outta my range.
Brad
*HELP* Identify this goo under my oil filler cap vilespankmachine Service & Maintenance 7 04-21-2010 12:10 PM
Green goo on my underside Legba Newbies & FAQs 19 01-13-2006 04:19 PM
What is this goo in my coolant overflow tank? yobtah Factory 2.0L Turbo Powertrain 1 05-28-2005 03:27 PM
DO I need to reset my ECU when changing my muffler? Jfrankon Factory 2.0L Turbo Powertrain 1 03-28-2003 02:05 PM
My alarm shorted my ECU bruno Car Audio, Video & Security 7 12-18-2001 03:43 AM
