Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-26-2009, 10:05 PM   #1
w chapman
Member#: 75673
Angry 1999 NA 2.5L going into Open Loop at idle
On my 1999 2.5RS engine....a NA 2.5L, no mods...stock ECU.
My ECU is switching from closed loop to openloop after about 25 seconds at idle.
When the switch occurs the engine stumbles then surges up and down a few times....then settles into a (somewhat) stable open loop idle....although not nearly as smooth as the closed loop idle w/ the O2 sensor.
An OBD-II scanner shows it going from "openloop O2" to "closeloop drive".
Immediately when the I let up on the gas the O2 sensor voltage stops fluctuating and flattens at .01v or less....then in about 25 seconds it goes open loop...accompanied by a stumble and a few surges while the ECU figures it all out.
OBD-II reader shows (Absolute Throttle Position = 0.0%" at idle
and Short Term Fuel Trim also goes to 0.0% at idle.
Have installed new O2 sensor .....no joy.
Very frustrated.....need help.
Warren C.
w chapman is offline   Reply With Quote
Old 04-01-2009, 10:38 PM   #2
w chapman
Member#: 75673
Bump......come on ....someone HAS to have some helpful info on this
Warren C.
Old 04-02-2009, 08:36 PM   #3
GrundleJuice
Member#: 165749
have you tried the ECU forum? they might be able to help, too. Sorry, i couldn't give you a credible guess.
Old 04-02-2009, 08:41 PM   #4
SubaruDriver502
Member#: 114182
2003 toyota corolla
RIP wrx, damn u bambi!
Have you reset the ecu?
Maybe take it in for a reflash (obviously stock map) and see if that works.
Other then that...you already replaced the o2 sensor so
SubaruDriver502 is offline   Reply With Quote
Old 04-03-2009, 05:25 PM   #5
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
o2 sensors will cause this issue. I have had this happen to me before. I would start there. Try the rear sensor first.
Gr3en is offline   Reply With Quote
Old 04-03-2009, 05:50 PM   #6
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
Which 02 did you replace? The fronts are whats need for open-loop....the rears are for fuel trims from what I know of Fords. Also the front and rears are different as the Fronts are "heated" and the rears not...i think its a load of crap since both are in an exhaust pipe...but start with the fronts and then the rears, i know it gets kinda spendy...my 98 contour did this to me and that solved my issue... theres my 2 cents. hope it helps
rivman05 is offline   Reply With Quote
FS: N/A 1999-2002+ 2.5L RS T OBS SOHC 2.5L NA Short Ram Intake 02baruRS Engine/Power/Exhaust 0 05-24-2010 03:16 AM
Trackdaze at VIR March 1-2. Anyone going? Still open! mav1c Mid Atlantic Impreza Club -- MAIC 9 02-27-2010 07:43 PM
UTEC 4.2, I like the Open Loop Fueling, but is the ABC any better? Kwyjibo Engine Management & Tuning 5 06-18-2004 03:36 PM
Forcing ECU into open loop IdenityCrisis Engine Management & Tuning 0 06-12-2004 10:55 AM
Forcing ECU into Open Loop WRSport Normally Aspirated Powertrain 0 06-29-2002 02:55 AM
