Old 01-11-2016, 04:44 PM   #1
falcon1982horus
Member#: 437891
05 9-2X
NA
Default Hybrid build / Parts selection help needed
Hi WRX fellow,
To everyone who has hybrid build EJ257 on EJ205 port head. Please give me good constructive advice on who is a good approach and what parts recommended append to what I have list here. What level of power do you guys thing i will get on stock stage 1 drivetrain to the wheel?
I have a beautiful red Saab 9-2X (WRX with STI rack)
My motor blown on me just right before Christmas @ 150K
Anyway, I decided to keep the car going as a DD and go on with Hybrid engine build on 19-24 psi.
- Build block EJ257
- Weisco 100mm piston
- Manly rod
- ACL racing bearing
- STI Nitride crankshaft
- TOMEI M7960 rather than M7690
- Injectors Dynamic 1000CC
- Welbro 255 fuel pump
- Cobb EBC
- Cobb access port V3
- Up pipe & bell mount down pipe
- High volume TMIC
- K&N filter
Much appreciate.
falcon1982horus is offline   Reply With Quote
Old 01-13-2016, 06:24 PM   #2
redwards11
Member#: 214876
If I had to guess 320-400whp depending on dyno, altitude and fuel. You can aim to the higher end with cams and head work. I just did my first start on my new motor running the same m7960. Old result for me on stock 205 heads/257 bottom end was 352whp 367wtq on dynojet on 19psi, conservative timing and fueling. I went with cams, port on heads and chamber match this time around.
redwards11 is offline   Reply With Quote
Old 01-18-2016, 12:54 PM   #3
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
That turbo is good for up to 400hp. Your list of mods is going to get you close... a pump gas tune would probably get you more in the 360-380 at 22-23psi. That said, the power will come on EARLY if you look at the charts. So for "driveability" and overall DD-ness, I'd give this setup a thumbs up. I think you'll be pretty happy. If you're looking for most peak power, and don't mind waiting until 4K rpm or later, choose a different turbo. Too much bigger and you may max out the 1000cc's. Your tuner would be the best guy to ask about all of this.
It's always the wisest to consult a tuner anytime you put together a list of mods like this.
bdubblu is offline   Reply With Quote
Old 01-22-2016, 06:05 PM   #4
falcon1982horus
Member#: 437891
05 9-2X
NA
I hope to see something close to 370whp with 19 PSI. I have EJ257 and port match polish 205 head. Like to have a all around fun and VERY reliable DD, Thx guys.
Old 01-27-2016, 12:19 AM   #5
URABUS07WRX
Member#: 262367
2007 WRX
I would stick away form 100mm pistons if possible. Keep as much cylinder wall as possible. I know a good number of shops that won't do a piston that size. 99.75 is as big as they will go and it much be for good reason.
For pistons I'd stick with Manley, CP and JE. H-Tuff rods seem like the no brainer for most builds. Manley rates those rods at 750 chp.
Bearings of choice depending who builds it and what they're comfortable with using.
For turbos I'd personally recommend blouch or any borg turbo. A few are stock location too which is awesome.
I'd get the heads port matched to the 2.5L and then you can really get some more out of the heads if you decide to do cams.
With a 5 speed id look at the 6258 from Borg. Vf series spool without the asthma attack. The blouch 16gxt would be my second choice.
Just my 2c. Hope it helps!
URABUS07WRX is offline   Reply With Quote
Old 01-27-2016, 07:01 AM   #6
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Just drop in an EJ207 then run it on carberry flexfuel for a solid 350whp on e85 that will be long term reliable
Gigs90 is online now   Reply With Quote
Old 01-29-2016, 02:37 PM   #7
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
You can save yourself some money by purchasing JE hybrid pistons. That way you won't need to get the heads chamber matched. It's the way I'm going after talking to a few shops and a few members on here who have done it.
svynx is offline   Reply With Quote
Old 01-29-2016, 06:25 PM   #8
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
I just put the JE's in my build. No problem. Chamber matching is highly debated, but there's a ton of hybrids using the JE's with perfect results.
Old 01-30-2016, 07:52 PM   #9
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
Agreed. The "proper" thing to do would be to chamber match (when using any stock or non-hybrid piston). Going with the JE hybrid piston kills two birds with one stone...getting a forged piston, and not having to deal with the chambers matching. The charge to have the machining plus the price for the pistons compared to just pistons is a no brainer to me.
Old 02-04-2016, 08:07 PM   #10
Hagbeard
Member#: 40286
'04 WRX Sedan
Platinum Silver
Two years with JE pistons on a hybrid build here, no problems, although I'm still on the stock TD04. Ya, it's only got 230 whp, but the 280 wtq comes on at 2800 rpm!
Hagbeard is online now   Reply With Quote
Old 02-04-2016, 11:01 PM   #11
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Ha! That powerband's gotta feel like a v8.
Old 02-05-2016, 10:48 AM   #12
Hagbeard
Member#: 40286
'04 WRX Sedan
Platinum Silver
It has tons of mid grunt, but it starts falling off pretty quickly north of 5K. Great for passing and finding holes in traffic, though.
Old 02-08-2016, 09:08 PM   #13
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You are my hero! I miss my stock turbo days sometimes.
Old 02-08-2016, 11:28 PM   #14
Harey
Member#: 270569
'15 Foz XT & 02 Foz
EJ207
+1, love my EJ207 conversion super reliable, daily driver, 1/4 miles, occassional track day.
But I think its the wrong section for this thread.
Harey is offline   Reply With Quote
Old 02-19-2016, 08:30 PM   #15
falcon1982horus
Member#: 437891
05 9-2X
NA
Thank for all you 2 cents and comment fellow. I already bought build my new block with listed part. So, I had to get my head port matched. I choose this Tomei snail because of the exact fitment and Japanese quality in detail. It is really remarkable. When I get it back from the shop, I will take sometimes to learn my new power band and its characteristic. Another month or two in, I should be in full tune and tight bra undone mode. +
Old 06-28-2016, 07:28 PM   #16
falcon1982horus
Member#: 437891
05 9-2X
NA
It had been a while since I got it through break-in period not break-it period. I finally got my car full tuned and Mustang dyno with EJ257 full forge block and STI head.
Result is impressive and satisfying. @ 20 PSI produces 320 WHP on 92 Octane Dinosaur fuel.
Stock intake and exhaust for sleeper kill, quiet and super fast..
