Old 03-26-2009, 11:43 PM   #1
1st1
Member#: 194358
08 WRX
Default HELP, My fenders are rubbing on my back tires....
Hey Everyone,
I just purchased some new rims and rubber for my 08 WRX and I have a slight problem. The back tires rub when I go over potholes or bumps on the road. I had called a subaru dealer in Ottawa to find out if they would fit properly before buying them and they said yes.
what I bought: 18"x8.5 ADR Propulsion
Nexen N7000 235/40R18
The rims and tires look sick on the car and I want to keep it that way. I figure my only two options is to
1) Have the rim's inside bolt plate shaved down 2 cm; or
2) Roll my back fenders (I'd hate to do this on my new car!!!)
Can Anyone offer any helpful advice ? Where do I go or who do I contact to have this kind of work done??? I live in Ottawa, Ontario, Canada.
_________________
Lovin my first WRX!
1st1 is offline   Reply With Quote
Old 03-26-2009, 11:58 PM   #2
STIckySTIfee
Member#: 162812
2004 STI
roll them man, its not as bad as it sounds, just keep constant heat on surface.
STIckySTIfee is offline   Reply With Quote
Old 03-27-2009, 12:29 AM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
They have a 35 offset and a 71 center bore.
I would definitely recommend rolling the fenders and you may want to get some hub centric rings if you don't already have.
tora is offline   Reply With Quote
Old 03-27-2009, 12:31 AM   #4
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
you can run more camber in the rear so it won't rub (you might need camber bolts), I would roll the fenders with a heat gun and fender roller. I just had to roll my FRONTS
djerickd is offline   Reply With Quote
Old 03-27-2009, 01:22 AM   #5
sniper913
Member#: 164943
You know what, I have the same issue, works XD9 18X8 +45 with 245/40/18. I love my wheels and would like to keep them, I am on stock suspension btw. Whenever i do hard turns and bumps, fender would hit the tire and scrape some off. Either roll fenders, or camber is the only way out.
sniper913 is offline   Reply With Quote
Old 05-06-2015, 08:33 PM   #6
subielovin08
Member#: 403464
2008 Impreza sport h
lightning red
I Need someone who can properly roll fenders in the Ottawa region!!! Just got some miint rota grids on my impreza they are 17x9 they look great but they rub in the back only!!! Can anyone help me out with a name or number? Id appreciate it!!
subielovin08 is offline   Reply With Quote
Old 05-06-2015, 10:22 PM   #7
Canadmos
Member#: 408498
2009 WRX
Drive to Lachute?
Just start calling up any tuner shop and ask if they roll fenders.
Canadmos is offline   Reply With Quote
Will 18" stock subie tires/rims rub on my 2002 WRX wagon? mespinola Tire & Wheel 9 11-14-2009 09:22 AM
another: would this tire rub on my current setup Lordhowe Tire & Wheel 5 11-11-2008 05:11 PM
* HELP Hella Supertones Rubbing on my STi Grille ultraspdWRX Interior & Exterior Modification 13 10-14-2007 10:14 PM
Will these Wheels rub on my GC8?. Help! UpTown I-TS Interior & Exterior Modification 11 09-14-2005 12:43 PM
Rubbing on my Kosei K-1 from Tire Rack AntiochCali Tire & Wheel 8 07-24-2005 11:04 AM
