Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Old 03-26-2009, 07:36 PM   #1
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Default Wrist pin and rod question
Hey guys, my engine builder mentioned to me today that when my eagle rods are married to my ROSS pistons it has a lot of side to side movement compared to the stock piston and rod setup. When i say side to side i mean the top of the connecting rod that holds the wrist pin slides along from one end of the piston to the other ( if this makes any sense). Now my question is does this have to be within a certain spec? If i were to take a guess i would say that so long as the pistons movement is only up and down and the crank does not walk back and forth this should not have any effect because everything is all in line of each other.
This picture might shows more, if there is any confusion. It is the distance between "A" and "B" that is larger then the stock piston. All other clearances are bang on within the wrist pin and piston and wrist pin and rod etc etc.
cribbie is offline   Reply With Quote
Old 03-26-2009, 10:35 PM   #2
madmax718
Member#: 172501
Its angled for her pleasure.
If you look closely at some rods (yours included most likely) you'll see a little angle that allows it a little side to side play. There should not be any slop in the normal piston cycle movement (as I think you stated).
The side to side play actually allows for better lubrication at the actual surface that has the most contact. I still personally like the larger contact surface area.
madmax718 is offline   Reply With Quote
Old 03-27-2009, 08:37 AM   #3
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Added another picture for better illustration.
Old 03-28-2009, 07:36 AM   #4
cribbie
Member#: 184505
2003 WRX
Sonic yellow
bump for more input
FS: (NY) Sti pistons and two sets STI rods (pistons, wrist pins, rods x 2) mtcs Engine/Power/Exhaust 16 04-29-2009 12:16 AM
wtb:1 Sti B Piston, wrist pin and rings Ray@revitup Private 'Wanted' Classifieds 4 03-31-2009 09:20 PM
Wrist Pin/ Rod Bearing Question dimpster Built Motor Discussion 29 09-06-2008 10:47 AM
Rod Bearing/ Wrist Pin question dimpster Service & Maintenance 8 08-27-2008 01:09 PM
Rod Bearing/ Wrist Pin Question dimpster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-25-2008 08:22 PM
