Old 03-26-2009, 09:17 PM   #1
cujo87
Member#: 99025
2000 IMPREZA
BLUE
Default Does any one have a set up like this?
I have a 2.0 wrx engine. it has a v6 crank with cos worth bearings and wisco pistons, and manley h beam rods. I have new wrx heads with ARP head bolts. It also has sti pink injecters. MRT top mount. tgv deleats, vf 23 turbo. cat free up pipe. and TBE
I would like to know what I can expect out of this engine.
How much more can i push the timing? what kind of boost can it handel ? I am not looking for exact numbers just how this is better then a stock wrx 2.0 and what people are or have experienced with simaler setups.
thanks
cujo87 is offline   Reply With Quote
Old 03-26-2009, 09:22 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
what turbo are you running? what rods are they?
if your on stock turbo it can handle ALLLLL the boost out of the lil guy.
it could handle 25 pounds daily on a fairly "big" turbo.
its far far far far better than a stock 2.0 block.
godforbid67 is offline   Reply With Quote
Old 03-27-2009, 01:00 PM   #3
cujo87
Member#: 99025
2000 IMPREZA
BLUE
update on the turbo and I am not sure of the rod brand.
Old 03-28-2009, 10:55 AM   #4
cujo87
Member#: 99025
2000 IMPREZA
BLUE
any one else have a set up like this?
Old 03-28-2009, 01:32 PM   #5
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i say bigger turbo, and deff bigger injectors
seanathanq83 is offline   Reply With Quote
Old 03-29-2009, 01:59 PM   #6
cujo87
Member#: 99025
2000 IMPREZA
BLUE
bump.
Old 03-29-2009, 02:05 PM   #7
godforbid67
Member#: 137168
06 Built SGM WRX
are you going to keep that turbo? if so get as much boost out of it as you can, your engine can hold it fine. probably wont make much boost over 20-22 pounds but try and go has high as you can or want.
Old 04-01-2009, 12:48 AM   #8
cujo87
Member#: 99025
2000 IMPREZA
BLUE
Bump.
Old 04-09-2009, 06:28 PM   #9
cujo87
Member#: 99025
2000 IMPREZA
BLUE
does any one have a similar setup? What kind of can i expect to see?
Old 04-09-2009, 07:22 PM   #10
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
If you didnt port the crap out of those heads before you installed them...you just wasted a crap load of money. Subie heads flow very poorly. You have a good sounding bottomend but the turbo size and non-ported heads are your 2 big power robbers. Dont worry about your injectors, get a adjustable fpr and save some money.
scby rex is offline   Reply With Quote
Fuel cut defender? What exactly does this thing do? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-26-2002 12:04 AM
what is this thing??? Hondaslayer Mid West Subaru Owners Club Forum -- MWSOC 13 04-01-2002 12:04 AM
What is this thing on the engine? Andrew Normally Aspirated Powertrain 9 08-27-2001 09:09 AM
What is this thing? (big pic) cvalle-sd Normally Aspirated Powertrain 9 02-26-2001 04:56 PM
Holy Hood Scoop! What is this thing? (semi-large pic) 8Complex General Forum Archive 30 05-15-2000 09:55 PM
