Old 03-26-2009, 07:21 PM   #1
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
Default hooking up boost gauge-halp!
great
so i got a boost gauge and i hooked it up, but i have a couple questions. at idle it's at about -11
the gauge says Hg or whatever on it. i'm a turbo newb and may have not my homework correctly. so how is Hg different than PSI? also i know (when working correctly) it's only supposed to put up to 8.7 psi and my gauge goes up to 10 hG (so i thought i was in range) when i get on it, even pretty moderately it goes wayyyyy up to about where 20 is. pretty sure that's not right anyway.
thoughts?
Meat Supply is offline   Reply With Quote
Old 03-27-2009, 01:34 PM   #2
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
Rei_Akira is offline   Reply With Quote
Old 03-27-2009, 07:51 PM   #3
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
well.great.
so what kind of device would use Hg and only up to 10? motorcycle?
Old 03-28-2009, 11:45 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Usually boost gauges have a vacuum side (mm Hg), and a boost side (psi.) The mm Hg is vacuum pressure, that's how many millimeters of mercury it pulls i n vacuum.
Are you sure its a boost gauge? Usually the vacuum goes to like 20 or so and the boost goes to about 30. There will be a zero in between the two largest numbers.
~Josh~
help hooking up boost gauge grasshopper2.5rs Electrical & Lighting 2 03-27-2008 11:48 PM
Is there any other way to hook up boost gauge? maxpower_454 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-11-2005 12:58 PM
help please..how to hook up boost gauge warpspeedwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-06-2003 10:48 AM
How to hook up boost gauge and turbo timer on legacy! MugenNeuspeed Legacy Forum 12 09-19-2002 05:58 PM
WRX: Where to hook up boost gauge? djerickd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-10-2001 11:31 AM
