Old 03-26-2009, 06:40 PM   #1
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
Default boost on NA ecu
has anyone attempted to run a td04 on wastegate pressure on the stock ecu without any sort of ems? i plan on putting my hydra on the car but for smog i need to know if its safe to run it on the stock ecu.
SubeSTIle is offline   Reply With Quote
Old 03-26-2009, 08:43 PM   #2
mikeythejew
Member#: 141672
You are obviously hoping someone says what you want to hear. Not safe.
mikeythejew is offline   Reply With Quote
Old 03-26-2009, 08:49 PM   #3
Skidd
Member#: 1853
GC6 Supercharged
STM
Probably.
Skidd is offline   Reply With Quote
Old 03-26-2009, 10:01 PM   #4
PA-Outback2000
Member#: 161832
2000 Outback Limited
someone correct me if i' wrong, but if hydra is a piggyback, it controls boost, not the stock ECU. u shouldn't run more than 6-7psi on stock N/A compression though.
PA-Outback2000 is offline   Reply With Quote
Old 03-26-2009, 10:33 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Hydra is full standalone....and the best way to go if you have one. Eliminate ALL your headaches in one swoop.
Jay
Old 03-26-2009, 10:45 PM   #6
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Without ANY EM?
Might as well just put a grenade in your airbox and stand back.
XanRules is offline   Reply With Quote
Old 03-27-2009, 01:16 AM   #7
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
just to clarify its not a stock block, its an ej22t block that is in there so compression is about 7.4:1. i just need to know if it will run enough out of boost to pass the cel check. most likely im going to be using a GT30r and the hydra standalone ems with a wrx intake mani and 750 injectors. ill just swap in the stock intake mani and ecu before smog and run it NA to pass i guess
Old 03-27-2009, 01:35 AM   #8
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Are you running it n/a already?
At that compression ratio?
With no problems?
Regardless, your plan won't work. You'd be better off finding a shady emissions guy or something.
Old 03-27-2009, 03:20 AM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
It should pass, put in the smallest injectors you can and still have it idle.
If you can, just run stock injectors and run the turbo with the wastegate loose/open for emissions.
Old 03-27-2009, 10:11 AM   #10
Skidd
Member#: 1853
GC6 Supercharged
STM
Ah ha.. a little more information has surfaced now.
So, the OP isn't looking run a car with stock EM.. just run it, drive down the road, and pass emissions. Right? Now were getting somewhere.
Like red said above.. that's a pretty good option. Jimmy the wastegate to stay open, and you should see little to no boost, assuming you stay off the skinny pedal.
As for will it run well enough to pass the CEL check... that's a good question. I can't help you on that one. My guess would be that yes, it should. But, that's just a guess.
Old 03-27-2009, 01:09 PM   #11
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
With no problems?
Yes I am running it na currently
Yes it runs fine but is really low on power which is causing it to get very bad gas mileage (aprox 16-18) other than that not having any problems running the car this way. I am pretty set on putting the 30r on the car ill post a writeup in the bolton forced induction when its finished
Old 03-27-2009, 03:37 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
The extremely low CR is what's making it run so poorly. It's just too inefficient right now.
Get some air into the cylinders somehow!
Jay
Old 03-27-2009, 10:50 PM   #13
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
i was thinking a hair dryer to blow some air in seriously though not really just going to get a turbo on it soon
Boost/Vacuum Gauge on NA engine bullworm562 Normally Aspirated Powertrain 15 12-24-2007 11:19 PM
FS/Trade: MAP-ECU & 95 NA ECU for AEM EMS dejacky Private 'For Sale' Classifieds 0 04-11-2006 12:10 PM
Too much boost? for NA ecu? reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 5 12-13-2004 11:20 PM
8-10 lbs of boost on my little old 2.2 NA. reddevil Legacy Forum 3 08-24-2004 11:32 PM
Throttle postion vs boost on stock ecu map UM-WRXer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-12-2004 10:20 PM
