Old 03-27-2009, 08:16 AM   #1
Inder
Member#: 137838
2000 Legacy GT Sedan
Timberline Green
Default NA EJ252 rebuild..
Hi,
I have the EJ25 Phase II SOHC (EJ252 on VIN) in my 2000 NA Legacy GT and I am getting the engine rebuilt soon, and want it to be strong enough for future boosting.
It's currently at 60k miles and has some piston slap and higher than normal oil consumption...
I was considering:
- Wiseco Piston Set 9:1 or 9.5:1
- K1 H-Beam rods
- 08 STi head gasket...
- ARP head studs
- All new seals, gaskets, pullies, belts
- Water pump
Is there anything I am missing that should be done?
Any of this not need to be done, to save costs?
Anyone have part numbers if possible?
Application: This will be a daily driven street car.
Expectations: ~250awhp
Long term possibilities: ~300awhp
I only have access to 91 octane fuel.
Any help would be appreciated.
Thanks,
Mark
Inder is offline   Reply With Quote
Old 03-27-2009, 11:06 PM   #2
Inder
Member#: 137838
Timberline Green
bump!
Old 03-28-2009, 12:36 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Get used STI rods and save money.
Go lower than higher compression if you are going to piggyback the stock ECU.
98 EJ25D headgasket is awesome, although itlowers compression due to the thickness.
Old 03-28-2009, 10:18 AM   #4
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
You aren't going to do the bearings? Are you going to refresh the head at all, at least valve stem guides and seals and maybe at least check the valve seats for tolerances? I would put a new oil pump on too while you're at it. They're pretty cheap.
What kind of fuel injectors are you going to use? How are you going to tune it? You have to replace your exhaust manifolds of course, what are you going to do to them? I would at least port match the manifolds and get an up-pipe (pretty cheap for a good gain).
GodSquadMandrake is offline   Reply With Quote
Old 03-28-2009, 10:18 AM   #5
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
****need Help With Cel Codes-please Help************** stito Subaru Conversions 4 07-29-2007 04:55 AM
Need help with swap/rebuild tptwrc Subaru Conversions 4 05-03-2006 03:31 AM
Desperate for Help with Cobb AP.. Please help Flyguy3663 Engine Management & Tuning 5 10-08-2005 04:14 PM
HR need help with caliper rebuild LotusDriftx Mid Atlantic Impreza Club -- MAIC 17 10-19-2004 10:15 AM
I need help with utec logs. PLEASE HELP! dman918 Engine Management & Tuning 3 05-04-2003 02:54 PM
